Question about Maax Home
Maax stamina shower faucet leaking through the jets when turned off
TBlessed 1
  • 61 Answers
SOURCE: leaking maax shower drain
try this:
you might but it will depend if it is pvc then yes any other material you might be able to use a waterproof epoxy but it will harder to repair because of the epoxy but the pvc you can prime and glue the seam from the inside..
Posted on Nov 12, 2008
  • 659 Answers
SOURCE: Parts for sterling shower faucet
http://www.sterlingplumbing.com/contact.strl
The above link is the contact info for Sterling Plumbing Company. You can contact them and they will either be able to mail the parts out to you directly or tell you where you will be able to find repair parts.
Posted on Apr 17, 2009
  • 297 Answers
SOURCE: Moen Single Handle Shower Faucet leak...
the cartridge if defective,replace it and your leak will stop.
Posted on Jul 24, 2009
  • 10865 Answers
SOURCE: Maax bathtub Palace model Error code C01 jets don't turn on.
first of all check the circuit breakers to be sure one or both aren't kicked. be sure to turn the breaker all the way off and then fully on as a tripped breaker is in a halfway off position. if that doesnt fix your problem remove the access panel to the mechanical space in your tub. there are generally one or two reset buttons in there which can also kick off and need to be reset.
Posted on Sep 01, 2009
  • 150 Answers
SOURCE: i get a leak only when the shower bathtub faucet
check the bath faucet handle and the protective cover just beneath. if the water comes from here then remove handle and lower cover & tighten the nut on the insert and test without the cover
Posted on Sep 07, 2009
The water coming out the shower jets is not powerful, help?
follow this steps and fix it. God bless you
If a faucet leaks, replace seals and gaskets .
If a shower head leaks, create a better seal or replace seals .
If a sillcock wears out, replace the washers .
If a compression faucet drips from the spout, replace the washer and/or the seat .
If a faucet leaks from the handle, replace O-ring(s), replace the packing washer, tighten the packing nut, or replace worn packing, depending on the valve type .
If a ball or cartridge faucet leaks from the collar, replace worn O-rings .
If a disk faucet leaks around the base or has reduced flow, replace cracked or pitted disk assembly or worn inlet seals .
If there is water under the sink, tighten the faucet-set locknuts under the sink. You also can replace putty or a gasket, replace a worn faucet, or replace leaky supply tubes .
If the aerator leaks around the edge, replace the washer in the aerator .
If the spray hose leaks or has reduced flow, replace the O-ring on the diverter valve, replace a worn washer at the base of the spray head, or clean the diverter valve and spray head .
Nov 25, 2013 | Home
How to remove the shower valve on my Maax shower? It is leaking badly, and I think I just need to get to the valve that directs water to either shower head, or back sprayer nozzles or the whole body
Its probbably the hose connected to the valve, try screwing it back on and turn the water up slowly, if that does not help, check your local radio shack
Nov 05, 2013 | Maax Brio II One-Piece Neo-Angle Corner...
Leaking Neo-Round shower stall???
Check really close to make sure there is not a small crack in the base. Many times they can barely be seen and when you stand in the shower they open up larger allowing water to leak out. You may have to have someone else stand inside while you look for the crack.
Nov 08, 2012 | Maax Acrylic Base for Shower - 102623
Leaking water from head when turned off
It is normal for the water to trickle for a little time while the water drains from the shower head. If this continues you will need to repair the shower faucet
Jun 25, 2010 | Speakman S-2252-2 Anystream 6 Jet Dual...
Water comes out the shower head without the faucet lever being engaged
the whole faucet is bad it has an internal leak replace the whole thing
Jul 03, 2009 | Home
Cold water and jets don't work
Likely your mixer valve cartridge has a blown o-ring.
Replace the cartridge.
Jets not working may be as simple as the GFI outlet being tripped.
Thanks
Dec 16, 2008 | Maax Studio 1-Piece Hydromax Whirlpool Tub...
Jacuzzi
you have to call the maker of your unit because the gasket can start leaking if you use the rong kind of cleaner
Dec 12, 2008 | Maax Studio 1-Piece Hydromax Whirlpool Tub...
Home Logo
67 people viewed this question
Top Maax Home Experts
Donni Steen
Mike
James Feragola
James Feragola
Level 1 Expert
Are you a Maax Home Expert? Answer questions, earn points and help others
