Question about HP Photosmart C6100 All-In-One Printer
We had a comcast technician install the phone service. after this, our printer has stopped working - it is a hp-photosmart c6180 all-in-one series. there is no error, it just says that it is offline when I go into the printer information.
  • Mohammed Rizwan
    Mohammed Rizwan May 11, 2010
    May i know, what is the Operating system of PC? and also check the printer status in control panel; Does it shows offline in printer n faxes in control panel?
    Thanks
    Riz
    President:
  • HP Master
  • 990 Answers
Hello sir; there has not thing wrong, just check out the printer cable is connect property.
Posted on Mar 17, 2009
HP PHOTOSMART c7100 pumpengine dont start
the service station and carriage is faulty and needs to be repaired or replaced. take the printer to a hp repair center for a technician to have a look at it.
Nov 10, 2013 | HP Photosmart C6180 All-In-One InkJet...
Cannot get Printer reinstalled after having Hard Drive replaced.
first you need to installed the sytem driver like mothrboard driver and the display driver then start installing the printer driver if you dont have printer driver you can download from this link,
http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?lc=en&dlc=en&cc=us&product=1153494&
Nov 06, 2009 | HP Photosmart C6180 All-In-One InkJet...
Wireless HP 6180 PhotoSmart All in ONe will not scan document to my computer
Well its the issue with the printer drivers taking a dynamic ip address.all you need to do is uninstall the printer network drivers,insert the s/w cd that came with the printer and then click on add a device ,it would install the printer drivers all over again.
In case it doesnt you can always contact a free online technical
support with an online live techbuddies technician at
http://tinyurl.com/m7ghqz
May 30, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 colors no good - missing colors & muted. No longer aligns print when requested, per HP note at end. Already cleaned print heads,[OK], aligned printer numerous times-doesn't work....
try resetting the printer using the # and the number 6 buttons,holding them down and then inserting the power cord at the back of the printer.
see if it works.
Apr 13, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP C6180 will only print a partial document
Hi Rbluhm,
I need somre more information regarding this issue. Like are you able to print fine from other applications without any issue, connectivity and foremost thing operating system you are using...
However, as a work around, I would suggest to select the "Print directly to the printer" option in the properties of Hp Photosmart C6100 series icon.
That is:
1. Go to printer folder.
2. Right click on the printer icon.
3. Click on the Advance tab
4. Select "Print directly to the printer" option.
5. Click apply and click ok.
Then just close all the windows opened on your computer and then re-open the Microsoft Word document and try printing....
I am sure this will resolve the issue. However, if the issue persist, do reply me soonnnnnnnnnnn.......
With Regards.
Mike.....
Feb 05, 2009 | HP Photosmart C6180 All-In-One InkJet...
Lost cd for HP Photosmart C6180 All-in-One
I have lost my HP photosmart C6180 installation software. Is there somewhere I can download?
Jan 22, 2009 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6180 goes Offline in Vista
Solution A:
Download and install this Critical Update for your printer directly from HP.
Solution B:
There have been cases where if the PC is turned off or goes into hibernate this can occur. To work around this issue the "HP CUE DeviceDescovery Service" must be disabled:
1) Click on the "Start Menu" icon on the bottom left corner of the screen, type "services.msc" in the "Start Search" edit box, and hit enter. This will trigger Vista to pop-up a "User Account Control" dialog to prompt for permission to continue. Click "Continue" to allow Vista to open the Services management console application.
2) The Services management console application is made up of 2 panels. The right panel contains a list of all services available on the system. Scroll thru this list and look for a service called "HP CUE DeviceDiscovery Service".
3) Right-click on "HP CUE DeviceDiscovery Service" and select "Properties" to open the "HP CUE DeviceDiscovery Service Properties" dialog.
4) From the "HP CUE DeviceDiscovery Service Properties" dialog, click on the "General" tab. If the "Service status" shows that the service has started, click on the "Stop" button to force the service to stop.
5) Change the "Start type" to "Disabled" and click on the "OK" button on the bottom of the dialog to apply the changes.
Solution C:
1. Set the printer to a static IP address
2. Logon to the machine as the administrator or with admin rights.
3. Remove/Reinstall the printer using the IP address
Dec 14, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C5240 AllinOne
In case its a communication error go to services and make sure the print spooler service is up and running. If there is any lxbce service running stop that and it will work fine.
Thanks.
Oct 13, 2008 | HP Photosmart C6180 All-In-One InkJet...
C6180 stopped scanning after installing leopard
Unplug the printer from the computer, uninstall the printer software, and download the latest software and drivers from the HP website.
Leave the printer unplugged from the computer while you reinstall the software. When the installation program asks you to plug in the printer, do so.
One the software has completed installation, reattempt the scanning function.
Jul 24, 2008 | HP Photosmart C6180 All-In-One InkJet...
HP Photosmart C6100 All-In-One Printer Logo
119 people viewed this question
Ben Johnson
