Question about Canon EOS 40D Digital SLR Camera Digital Camera with 17-85mm IS USM Lens
EOS utility not tranfering all images on card
Using the EOS utility started from the camera is not transferring all images. Used the manual transfer via the computer and all images transferred. The card said it had 400 images according to the camera, on the manual transfer it had over 900 images.
    Problem Solver:
  • 14 Answers
You are better off to simply remove the card and either use your built in card reader or obtain a external USB card reader and transfer your images that way. All you have to do is open 2 "My Computer" windows. Simply drag your photos from your card to your C: drive.
Posted on Nov 22, 2013
3 Suggested Answers
  • 102 Answers
SOURCE: Transfering Photos
edmerk:
In your case it seems like the software is the problem, try uninstalling it completly and reinstalling it back after a restart of your machine, also check this:
http://www.microsoft.com/windowsxp/using/digitalphotography/takeit/transfer.mspx
If this does not solve the problem then try using any other software for downloading pics from your camera or simply use the windows built in feature like:
Going to my computer, and check if you can see your camera drive there and simply copying and pasting from there. (see if this helps you).
I hope it helps you!
Posted on Dec 07, 2007
  • 62 Answers
SOURCE: EOS Utility does not recoganize Canon Rebel Xti
I believe there are 2 modes of usb transfer that you can pick in the camera. They are set somewhere in the menu in the options. If you go through the menus thoroughly you'll find it. One option is for connecting the camera directly to a printer and the other is for computer transfer (there might also be an Auto setting but I don't remember for sure). Make sure that setting is set for computer transfer. If that doesn't fix your problem, re-install or update EOS Utility / ZoomBrowser.
Posted on Aug 28, 2008
How to set up a wireless file transmitter(WFT-E4 II) to canon eos 5D mark II
Configuring communications settings in FTP mode1. Select [Address setting] with the camera's Quick Control Dial.
2. If you choose [Disable] for DNS server setting, enter IP address. For [Auto assign], enter server name. For [Manual setting], set up IP address.
3. Set up [Port No.] usually at 0021.
4. Configure [Proxy server].
5. Configure [Login method].
6. Set [Target folder] to [Root folder] or select folder using [Select folder] menu.
7. FTP server connection is established.
Note: Settings can be stored in the camera.
Configuring automatic image file transfer in FTP mode1. Select [Set up] in [WFT settings] menu.
2. Choose [Automatic transfer].
Configuring communications settings in PTP mode1. Select [OK] from Pairing screen.
2. Start WFT Pairing software on PC.
3. Double-click the icon inside PC task bar.
4. Select the WFT-E2/E2A/E3/E3A/E4/E4A [MAC address] you want from on-screen list of cameras.
5. Connection to camera is established.
Remote control of cameraOnce you start EOS Utility, you can control the camera remotely, using all available functions.
May 05, 2011 | Canon EOS 5D Mark II Digital Camera with...
I tried to tranfer my photos to my computer and
In order to transfer the pictures to the computer you have to turn the switch on to get the computer to detect it, Do you have your manual? if not reply back and I can send you directions. The other thing is you may have not taken any pictures if you did not have it set up right.
Jun 01, 2010 | Canon Rebel XT / EOS 350D Digital Camera
Problem with tranferring images to personal computer/new onset
Blame windows updates. Get a card reader...works every time.
May 11, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
40D not communicating with EOS utility
open device manager, connect camera, it will be seen briefly with yellow triangle and exclamation mark. open it up and uninstall.
Disconnect camera and close windows down. Restart windows, connect camera and switch on, windows will then find it and install driver. Took me hours to figure this one out
Mar 11, 2009 | Canon EOS 40D Digital Camera
Transferring images to my pc
Sounds normal. You could get a faster computer. I like using a  USB card reader.
Sep 18, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
Jul 30, 2008 | Canon EOS 400D / Rebel XTi Digital Camera
I have a cannon EOS 400D and i am trying to download images on to my laptop. i have the the camera plug in to the usb socket and the camera is on play back and turned on
Hey ikpoole,
What you need to do to transfer your images to your computer is first make sure you have installed the software that came with the camera on your computer. Make sure the camera is off and connect your camera to the computer using the USB cord that came with the camera. Turn the camera on and your computer should detect the camera and ask you what program you want to use to download your images, and select the EOS Utility. Your images should now download to your computer. Another way to download your images would be to use a card reader that supports your type of memory card and plugs directly into a USB port. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jun 20, 2008 | Cameras
Canon 20d raw to pc
Have you ever been able to view the pictures on your pc?
Have you got a card reader that can view the card contents externaly from the camera?
I found the Canon software is quite as happy from a card reader as it is reading from the camera. (I have the next model up, 30D.)
Have you tried upgrading your software, or tried using a third party image program to read the raw files?
Over to you!
Dec 29, 2007 | Canon EOS-20D Digital Camera
Transfering Photos
edmerk:
Dec 06, 2007 | Canon EOS 400D / Rebel XTi Digital Camera
Error: "Insufficient free space on startup disk"
Nikon View requires at least twice as much free space on the startup disk as the size of the CF Card being used to transfer images. For example, to transfer images from a 1GB card you will need at least 2GB free space for temporary storage while the images are transfered. The free space must be on the hard disk that the operating system is starting up from, even if the destination for the transfer is on a different drive.
Aug 29, 2005 | Nikon Coolpix 5700 Digital Camera
Canon EOS 40D Digital SLR Camera Digital Camera with 17-85mm IS USM Lens Logo
62 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
