Question about Timex Expedition 84601 Wristwatch
Change cr2016 battery in timex expedition watch
indays
  • 111 Answers
SOURCE: Timex Expedition alarm beep
good after noon ! maybe the problem of your watch is wrong possition of case back because the speaker or buzzer of your watch is attached on the case back , so open the watch and fix the case back at the correct possition ,!thank you ! god bless !.....
Posted on Aug 29, 2008
SOURCE: Timex Expedition sports watch - how to view lap times?
I ran into the same problem w/ my new Timex Expedition. I emailed their help desk and they said that the Expedition models do not have lap memory feature. You need an IronMan watch to get lap recall. Wish I knew that before getting this Expedition watch...
Brian
Posted on Jan 09, 2009
  • 4 Answers
SOURCE: beep and chime will not work
I think there would have been a minute spring coming from the back of the watch module to the backplate of the watch - this spring carried a vibration / beep which echoed off the backplate. Chances are you have damaged this spring during battery change - as i did with my gShock. Basically it's nackered!
Posted on Jun 12, 2009
SOURCE: How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
Posted on Jun 17, 2009
SOURCE: TIMEX MODEL MF13/P8
Press all the four buttons simultaneously your digital clock gets resetted. It worked for me try it out.
Posted on Aug 23, 2009
What's the band size for a cr2016 Timex indiglo? Also says wr 30 m.
these are not the model number , CR2016 is the lithium battery number and the WR30 is water resistance 30 meters.
you will need to send the watch off to Timex csd@timex.com
May 09, 2017 | Timex Watches
How to change CR2016 and SR526SW BATTERIES OF ironman triathlon 50 lap
Timex Triathlon Ironman Watch Battery Change - YouTube
? 2:44
https://www.youtube.com/watch?v=x_C7VsE8Kks
Jun 26, 2015 - Uploaded by Lin Le
Timex Triathlon Ironman Watch Battery Change, I forgot to show you how to reset the "AC" with tweezers so ...Missing: cr2016 ‎sr526sw
How To Change CR2016 Battery In Indiligo Timex Watch
www.mademan.com/.../how-change-cr2016-battery-indiligo-timex-watc...
Oct 15, 2010 - Wondering how do you change a CR2016 battery in a Timex Idiglo watch? Changing a CR2016 battery in a Timex Indiglo watch is not a hard ..
Nov 17, 2015 | Timex T5K018 Ironman Triathlon 30 Lap Flix...
Timex expedition indiglo wr50
The battery is a CR2016 as noted in the description. Hard to find these days.
Aug 31, 2017 | Watches
How do I open the back to change the battery on my timex e tide/temp watch
you had to have a knife caseback opener or any flat tools. look for the small opening on the back located on the upper right side of the caseback, insert the flat tool inside of it and just flip it up. then it pops out. note: after you had change the battery, you had to use pressing tools to cover it again because it cannot press by hands to seal it. it uses CR2016 size of battery. i hope i had been helped you.
Aug 20, 2011 | Timex Watches
Model no cr2016 cell timex 1854 can't change the date
Thank you for contacting FIxYa.
You can get instructions/manual at the following link:
http://www.timex.com/info/Product_Instruction_Guides_Downloads
By the way, that is not the style # of watch, that is battery type.
Best regards. Jewel
Sep 10, 2010 | Watches
CHanging battery on timex expedition, cover says
If you don't have the proper tools I recommend that you not do this yourself. You could scratch the case or damage the movement if you don't know what you're doing. If it's a water resistant watch the gasket also needs to be replaced once it is opened. DO NOT reuse a gasket! For about $8 any watch or jewelry2_bing.gif store can change the battery and renew the gasket for you.
Apr 09, 2010 | Timex Expedition 84601 Wristwatch
HOW DO I CHANGE THE BATTERY ON MY TIMEX 40691
There are so many applications use of the manual will be mandatory.
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
Feb 01, 2010 | Timex Expedition Camouflage 40691 Wrist...
Resetting Watch
Here's the inside of my Timex Expedition Dive watch. To reset the watch after replacing the battery, press down with a small screw driver on the metal tab that the red arrow is pointing to.
Nov 20, 2007 | Timex Expedition 84601 Wristwatch
Adjusting my timex expedition cr2016
nike T20 lap digital sport watch? Older model. cannot adjust time, date, etc. Know where to get instructions?
Sep 25, 2007 | Nike Super WR0064405 Wrist Watch
Timex Expedition 84601 Wristwatch Logo
888 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
