When power is on, machine doesn't run, just beeps constantly, once per second.
Error code 66 is water pressure sensor.
66. (01000001) Pressure Transducer Error [Ptx Frequency > 90 kHz]
Note: this supersedes Fault code 65 from V41 Motor controller code onwards.
The Motor Control module has received signals from the water level sensor (Ptx)
above normal frequency values.
Primary Source: Motor Control module
Action: Replace Motor Control module
SOURCE: lid lock stays on and constant beep on excellence washing machine
I am having the same issue and hope someone can post a solution. I have found a work around though. Mine does it when it is on a 'Regular' wash cycle, I found that if I put it on Permanent Press it works fine.
