Question about Whirlpool WMH2175XVB Microwave Oven
I have a Whirlpool microwave that ran but did not heat. while trying to identify the problem the fuse blew. I replaced the fuse but it immediately blew again when power was applied. what is causing the fuse to blow.
    Top Expert:
  • 14,553 Answers
A dead short---most have a large diode inside that you may have by accident destroyed. I will attach a photo of a typical diode but yours likely will be similar or may look different---it will have the diode symbol on it and or a band at one end---it has to go the same direction as the one in the unit.
Simple to test with a meter--resistance reading should NOT read like a fuse.
I have a Whirlpool microwave that ran but did not  - 12_6_2012_11_35_53_pm.jpg
note the triangle shape on this one
Posted on Dec 06, 2012
MicrowaveSvc
  • 9086 Answers
SOURCE: Microwave ahs power but doesn't heat.
The most common causes for a lack of heating are a bad door switch, a loose connection on the magnetron, a bad magnetron, bad connection on the control circuit board, a bad relay on the board, bad high voltage diode, or bad high voltage transformer. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can find helpful exploded view diagrams and order parts by entering your model number here: http://tinyurl.com/gv383
Posted on Sep 28, 2007
SOURCE: No power from Whirlpool.
The problem was a defective switch. There are 3 switches on mine. 1 on the top door latch, and 2 on the bottom. one of the switches on the bottom connected the power and neutral together, unless it was activated at the same time as the other 2, causing the breaker to trip or the internal fuse to blow. When unhooking the wire going from this switch to the other switch, everything works great now. Though I still need to replace the switch.
And for Basic 1. Yes my microwave did have a fuse in it it's ceramic, I got a pack of them at Radio Shack 4 for 3$ 250V 20 Amp. There should be a wiring diagram inside the microwave, mine was inside a black bag, so it may be hard to see.
Mine was up top next to the fuse behind the Plastic Grill and then a small metal grill. Some are behind the control panel, to fix this remove the screw at the top and then slide the control panel up and it should unhinge.
Posted on Apr 01, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Whirlpool GH518XP
Hattiemay
We see (and repair) this a lot. The problem is on the control panel, which we regularly repair nationwide by mail for $39.95 postpaid.
This light failure often occurs when a bulb goes out and the filament shorts, or when the bulbs are removed or installed without first unplugging the oven from the power line. Either can cause such a failure on the controller.
This can often also affect the exhaust fan operation, too. The lights and fan can be inoperable or stuck on too.
Details of our service and critical safety information and disassembly information is at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
Please feel free to contact me directly if you need more help.
William E. Miller, AS-EET
prototech@usa.net
http://www.microwavedisplay.com
Posted on May 30, 2008
MicrowaveSvc
  • 9086 Answers
SOURCE: Whirlpool microwave MH1170xsy0 1000 watts
With the symptoms you mention, I would suspect:
- loose or corroded connection at the magnetron
- bad magnetron
- shorted high voltage diode
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Here are some links you or someone you know can use for test help, but read their safety warnings first:
http://www.gallawa.com/microtech/diode.html
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Posted on Aug 21, 2008
welcomejee
  • 10594 Answers
SOURCE: panasonic genius microwave light bulb
Does your microwave front display lite?
Posted on Aug 27, 2008
What causes microwave to blow new fuse?
The only thing inside a microwave oven that draws enough current to blow a fuse is the magnetron that generates the microwaves to provide the cooking power. Based on the age of the unit (approx 15 years) it is most likely best to just replace it as repairs at that level are not cost effective. Newer units cook better and faster using less power these days.
Jul 02, 2015 | Sharp Microwave Ovens
GE Advantium 120 SCA1000DWW03 blowing 20amp fuse
Our unit was doing the same thing,
took it into the repair shop, they said there was nothing wrong with the unit, replace the main breaker that supplies power to microwave and try again.
Sure enough the breaker became defective, and we never had issues with it before, but now the unit has not had a single problem.
Feb 13, 2014 | GE Advantium SCA1000H Convection /...
Whirlpool Microwave MH6700xW-0 Blows internal fuses regulary
Assuming your power line voltage is okay, it would not surprise me that after 27 years, your high voltage capacitor is drying out and increasing its capacitance. This will cause variance in the high voltage output, which can stress the magnetron and increase current consumption.
You can order Whirlpool parts my model number here.
For more free DIY and other help & advice, feel free to contact me via my site.
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 16, 2017 | Whirlpool Microwave Ovens
Panasonic microwave NNP295SF shuts off after 15 seconds
It is going to be one of three things, the magnetron, " heart of the microwave oven " the inverter board, " if 7 years or less" and finally the keypad control board. In order to break this down, it will require testing to narrow the field. But what ever choice is made, the parts and labour are going to be the big factor when it comes to cost.
Apr 18, 2012 | Panasonic 1.2cu ft Microwave- Black...
The range-top light blew and now replacement bulbs
My Whirlpool/Roper microwave/hood combo has the same problem. I replaced the bulb twice, checked the bulb and it works, but not in the microwave. I wrote to Whirlpool asking about the problem. Haven't heard from them yet.
Apr 02, 2010 | Whirlpool MH1150XMQ Microwave Oven
Microvave does not heat the food
The Litz Coil or Magnetron Tube has failed. You can look for blown fuses when you remove it but there is usually another reason it blew and will most likely continue to do so if replaced. They are not worth repairing so it may be time to get a new one.
Jul 20, 2009 | Whirlpool GH4155XP Microwave Oven
Whirlpool Microwave, No Power
could be a damaged door saftey
Jun 14, 2009 | Whirlpool Microwave Ovens
Sharp Model 1451 blown power fuse
1.Problem with monitor door switch or
2. Problem with high voltage condenser.
Nov 30, 2008 | Sharp R-1874 Convection/Microwave Oven
Model #mh7130xe made grinding noise then in line fuse blew
Did you replace the fuse yet?
Did the new one blow?
If so, and if it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If so, and if if it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If the new one did not blow, and the microwave still makes a growling or grinding noise, but does not heat, you probably have a shorted high voltage diode or a bad magnetron.
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/cap_test.html
Oct 05, 2008 | Whirlpool MH7130XE Microwave Oven
Whirlpool WMH2175XVB Microwave Oven Logo
127 people viewed this question
Top Whirlpool Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a Whirlpool Microwave Oven Expert? Answer questions, earn points and help others
