What operating system it is running on?
windows 7 premium
Try this Go to Start> type in services.msc> then double click on IPsec Policy Agent and on the startup type select disable and under service status click stop.
yeah that didnt work either.. it turns on when i turn the computer on and than shortly after turns off .. its gotta be something to do with the internet switch or something maybe the f2 button or something the keyboard is very clean so any other suggestions what if i took the computer apart
SOURCE: Help Installing network adapter for dell inspiron 8600
If you just purchased this recently and are retuning it, don;t worry about conecting to the INternet.
Just sxend it back. The Dell techs will do a complete refresh of the sytem before they sell it as a refurb unit, so don;t sweat this.
SOURCE: Dell Inspiron 6000 Laptop no wireless networks found in range
i don't know what is the fn+f2 button please help
SOURCE: Inspiron 6400 detects networks but does not connect to internet
Make sure you are connecting to your own internet connection through your wireless router and not on your neighbor's.....limited connectivity means you are out of reach or signal is blocked....
SOURCE: My WiFi isn't working on my Ispiron 1525?
this is working thanks a lot dear
i solve out my problem
thaks again
take care
and share the knowledge
SOURCE: wireless network connection not working
For some reason known only to Dell, the default setting for the Inspiron 6000 built-in wireless network adapter is 'off' or 'disabled.'
If you used Dell's restore disk to reinstall XP, the radio button is turned off. Go to control panel/system/device manager, find the wireless LAN device, right-click on it and choose 'Properties.' Under 'Wireless radio' check 'on' or 'enabled.'
Go back to Windows network setup wizard and go back through the steps using the 'restore network connection' button. You should be good to go.
There's an EXCELLENT network manager from Cisco named 'Network Magic' that takes all the guesswork out of setting up your internet connection. I highly recommend it. They offer a free trial and I think may even have a 'Lite' version that helps with simple connections without the bells and whistles of the full blown program. I'm not sure about that, but I can't tell you how much time it's saved me troubleshooting and setting up networks for my clients.
