Question about Dryers
What's the capacity (cu. ft.) of my whirlpool dryer?
Its an Imperial Super Capacity Plus and the model number is LER8857EQ0
Illeagle
  • 525 Answers
SOURCE: Our dryer, described below, takes
Your complaint is:"Our dryer, described below, takes between 4 and 6 hours to dry, though it's advertised as "heavy duty" and "extra large capacity.""
White Kenmore 5.8 cu. ft. Super Capacity Gas Dryer
Sears item# 02690412000 Mfr. model# 90412
Based on the information provided above, I am unable to provide a positive solution to your issue. Your model number is incomplete! I have provided some common solutions to help guide you in your search. This information is for a non-specific brand model, gas dryer.
This link, http://www.repairclinic.com/SmartSearch/SmartSearch.aspx, provides exploded view imagery, belt routing diagrams, parts imagery and function, parts ordering and shipping information, error code details, just about anything you need to get your appliance up and running again. Just follow the links to navigate through the site.
You will need to enter the model number stamped on the manufacturers product information data tag, located on the unit, and not in the User’s Manual. to access your product information.
It normally takes about 45 minutes for a dryer to dry a full load. If your dryer is taking more than an hour, check these:
Vent
Flame sensor/gas valve
Internal ductwork
Cycling thermostat
Lint Filter Vent: Frequently there's an obstruction in the vent duct from the dryer to the outside of the house. For the dryer to heat properly, the duct must be clean and clear of lint or any other substance. Also note that, to maximize drying efficiency, the vent should be as short as possible.
Flame sensor or gas valve coils: This is the most likely cause. Click links below. http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3449&PPStack=1 http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=3229&PPStack=1 There's a flame sensor near the igniter. If it's defective, the gas may shut off prematurely. Another common problem occurs when one of the electrical coils on the gas valve fails intermittently. If this happens, the flame shuts off before the thermostat sends a signal, which can greatly prolong the drying time. If the sensor or the coils are causing the flame to shut off, replace them.
Internal ductwork Your dryer has some internal ductwork. If it gets clogged, your dryer can't dry properly. In most dryers, to get to the internal ductwork to clear the clog, you have to substantially disassemble the dryer. A quick way to check for internal clogs is to remove the lint filter and use a flashlight to inspect the inside of the duct. If it looks clogged and you can't clear it using your vacuum, contact a qualified appliance repair technician.
Cycling thermostat Although this isn't a common problem, one of the thermostats that controls the temperature in your dryer may break and cause the dryer to heat poorly. If so, you need to replace it. The thermostat is usually a small, round, black device mounted to an oblong steel plate. The plate is mounted to the internal ductwork with two screws.
If my assistance helped resolve this issue, please show your appreciation by rating how effective my advice was in resolving this issue.
Thank you,
Dave E. (Illeagle)
"Your satisfaction is my personal reward"
Posted on Jul 14, 2008
bozcro
  • 867 Answers
SOURCE: turns on but doesn't heat up
most likely heating element needs to be replaced.most can be accessed by removing back panel. also a thermostat switch may be faulty.
Posted on Aug 09, 2009
SOURCE: Admiral 6.5 Cu. Ft. Super Capacity Electric Dryer not drying load
does the admiral aed4475tq have a reset button it will not turn on it is only 9 months old
Posted on Jan 01, 2010
hunter19_46m
  • 7482 Answers
SOURCE: Kenmore Elite 7.0 cu. ft. HE4 Super Capacity Plus
Your drum rollers is in need of lubrication.
You can lube them with a high quality machine oil like 3inOne oil.
Please rate me
Posted on Dec 28, 2010
  • 29 Answers
SOURCE: how to check and replace dryer's heating
unplug the machine from the wall - open the door and look in the top of the door hole - there will be 2 screws there - take them out and you will be able to lift the top off - the heating element is located behind the drum on the rear wll of the cabinet - use an Ohmmeter to test the element for continuity - if it is open - you will need to remove the front of the dryer and then the drum to replace the element - if it is continuituos the problem may be a fuse or thermostat or broken wire or an open timer
Posted on Oct 01, 2011
Won't let me change temperature and won't start up
There are some complex Circuit Boards on the newer models. It isn't a quick fix that I can give you. An Technician needs to check it over. Could cost a lot.
Jan 17, 2013 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool dryer model #LG7681XSW2 what is the cubic ft of this dryer? 22000 BTU...serial # MAO143334
Hello, about 7 cubic feet or roughtly 1.918 feet X1.918 feetX1.918 feet equal 7.048 cu/ft. I hope this help you. GB....stewbison
Sep 22, 2011 | Whirlpool Duet 7.0 Cu. Ft. 7-Cycle Super...
My Whirlpool Imperial Series WGD5550SQ0 has low heat, does not start the way it used to. My wife has to alter the settings to make it work. What could be the problem?
The 'operating thermostat' is not working correctly. It should allow heating up to about 155 degrees F and then open for a short period and then re-close. This is the cycle during drying.
Jul 09, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Whirlpool imperial series 6 cycle/3 temp electric dryer wont heat
My dryer is not heating, where is the cupling at in the dryer i have it open tho
Jan 10, 2009 | Whirlpool Duet 7.0 Cu. Ft. Super Capacity...
Dryers Logo
24 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
