I have 2 channel worth of wires i dont know what goes where
There is no power cord just 4 wires
    Sergeant:
  • 256 Answers
If you don,t no where only 4 speaker wires hookup to Get some one to help you that has done it before end noe,s what in the hell there doing, That you don,t fry it,
Posted on Dec 06, 2012
Wiring diagram for BOSS AVA 1209 equalizer. It was given to me dont know where the 4 wires connect red,black,white,last wire is orange or pink.
Your wiring is as follow's :
The Red wire is your (+) Positive that connect's to the power source
The Black wire is your (-) Negative that connect's to the ground
The Orange wire is your Auxillary (+) that turn's on Amplifier's or Power Ant.
You should have a Green wire, a Green wire with a White stripe,a Gray wire, and a Gray wire with White stripe
The Green wire is the LEFT channel input (+)
The Green/White wire is the LEFT channel input (-)
The Gray wire is the RIGHT channel input (+)
The Gray/White wire is the RIGHT channe (-)
(BE SURE THAT YOU CONNECT THE RED (+) AND BLACK(-) WIRES BEFORE YOU CONNECT THE ORANGE WIRE TO AN AUX SOURCE OR YOU WILL BLOW THE INTERNAL FUSE !!!)
PS. I have no idea where that White wire you mentioned goes.
Feb 03, 2011 | Boss AVA1209 7-Band Car Equalizer
NEED TO KNOW HOW TO HOOK UP A 4 PRONG CORD TO DRYER WHAT COLOR GOES WHERE
The following link explains how to properly connect a 4-prong power cord on your dryer:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
If you have any questions, please post back and let me know. I hope you find this helpful.
Oct 07, 2010 | Kenmore Dryers
Need to change power cord on maytag dryer from 3 prong to 4
Always disconnect electricity before beginning this process.
All the 4 wire cords I have seen are color-coded. The white wire goes to the middle terminal, the green wire goes to any screw you can reach that goes into the metal case of the dyer. The red and black go to the outside terminals of the block and while it doesn't matter which color goes to which terminal I usually follow the color code of the interior dryer wiring that already exists. Good Luck.
Oct 04, 2009 | Maytag SDE3606A Electric Dryer
I NEED HELP CHANGING CORD TO A 4 PRONG ASAP!!THANKS
These two pictures illustrate the power wiring on a the terminal of an electric dryer. The one to the left here is the old-style three-wire configuration. Most people have this type in their homes. New code changes, though, require that dryers now have a four-wire cord, shown to the right. These are just just thumbnail pictures that you can click for a larger view. But I'll bet you already figured that out, didn't you?
Besides the number of wires in each cord, there are two important things to notice. First, in the four-wire configuration, notice that the dryer's grounding strap is folded back on itself. The whole point of the four-wire cord is to separate the ground from the neutral. The green wire (the "new" extra wire in the four-wire cord) is attached to the dryer cabinet. In the three-wire configuration, the grounding strap is left intact and the neutral and ground are tied together.
tn_3prong_dryer_outlet.jpgtn_4prong_dryer_outlet.jpgIf you need to re-wire the outlet, these pictures will explain the anatomy of the three-prong (left) and four-prong (right) outlets. Once again, these pictures are just thumbnails--click 'em for a larger view.
Sure hope this helps you find a resolution to your delimma! Best wishes.
Comments: Jul 23, 2009- bf71290.jpgfb4d3ed.jpg
Three wire Four wire.
Better? Best wishes and sorry about the pics. Hope this is better.
Aug 17, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Power cord ?
What kind of radio is it? Looks like a Marine Band radio. Do you still have the owner's manual, as it will show the purpose for each wire. If you don't, write or email the manufacturer to get one. Most Amateur and Commercial gear simply has a red and black wire to get DC power to the radio. Sorry I couldn't answer your question better, but I've never come in contact with a four wire radio.
Longshorts.
Jul 24, 2009 | Uniden MC1010 (54 Channels) 2-Way Radio
I need to change my eltric cor from a four wire to
The following link explains how to install a power cord for your appliance:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
Refer to the section that discusses converting from a 4-prong to a 3-prong power cord.
If you have questions, let me know. I hope this helps you.
PS The GREEN wire is ground and gets grounded to the appliance frame.
