Question about Frigidaire GLTF1670A Front Load Washer
Washing machine squeaks - Frigidaire GLTF1670A Front Load Washer
  • Official Brand Answer
  • 4,342 Answers
Hello Amanda Fosdick - It sounds like the washer either has a problem with the front tub, rear bearing or a loose connecting with the motor or drum. I recommend contacting a professional to move forward accurately and properly diagnose the unit. The part(s) may have to be replace depending if they are worm, damaged or loose.
Posted on Dec 06, 2012
Hoover 2300L 6.okg boss. Squeaking when agitating back& forth, not when spinning. Is this a bearing problem? & is it replacable. If so, from where in south australia? Or wherever.?
Washing machines don't usually run silently, but in most cases, a squeaking noise that occurs while the washer is agitating the clothing is not normal and signifies a problem. If the noise only happens when the washing is agitating, the problem is likely connected to the motor or your water pressure. Depending on the specific cause, you may feel comfortable fixing it yourself. Otherwise, call a professional.
Other People Are Reading
The Agitator
  • Agitators are located in the center of the drum, or basket, of top-load washing machines. Front loading washing machines do not use agitators -- instead, gravity moves the clothes from the top of the drum to the bottom. Agitators usually consist of a tall cone fitted with arms at the base. The purpose of the agitator is to rotate the clothes and soapy water around the tub to clean the clothes. The agitator itself is not usually the cause of the squeaking noise. It is powered by the drive mechanism, which consists of a motor, clutch and gears.
Motor Problems
  • A repetitive squeaking noise during the agitation cycle may signify a problem with the motor. Specifically, the belt on the motor may be wearing out. Some motors use rubber couplers, which also wear out easily. The belt is necessary for the agitator to turn, but over time, it wears thin, just like the belts in your car's motor. An easy way to test for this problem -- if you're handy -- is to take the belt off the motor and then run it. If the squeaking noise stops, the problem is indeed your belt. Of course, this means your agitator won't move. Replacing the belt should fix the problem.
Water Pressure Issues
  • The tub, or drum, fills with water right before the agitator turns on, and water continues to circulate throughout the washing process. As the tub fills and water circulates, you may hear a squeaking or squealing noise if you have high water pressure. This sound is caused by the force of the water moving through the pipes. To adjust this, turn the knobs on the hot and cold valves on the pipes that go into your washing machine.
Considerations
  • New washing machines may squeak at first as the parts "warm up," according to the GE Appliances website. The noise should disappear after five complete washing cycles have run on the machine. Unbalanced loads, overly heavy loads and loose items in the drum may also cause noise when the agitator comes on, but these things usually do not produce a squeaking sound.
Read more :http://www.ehow.com/info_12131280_washer-squeaks-agitating.html My Washer Squeaks When Agitating eHow
Jun 14, 2015 | Hoover Washing Machines
Why washing machine squeaks when in wash cycle
Hello friend, thank you for your inquiry!
Based off the information you have provided you are hearing a squeaking noise during the wash rinse cycle on your Frigidaire washer. You could be hearing the noise from your motor during that operation, this is normal. Additionally, if you feel that this is noise an issue I would contact a professional to come out and diagnose your appliance properly. -Matt
Aug 23, 2014 | Frigidaire Washing Machines
My top loading washing machines squeaks while washing
I wonder why it does that.
Are there any rubber "things" that are getting old and therefore not in a good condition so steel could touch steel.
Hope this works out for you
Kolbrun
Mar 26, 2012 | GE Profile WPSR3100W
I have a Fisher & Paykel smart drive 9 excellence 7.5 washing machine and the is a squeak coming from the bottom of the tub?
Hi Craig,just read your posting.The squeak could be the bearings.Is the machine noisy on spin?Could you reply back and tell me what part of the cycle the squeak happens.Looking forward to your reply.
May 17, 2011 | Washing Machines
Squeaking washing Machine during spin cycle
Hi
Loks that your machine is pretty old and hence the belt has hardened making a squeaking noise.
Good fix is get a new drive belt.
OR
Quick fix is you could put some oil on the drive belt..... it will work for now but not a permenant solution.
Regards
Berry
Feb 01, 2010 | Kenmore Washing Machines
Washing machine squeaks when running
I called a local repair service to check machine. Not good news! Pulley broken and transmission leaking. Cost to repair versus purchasing new washer prohibits repair. I sincerely appreciate your service and your response. Your service is a welcomed start to our problems.
Thanks
Mar 18, 2009 | GE Washing Machines
Admiral Washing Machine Makes Squeaking Noise
THE BRAKE IS VERY FAMOUS FOR THAT NOISE NOT INSPECT THE PUMP ,, CAN BE GRINDING ON BOTTOM BASE OF WASHER ,, BEARING POPPED OUT
Nov 22, 2008 | Washing Machines
LG intellowasher (front-loading washing machine) is starting to squeak.
I suggest u buy another washing machine. This one's had it!
Jan 12, 2008 | Washing Machines
Squeaky Washing Machine
There are many possibilities but a common one is a worn out idler wheel. 6b657f1.jpg
Jan 11, 2008 | Star Speed Queen AWS53NW 26" Top-Load...
Same squeak on spin -LW8203 shortly before that she ran an off balance load and now wonders why it squeaks..
Jan 06, 2007 | Amana ALW895 Top Load Washer
Frigidaire GLTF1670A Front Load Washer Logo
61 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Jason Harris
Jason Harris
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
