Not powering up at all. Taken battery out and should power up through charger however nothing. Model sony vaio pcg-3d1m Please advise if anyone else had similar problem. Thanks
  • 32,281 Answers
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Posted on Dec 06, 2012
  • 238 Answers
SOURCE: Sony Vaio PCG-K86P laptop
hi, the problem seems with the RAM, remove and clean the contacts with an rubber/easer, this should fix ur problem,let me know
Posted on Dec 20, 2007
  • 3 Answers
fjhdsjafjkds
Posted on Jan 02, 2008
SOURCE: how to reformat my sony vaio PCG-7L1M
abcd
Posted on Sep 26, 2008
HW_Dude
  • 87 Answers
SOURCE: How Replace CMOS Battery in Sony Vaio VGN-FS742 / PCG-7D2L?
Here is are disassemble instructions for you,
Good Luck
Posted on Jan 11, 2009
cheap to fix
  • 404 Answers
SOURCE: Sony Vaio Laptop Model PCG-384L - Won't turn on.
it means time to buy a new battery..it happens
Posted on Mar 09, 2009
Manual/user guide for Sony Vaio PCG-3D1M
https://esupport.sony.com/US/p/model-home.pl?mdl=VGNFW230J&template_id=1®ion_id=1&tab=manuals#/manualsTab
May 20, 2017 | Sony Computers & Internet
Sony vaio model pcg-61611L it turns on for 4 seconds and then it turns off using the ac adapter . help please
The charger may be bad, will it charge the battery? a common problem is the DC jack in the laptop breaks connection on the motherboard internittent operation or no power and shut down. If you can sub the charger that will tell if the power supply is bad or the problem is in the laptop. If the computer is the issue I recommend a professional because it will require extensive parts removal.
Mar 04, 2012 | Sony Vaio PCG-71318L
I hadn't charged my Sony Vaio model PCG-61611L for a couple days. Then when I finally plugged it in to charge, it won't turn on. I even left it plugged in for a few days and still nothing. It has...
Try A Hard Reset
Remove the battery and charger/ac adapter/power cord from your Sony Vaio laptop, press and hold the power button for 20 seconds to discharge any residual current inside the laptop.
This clears your RAM and is like a hardware reset.
Replace the battery and charger/ac adapter/power cord
and turn your laptop on.
If that does't work try removing ram and reinstall. Sometime this works with these laptops.
Sep 11, 2017 | Sony VAIO VGN-AW330J/H Notebook
The battery charger of sony Lptop VAIO PCG-7T1L has become faulty, i m not able to get a support fron sony service center, so how to purchase or get it reapired in Delhi
can just buy a replacement in the link below
http://www.ebuybatteries.com/product/GBProduct.asp?id=973M69&item=Sony+VAIO+PCG-7R2L+PCG-7T1L+PCG-7V1L+ac+adapter+laptop+charger
Feb 26, 2011 | Sony VAIO PCG-7T1L Series Laptop Charger...
I have a Sony Vaio PCG-661L I shut it down and it won't restart
do you get any leds when charger is inserted? if yes, try to remove battery, insert charger and press power on. also, i would recommend you test the output of your charger using a multimeter to rule out the possibility of a faulty charger.
Regards
Jul 23, 2010 | Sony VAIO Notebook
Sony Vaio PCG-K35 not seeing battery
Contact BatteryRefill support here:
http://www.batteryrefill.com/contact_us.phtml
They'll be able to help you better than anyone here on FixYa.
Mar 23, 2009 | Sony VAIO PCG-K35 Notebook
Dec 20, 2007 | Sony VAIO PCG-K25 Notebook
Computers & Internet Logo
74 people viewed this question
David Payne
David Payne