Jul 06, 2009 | Whirlpool LER4634J Electric Dryer
Subwoofer buldging out problem
When speakers are wired in the wrong way the will do the "pushing out" you're describing. Basically the polarities have been reversed and if kept like this over a period of time will blow the speaker. Best thing to do is to disconnect the power by the negative on the amp and take out the fuse from the power supply. Check the wires running from the amp to the subs, negative to negative and positive to positive. I know it sounds basic but many people do mix it up! I would also check to see what channels the subs have been wired into?
Best way is to have one sub from channel 1 and the other sub from channel 2 for example. Or if its a bridged 4 channel amp, have 1 sub running from channel 1&2, and the second sub running from channel 3&4 still making sure of the polarities. Again this all depending what kind of amp and sub you have.
For example;
A 4 channel (bridged) 1000W amp. 250W max per channel or 500W per 2 channels! So if you have 2 500W subs, by connecting one to a single channel will decrease subs ability due to the lack of power supplied. However by combining 2 channels you optimize the output!
Once you know all your wiring from your amp to subs are ok/good connections/good wires etc you shouldnt have to "wiggle the wires" to get it to work as this is just a bad connection. Also ensure that no 2 wires are touching. Make sure that the master volume on the amp is turned down. You dont need this to be on loud at all, in fact far from it or you'll risk damaging both the amp and subs!
Hope this helps!
May 27, 2009 | Car Audio & Video
Correctyly wiring power supply to Kenmore dryer
A three wire pigtail is connected thusly. The two outer wires go to the two outer terminals on the dryer, the center lead goes to the center of the dryer terminal block. If its a four wire pigtail, the outer leads go to the two outer terminals on the dryer, the white goes to the center terminal. The jumper strap on the center is removed and the green goes to chassis ground.
Sep 16, 2007 | Maytag Neptune MDE7500AY Electric Dryer
Jensen LXA400
I have this same amplifier. I have noticed several ways it will "not work" during my ownership of it. I have it connected to a seperate battery to save my alternator, battery, etc as it is a power hungry beast for how low the output wattage is. Test the input voltage to see if you have enough, one way to see this is to check the "jensen" emblem that lights up. If you dont have enough power it will appear dim and only the right side lights up. Also the amplifier will not work if your speakers are "blown" even a little bit. Ive taken speakers that wont work on my lxa400 and connected them to a higher power amp and they will work (although they will sound horrible) If youre smart you will keep the gain under 3/4 on this amp, I see some people have found out the hard way that full gain fries the amplifier circuitry. Not an expert on electronics but it smells somewhat like melting glue or plastic. Ive noticed a lot of people have problems with the RCA jacks as well. There are 8 jacks, in two clusters. The first one is A+B and the second is C+D. Note: You do not NEED Y connectors on this amp! Connect your output rcas from the deck to top left and bottom left jacks of the left cluster. This will give you left and right (a+b) output from the first set of speaker outs. Then connect an rca patch cord from the top right and bottom right jacks of the first cluster and connect the other end to the top left and bottom left of the second cluster. This will give you output from the second set of speaker outs. Remember that this is in 4 channel mode. I dont remember the set ups for 3 channel but two channel I believe is the left deck rca goes to top left of the first cluster and the right deck rca goes to the top left of the second cluster. Then you just wire the speaker outs according to the picture on the amplifier. something like this: _________________________ |(+) - (-) +| ~~~~~~~~~~~~~~~~~~~~~~~~~ Speaker + goes to (+) and speaker - goes to (-) Also addressing another issue if you want to increase the wattage to your speakers you just use a lower resistance speaker (2ohm instead of 4) I would not recommend using anything over 4 ohms. As for the high level inputs, I dont recommend using them unless you have the plugs that go with them, its a lot easier to wire your deck rears to a line converter (changes straight speaker wire to RCA jacks) or to just buy a new deck with RCA outs. Last item, common knowledge: 400 watts does NOT mean 400 watts!!! This amplifier puts out very little actual wattage (50 or 83 per channel depending on the load) Hope all this helps someone out there.. Anyone who knows the 3 channel setups I would appreciate it.
Apr 12, 2007 | Jensen LXA400 Car Audio Amplifier
20 people viewed this question
 Grubhead
Grubhead
