Question about Intel Motherboard
Dear sir, I purchase new intel mother board D945GCNL, some pins where we processor install damage. It purchase it before two week. How can we repair or replace it.
Purches new processer.....
Posted on Jan 12, 2009
What is max.hard disc size supported by intel DG41RQ mother board(can it support 1 TB+80GB)?-help me please sir..................
Any motherboard that is modern-enough to support "dual-core" processors can support *ANY* size of SATA disk-drive that you can afford to purchase.
Jun 21, 2011 | Intel DG41RQ Motherboard & Core 2 Duo...
Dear Sir, my mother board d101 has been damaged can i use of p4sd m/b insted of that while i want all rest parts remain using i dont want change ram,SMPS, Proccesser etc.
fbhushan, the Intel D101GGC motherboard (Grand Country) supports;
1) Intel Pentium 4, Intel Celeron D, and Intel Pentium D processors that fit in an
> LGA 775 processor socket.
http://en.wikipedia.org/wiki/LGA_775
The Processor has the socket holes, and the processor socket (LGA 775) has the pins.
775 socket holes, and 775 pins.
The Front Side Bus (FSB) can be either 533MegaHertz, or 800MHz.
2) Supports DDR Sdram ram memory at either 333MegaHertz or 400MHz.
(PC2700 and PC3200, respectively)
Will support Up To 2GB of ram memory.
Has two ram memory slots. The maximum amount for EACH slot is 1GB
3) The SMPS used for it has,
A) One 24-pin ATX main power cable
http://www.playtool.com/pages/psuconnectors/connectors.html#atxmain24
B) One 4-pin ATX +12 Volt power cable,
http://www.playtool.com/pages/psuconnectors/connectors.html#atx12v4
The Intel D101GGC motherboard has Four SATA headers (Connectors) on it, so I'm going to assume you are using a SATA harddrive.
This would mean the SMPS you are using should have at least one SATA power cable.
It should also have an assortment of 4-pin standard Peripheral power cables.
(Misnomered as 'Molex')
The Asus P4SD (Motherboard chipset Intel 865PE) supports;
1) Intel Pentium 4 and Intel Celeron processors that fit in a > Socket 478 processor socket
http://en.wikipedia.org/wiki/Socket_478
The Processor has the pins, and the processor socket has the socket holes.
478 pins, and 478 socket holes.
Your Processor will NOT work.
The Ram Memory WILL work.
The SMPS MAY work.
I state MAY because the Asus P4SD motherboard uses a 20-pin ATX main power cable.
If the last four pins of the 24-pin ATX main power cable that you have on your SMPS right now, Do Not remove, you can Carefully cut them off. Wrap them up, and out of the way.
If you need guidance on this I can help instruct you.
You need an IDE (PATA) harddrive, or a SATA adapter card to use a SATA harddrive.
So there you have it sir.
Regards,
joecoolvette
Nov 22, 2010 | Intel D101GGC Motherboard
Sir i have purchased mercury PI 945 GZD MOTHER BORAD BUT I AM NOT diceded which processor support this board pls help me
Designed for the latest Intel® Core™ 2 Duo/ Pentium(Dual-Core inside)/ Pentium D/Pentium 4/ Celeron D Processors with LGA775 Socket ...
Jun 20, 2010 | Intel Computers & Internet
Not able to install video drivers on D945GCNL mother board
Go & download then install driver robot : http://driverrobot.com/download/
When it's done open the application & click on the "EXPORTER" from the list on the left hand side.
Select were to save i.e Desktop or My Documents, Driver Robot will then run a scan & save the results to the file you specified it to save to i.e Desktop or My Documents.
Then go to the saved file which looks like a web document & double click on it,then you should see a page with "Get Drivers" on it. Press the "» Get Drivers" link in this page to proceed to the drivers list
You now have access to the hardware scan results and all available driver updates for your machine.
Jan 31, 2010 | Intel D945GNTLKR Motherboard
Intel Desktop Board D945GCNL - Motherboard has no Display & Bip
this is not the solution you folks are looking for, so here goes,a motherboard with physical damaged is going to give you more problems and headaches. i know this from experience, even if you find a new bios chip, you may be unhappy, due to the physical damage. how far does the damage go? to the chipset? is it just the bios? i would first try an add on video card, and see if you can at least use it. or just find a new board. i am sorry.
Mar 06, 2009 | Computers & Internet
Audio driver not installing
go here
http://www.intel.com/support/motherboards/desktop/D945GCNL/
Jan 13, 2009 | Microsoft Windows XP Professional With...
Audio driver installation failed from mother board cd
The most common solution was this: open device manager click "system devices" disable "microsoft UAA bus driver for high definition audio" uninstall "UAA bus driver" make rescan devices (Note: Not all had this step. You may want to skip it.) D.W. install realtek driver the realtek driver includes the UAA driver too.Hope this helps.
Aug 29, 2007 | E-Mu 0404 Sound Card
Intel Motherboard Logo
43 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
