My kenmore washer series70 motor humms
I pulled the motor out re-connected it pushed the lid switch down and the motor just humms if i turn the motor shaft a few times it starts i put a new motor in and the same thing do u no if there is a start up capacitor for it
    President:
  • 1,922 Answers
Yes there is a capacitor on most washing machine motors on a kenmore series 70 it should be on the right front panel upright leg
Posted on Dec 06, 2012
3 Suggested Answers
  • 165 Answers
SOURCE: Kenmore front load washer won't start
No power Check to see whether power is getting to the washing machine. Is it plugged in? Has a fuse blown or is a circuit breaker tripped?
Lid switch If the lid switch is defective, your washer can't spin and may not function at all. The switch is inside the washing machine main housing near the door frame. Often you have to raise or open the top or front of the washer to get to the switch. If it's defective, you need to replace it.
Some machines have a special lid-switch fuse near the lid switch, inside the control panel. If this fuse blows, the unit won't fill with water until you replace the fuse.
bad start switch, sometimes the contacts in the start switch will arc and burn causing starting up problems.
Posted on Feb 10, 2009
Maytag317
  • 1136 Answers
SOURCE: kenmore washer lid switch bypass failure.
HI. Check and see if you might have tripped the breaker. If there is a ground fault outlet close by. check that as well.
It sounds like you bypassed it properly. Try and reconnect the wires with the wire nut. Sometimes it doesn't connect properly.
I hope this helps you.
Please let me know if I can assist you further.
Thanks
Vic
Posted on May 30, 2009
Kenmore model 23832100 washer will not spin in rinse cycle kenmore model 23832100 washer fills, agitates, and drains, but will not spin. Makes noise after draining. BUT if I manually turn off the machine...
Check door switch: If the lid switch is bad it will not drain or spin. Try this test: With lid open let it finish wash cycle. Press lid switch down with screwdriver. Washer should begin draining. Release switch. Motor should stop. Press switch a second time. Washer should start spinning as it continues to drain. If motor doesn't come on while lid switch is pressed, replace the switch. OR
http://www.youtube.com/watch?v=q942xn_2VXY
Mar 30, 2013 | Washing Machines
My 70 series just humms
What is the complete model number of your unit?
Dec 05, 2012 | Washing Machines
Washer filled with water but has stopped and will not adgetate or spin
next time send the model number.check the lid switch.set it on spin,close the lid and then open it a few inches,do this a few times repeatedly,if you don't hear a clicking sound when the lid opens and closes the switch is bad,you can try sticking a screw driver into the hole on the top right side to see if it will spin,no clicking sound when you push down on the switch the switch is bad,or you can pop up the top console,you might have to remove the corner covers to get at the screws,when the screws are removed push in the timer so no power is going to the machine,set it on spin,lift the console up and you'll see two clips,on the right side you'll see a white wire harness connection,that's the lid switch,disconnect the harness,it plugs into the top of the washer on the right side,when it's apart,stick a jumper wire into the two outside holes of the harness that you removed from the lid switch,the middle hole is the ground,when you have the wire pushed into the two outside holes pull the timer out and if it starts to spin then you know it's the lid switch.let it drain out the water then push in the timer knob to shut it down remove the jumper wire and get a new lid switch,when you have it pop the two mtal clips and then you can pull the frame off of the washer to get at the switch.if you send me the model number i can look up your washer and give you the part number or you can call your parts store,give them the model number and they will sell you the correct part.good luck with your washer.if the motor runs but it's doing this you could have broke the motor coupling,let me know what problem you find and i will send you a video to help you change out the lid switch or coupling.
Jun 21, 2011 | Kenmore Washing Machines
Our Kenmore washer (23812) stops working at the spin cycle, and the water will not drain out of the machine. Help!
This is a clear evidence of a broken lid switch. Power to the drive motor is routed through the lid switch during the drain/spin cycle. The machine, therefore, cannot drain and spin when the lid switch is not working. The drain pump doesn't work because it is directly coupled to the rear spline of the motor. Replace the lid switch to address the problem.
Release the console from the top of the cabinet depending on the model of your machine then pull forward and up on the console and lay it back on the hinges.
Disconnect the lid switch harness connector by pressing on the tab located in the middle and pulling it up.
The cabinet is attached to the rear of the washer by two brass-colored retaining clips. Insert a flat blade screwdriver into the turned-up edge of the clip, located on both sides, and then pry back to release the clip from the slot in the cabinet.
Open and hold the lid while grabbing the cabinet front opening then tilt the top of the cabinet toward you by pulling the cabinet away from the base. This releases the front and back slots of the cabinet from the tabs in the front and back of the base.
Using the side of your leg and/or body as a support for the front of the cabinet, carefully lift up the cabinet and lay the front on a cushioned floor to access the lid switch.
Remove the lid switch ground and mounting screws then release the wire harness from the metal retainers. Pull the lid switch connector out and install the new lid switch in reverse order of the removal steps.
Bring the cabinet to the front of the washer then slide the front bottom rail of the cabinet under the rail at the base of the machine then lay down the cabinet into position. Make sure the slots in the cabinet sit into the tabs at the base of machine.
Reconnect the lid switch harness then push the retaining clips back down into position to secure the cabinet to the rear of the machine. Reinstall and secure the console to complete the repair.
Oct 28, 2010 | Kenmore 23812 Top Load Washer
I have a kenmore 90 plus series model # 11068972892............... when i push start button the dryer motor will humm and mabey start to run or it will just humm and not run at all..if it...
Check under the machine and see if the motor turns easily by hand. It could be the motor, or it could be the bearing. The switching off after a while implies that the motor is struggling against a heavier than normal force and trips because of overheating. Most likely the bearing/s is/are ceasing up.
Sep 06, 2010 | Kenmore Dryers
How to bypass a lid switch on a Kenmore 90 series washer?
bypassing the switch is done by connecting the two(outer 2)wires.thus closing the switch circut to the timer
Jul 24, 2009 | Kenmore 22942 Top Load Washer
Washer won't spin or agitate
bad lid switch or bad motor coupler or both-mike
Jun 02, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Kenmore washing machine 80 Series 110 20802 990 Will not agitate or spin"
You need to replace the Kenmore Washer Lid Switch. I had the same problem so being lazy I would just push down on the washer's lid and it would push the lid switch further down. making the water drain. after a while I just replaced the lid switch.
Apr 22, 2009 | Washing Machines
Getting to lid switch on kenmore washer to replace it
This can be done without taking anything apart or removing anything except the lid switch.
Take the two screws out that holds the lid switch and let it drop into your hand. You may have to pull a little if it doesn't drop down on it's own. You may also have to push the tub over to get to the lid switch if you have big hands.
Dec 24, 2008 | Kenmore Washing Machines
Washing Machines Logo
50 people viewed this question
Top Washing Machines Experts
