Question about IBM ThinkPad T30 2366 Notebook
To increase the brigthness and contrast
Suddenly I am unable to increse the brightness of my pc. all the features to increase this has automatically turned off.
I have a gateway laptop and i would like to increase the brightness
Posted on Jan 12, 2009
INCREASING BRIGHTNESS OF CLOCK ON MICROWAVE
most models don't have that feature any more, If yours has a setup feature when you first power it up you may be able to adjust the contrast level up
Mar 19, 2014 | Samsung MW1030WA Microwave Oven
Too much brigthness
Adjust the Brightness in Power settings or Press the little blue "Fn" button next to the left "Ctrl" button. Then while still holding down the blue "Fn" button, tap the left and right arrow keys accordingly to increase/decrease the brightness.
Nov 03, 2012 | Acer Aspire One PC Notebook
Unable to reduce brightness windows7 ultimate hp1670
laptop ot desktop monitor ?
Adjust your monitor's brightness and contrast
You can adjust the brightness and contrast of your monitor to improve the readability of text and to make digital pictures appear more like they'll look when printed.
To improve the results when adjusting the brightness and contrast settings for your display, use Display Color Calibration. (Display Color Calibration helps you adjust these color settings and others.)
The way you adjust brightness and contrast varies and depends on your specific display.
Brightness and contrast buttons on the front of the monitor.
Some monitors have brightness and contrast controls on the front and use the standard symbols shown in the following image.
Brightness and contrast symbols
On-screen menu. You can change the brightness and contrast settings for some displays by using an on-screen menu, and then setting the brightness and contrast in the resulting menu. Many times, you can view the on-screen menu by pressing a button-possibly labeled Menu-on the front of the monitor.
Laptop display. Laptop displays don't have brightness or contrast buttons on the front.
For a majority of laptops, there isn't a control for setting the contrast.
However, you can set the brightness of many laptops by pressing and holding the Fn key, and then pressing a function key to decrease brightness ( ) or increase brightness ( ).
http://windows.microsoft.com/en-US/windows7/Calibrate-your-display#
When using Display Color Calibration on a laptop, set the display to the maximum brightness setting.
Adjusting brightness automatically using adaptive brightness
Adaptive brightness is a feature in Windows that uses a light sensor to automatically adjust the display brightness to match the lighting conditions in your computer's surroundings.
To use adaptive brightness, you must have light sensors installed and enabled on your computer.
To determine if your laptop or computer monitor supports adaptive brightness, look for the Enable adaptive brightness setting in Power Options (mentioned in the following procedure) or check the information that came with your computer.
To turn adaptive brightness on or off
Open Power Options by clicking the Start button , clicking Control Panel, clicking System and Security, and then clicking Power Options.
Under any plan, click Change plan settings.
Click Change advanced power settings.
In the list, expand Display, and then expand Enable adaptive brightness.
To turn adaptive brightness on or off when your computer is running on battery power, click On battery, and then, in the list, click On or Off.
To turn adaptive brightness on or off when your computer is plugged into an outlet, click Plugged in, and then, in the list, click On or Off.
Click Apply. Click OK.
hope this helps
Jul 26, 2012 | HP...
I have one pro view 17" view sonic monitor CRT with win xp as my OS. when i am working in my computer suddenly the contrast and brightness symbol comes on the screen and begin to increase to maximum...
buttons are not working perfect.therefore pressing automatically. you have to remove the panel after power on the monitor, (it may be dangers therefore get support by electronic technician , he will remove buttons and solder new ones or replace the switch panel.
Jan 18, 2011 | ViewSonic E70fb 17" CRT Monitor
Brightness and contrast increases suddenly
Check following:
1- VGA chord; is it loose or faulty?
2- Power Supply section not regulating perfectly.
3- Supply line from SMPS/Regulator power supply to EHT.
4- Brightness lines and controls (Resitance may be dry soldered or burnt)
5-Pin connection on rounded board of CRT neck may be loosed, Check it if loose than fit properly.
6- Adjust the precet for accelearting and focusing anode externaly fixed with EHT if inbuilt in EHT than only solution is to replace the EHT only.
Feb 15, 2010 | LG Computers & Internet
Monitor Contrast and Brightness Problem
service your monitor your monitors cadr is problem
Oct 02, 2009 | Proview PL19Wb Monitor
IBM ThinkPad T30 2366 Notebook Logo
71 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
