Question about Cell Phones
My ph is nokia 5250, is i can see what is my phone lock code with secret key. Please help .
    Master:
  • 368 Answers
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
Posted on Dec 06, 2012
  • 4102 Answers
SOURCE: nokia N80 "phone lock code"
Hi have you tried 0000 thats usually the code that is stored when phone is new failing that you will need to get a flash lead and nokia softtware that scans the phone and gives you all the codes allowing you to change them but this is expensive to buy.
I have alot of nokia software but not sure if it works through usb lead as i use from computer then into black box then into phone as i have this as it works on all makes an model of phone if it can be done through the usb lead i can tell you where you can get this software from ok just give us a shout back
Posted on Mar 19, 2008
  • 89 Answers
SOURCE: 6630 phone lock code
Please give me your phone's imei no.
it is written on the back of your phone after removing battery,
then i will give you your security code.
Posted on Oct 30, 2008
SOURCE: want nokia n72 lock code
I have Nokia N72, IMEI 354533016020374; forgotten the Lock Code and cant change SIM card
please help
Biswajit Ghosh
Posted on Nov 01, 2008
piyush dixit
  • 136 Answers
SOURCE: How to retrieve the lock code in Nokia 7610?
UnlockMe! is a software that will allow you to recover the Unlock Code actually configured in your mobile phone.
You have to install and run the software on the phone and after some minutes it will communicate you the Unlock Code actually configured in the Phone
This application lets you retrieve your security/lock code.
*Firsty you Go to Options > Unlock!.
*Wait for some minutes.
You will see the security/lock code currently set on your phone.
Thanks,
Posted on Jan 26, 2009
  • 142 Answers
SOURCE: security code for nokia 5130
You will need to take the phone to a reputable mobile phone engineer or Nokia Service Point to have the security code reset to the default of 12345
Posted on May 22, 2010
Unlocking code
Hi if you are looking for network unlock code to unlock your Nokia 5250 mobile from network lock ..Then have a look at sites like http://www.onlinegsmunlock.com/nokia-5250/rs1wp9/ here they are rendering unlock code for all mobile models at reliable cost .You first verify that whether they are rendering code for your country and network provider .If yes then pay for it and unlock your phone ....
Jan 11, 2014 | Nokia 5250 Cell Phone
Hello my phone is nokia 5250. When i start to use my ph i change the daffult code. Now i forgot my new lock . Wt can i do for restore factory . Please help me.
My Dear Brother
If For puk & pin cod problem So Please
Very Best Solution:You Go To Service & Sim Office and Get The Puk code And Pin code From Office oprator
Enter The Puk code and Yes
Enter The pin code and Yes
So Puk code Open and Problem will Quickly Solved
Dec 06, 2012 | Cell Phones
I've forgetten my nokia 5250 lock code .my phone
JUST TAKE IT TO THE NOKIA SERVICE CENTER THEY WILL HELP U WITH THAT
Dec 05, 2012 | Cell Phones
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
PZL TRY THE FOLLOWING
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#92702689# [*#war0anty#]
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
Sir, plz give me phone restricted code my ime no.354862/02/440393/8
Just you try to check here to http://www.unlock-free.com/nokia/ or http://www.superunlockcodes.com/ this will be get you back to give the restriction code for your nokia 3110 at very short time..I also got the code from here only ...Hope its helpful...
Jun 28, 2011 | Nokia 3110 Cellular Phone
I have forgotten my lock code of nokia 5250 please help me
Default 6 Digit Security code: 000999 or 1122
OR:
May 31, 2011 | Nokia 5250 Cell Phone
Locking nokia 1200 by using key guard code?
You can do that I dont want you joining the 30% crowd on this site asking for master code when they forget the code. Hence SORRY.
Aug 10, 2009 | Cell Phones
My n95 ask for phone lock code please help me.
Thank you for choosing Fixya.com.
brother i can give your phone lock.
just log on this site and all of the secret lock code of mobile are indicated.
feel free to use it....
http://gleez.com/articles/did-you-know/nokia-secret-codes
don't forget to rate our answers
Feb 19, 2009 | Nokia N95 Cellular Phone
Nokia N80 "phone lock code"
Mar 17, 2008 | Nokia N80 Cellular Phone
Cell Phones Logo
23 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
