Question about JVC AV-27530 27" TV
Setting up external speakers - JVC AV-27530 27" TV
    Top Expert:
  • JVC Master
  • 14,553 Answers
Only can be done if the set has connections on the rear for this--installing or adding speakers can damage the set instantly.
Posted on Dec 06, 2012
No sound coming from internal speakers Toshiba Projection television Model 50h82.
Some TVs have a set up option to disconnect internal speakers when an external audio amplifier will be used.
Dec 29, 2016 | Samsung Audio Players & Recorders
INTERNAL SPEEKERS do not work external speekers work when pluged in
Check the menu. In almost flat panel tvs there is setting that allow you to select in between internal speaker and external speaker. If the selected setting is external speaker the you wont get sound from the internal speakers.
www.electro-medical.blogspot.com
Sep 01, 2015 | LG 55GA6400 55" LED TV 1920x1080, 120 Hz,...
My lenco speaker has stopped working
If you have powered speakers and they work on other devices, such as; a pocket radio, recorder, etc.; then you need to reset the output to your speakers on the computer. Go to the lower right Icon (Speaker symbol) click on it. Go to System Sounds and see if the speakers are set correctly. If no check Marks indicate the external speakers are set, make your option set to your external speaker set.
Jan 16, 2014 | Audio Players & Recorders
External speakers don't work
If the set has a connection for external speakers they have be the same impedance (ohms) and the set will likely have to be switched from internal to external.
Dec 10, 2012 | Televison & Video
CANT FIND A EXTERNAL SPEAKER SET
before attempting that:
Look in set menu to see if speakers are switched ON or OFF.
Check on SET and a Box if used that sound is not turned off or low.
If set has hookup for external speakers is external or internal selected.
Does the set have sound when a DVD etc. is connected via one of the rear sets of audio/video input jacks?
SD TECH
Apr 24, 2012 | ESA PDP4294LV1 42 in. EDTV-Ready Plasma TV
Speakers are mounted on the side of tv (mitsubishi CS 40503 1995 model) want to remove them and have them in a different location
"Speaker: Internal/External" controls which speaker (built-in or external) is available. Set to "Internal" for normal operation of the internal speaker system. When connected to external speakers or an external audio system, the speakers can be turned off by setting this function to "External."
From reading this I see that the speakers may be internal because the setup allows to switch between external or internal. A mounted speaker is either permanent, part of the case, or has something that the speaker case slips into. I had one like that. You simply lift them and set them else where. How far they can be moved will depend on the wire. The wire is either attached internal through the back or attached via connectors on the back. That can either be loose wire or RCA plugs. Normally the wire coming from the speakers is attached internal, making the removal of them impossible. The wire is usually 3 to 6 feet long. You can buy an external speaker wire that has RCA plugs (and or plain wire) that will attach to the existing speaker wire and TV.
Good luck and post back
Jun 04, 2011 | Televison & Video
IBM thinkpad type 2647 - after installing external
Go to control panel / sounds / audio, and see if the boxes have greyed out writing, if so then the driver needs reloading, if they are all good check all settings.
Meant to ask if volume control icon is showing in the right lower task bar.
Dec 22, 2009 | IBM ThinkPad T23 2647 Notebook
Can't find the hands free speaker button
In an increasingly hands-free world, the external speaker feature of cell phones has increased the usability of cell phonesmag-glass_10x10.gif in the car, public transportation and at work. The volume controls on the external speaker controls can be somewhat difficult to find and manipulate.
  1. Step 1 Make sure the speaker setting is actually on. If the speaker is turned to off, the volume you hear will be coming from the earpiece and will be very low indeed. Sometimes there is a button on a cellphone which you can simply press and hold to activate the speaker function. You will notice a difference immediately.
  2. Step 2 Check to see if you have external volume controls. On some models, there is a button or two buttons that adjust the volume of both the handset and the speaker volume. If you have these buttons, use them to adjust these controls while on calls. Remember that adjusting the speaker volume will subsequently adjust the handset volume once you've turned off the speaker mode.
  3. Step 3 Access the sound controls in your phone. If your phone does not have external speaker control, it can be accessed by adjusting the controls saved on your phone. Also, the main settings can be controlled even if you do have external controls. Phones are different, but in your menu of options, choose sound and sound controls. This should give you options for ring volume, alarm volume and handset volume.
  4. Step 4 FInd volume controls for all settings. If you wish yo have multiple settings for each function---alarm, calls and speaker---you should be able to adjust these accordingly. Search through the control options until you've found speaker controls. Choose the setting you desire and save the settings.
  5. Step 5 Using the main volume as a foundation, use the external controls (if applicable) to adjust the levels.
Nov 15, 2009 | Cell Phones
Usb external speakers
MUTE THE INBUILT SPEAKER OF THE NOTEBOOK AND SET THE EXTERNAL SPEAKER
Nov 06, 2008 | Audio Players & Recorders
No volume
On the back of your set there are 2 switches that tell the tv whether you are using the internal speakers or the external speakers.
Make sure the switches are set to internal so the speakers in the TV receive the sound signals. If they're set to internal maybe the internal speakers are bad. Set the switches to external and hook up external speakers to the speaker terminals on the back of the TV. If neither setup works then it sounds like an output transistor or related parts.
Sep 01, 2008 | Proscan PS60690 60" Rear Projection...
JVC AV-27530 27" TV Logo
21 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
