Question about Toro Garden
Toro Power Clear 418 ZE Snow Blower won't stay started
Using electric start. prime normally. have set at all available points of choke to try to start. If primed, starts immediately, but won't keep running. Seems to only run long enough to use up the fuel supplied in the priming.
    Top Expert:
  • Toro Master
  • 12,957 Answers
The main jet of your carb is clogged and you need to open carb and clear the obstruction - spray carb cleaner on the bolt that holds the gas container to bottom of carb - also spray all the innards along with any tube that protrudes into the gas can.
Then using air compressor blow the sucker out and reassemble. That should do it.
Posted on Feb 15, 2016
slohry
  • 87 Answers
SOURCE: Echo 260L no power, will start but not run
Check the insulator block for cracks and the 2 gaskets behind it. Make sure the gaskets are lined up properly.
Posted on Apr 10, 2009
  • 246 Answers
SOURCE: I have a Homelite Yard Broom gas blower that won't prime/stalls.
Hello sodevine69:
>>From your Description it Sounds like the Fuel Filter in the Tank Requires Changing, the Carburetor Metering Jet is Stuck, the Carburetor Filter/Screen is Restricted and Requires Cleaning/Replacing or the Carburetor Requires Cleaning.
>>The Following is a Basic Instruction File I made for Replacing the Fuel Lines and the Filter on Chain Saws and Trimmers. Any Input is Appreciated.
>>The Fuel Line is Pushed and Pulled (I Use Long Needle Nose Pliers) Through the Small Hole Until the Hose is Out the Fill Hole about a 1/2".
>>You can Also Use a Coat Hanger with a Small J at the End to Hook the Filter in the Tank and Pull the Filter and Hose (if Detached from the Carburetor) Out the Tank Fill Hole Enough to Replace the Filter.
>>Then Attach the Filter and Pull the Hose Back Until the Filter Lays at the Bottom of the Tank Just Below the Fill Hole (or so it is in the Bottom of the Tank and will Rest in the Fuel Mix when Turned at Common Angles the Unit May be Turned to During Operation.
>>**Hint: Use Plenty of Spray Lubrication at the Small Hole as you are Feeding in the Hose. It Slides Easier.**
>>The Following is a Basic Instruction File for Doing a Diagnostic on the Engine for this Problem. Any Input is Appreciated.
>>**Remove the Muffler and Make Sure the Exhaust Port is Clear.
>>If it is, then Try to Start the engine with the Muffler Off.
>>If it Starts and Runs Properly, then Clean the Spark Arrestor Screen in the Muffler or Replace the Muffler if Required.
>>The Following is a Basic File I Made for Cleaning Carburetors. Any Input is Appreciated. Even though the Carburetor Looks Clean, the Internal Passages May be Restricted with Varnish that Gas Causes to Build Up over Time.
>>Spray Cleaners Remove this Varnish in Layers, so Soaking is the Only Sure Way to Remove ALL this Varnish.
>>I have Found that Most People can Use a Breakdown/IPL and Disassemble the Carburetor Enough for Proper Cleaning.
>>Remove Any Adjustment Screws that Go Into the Carburetor Body. The Welch Plugs Do Not have to be Removed.
>>If you are Able to Remove and Disassemble the Carburetor and Keep the Gaskets Intact, then Usually these Gaskets can be Reused. The Only Parts you May Need to Replace are the Needle Valve and Metering Pump Diaphram.
>>The Metering Pump Diaphram is Under the Carburetor Plate with 4 Small Screws in it.
>>The Dowl on the Diaphram should Just Touch the Metering Jet Actuator Arm.
>>The Actuator Arm is Adjusted by Carefully Bending the Actuator Arm Up or Down to get the Correct Clearance.
>>If you Order a Kit, then Replace All the Old Components with the New Ones in the Kit even if the Old Parts Look Good.
>>Once Disassembled, then Soak the Carburetor Body and Parts in a 1 Gallon Can of Gunk Carburetor Cleaner Overnight. The Can has a Parts Tray Inside it for the Small Parts.
>>Once the Carburetor and Parts are in the Cleaner, you can Replace the Lid for Safety and to Prevent Accidental Spillage. Then Blow Out the Passages with Compressed Air.
>>***(Do Not Use High Pressure Air for the Zama Carburetors, they have Check Valves for the Primer and these are Usually Blown Out of the Carburetor if Not Careful. Allow the Zama Carburetor to Set on a Drip Pan and Dry)***.
>>****All the Carburetor Adjustments are the Same for Lawn Mower and Trimmers.
>>If the Main Air and Idle Air Mixture Screws are Side by Side on the Side of the Carburetor, then the Idle Air is Nearest the Engine.
>>****Turn the Idle Air and Main Air Mixture Screws In Until SNUG **Do Not Jam** Then Reverse Both Screws 1 1/2 Turns. Holding the Throttle Full Open, Start the Engine. Turn the Main Air Mixture Screw Clockwise Until Proper Revs are Obtained. Occasionally you May have to Turn this Counter Clockwise to Achieve the Proper Revs. Now Allow the Engine to Idle. Set the Engine Idle Screw (Not Idle Air) so the Engine will Stay Running if Required. Now Set the Idle Air Mixture Screw so there is No Hesitation when Throttling from Idle to Full Throttle. Reset the Engine Idle if Required.****
>>If you have Questions, Please Ask. The links above Provide Good Directions on Cleaning the Carburetor. Make sure you use an Compressed Air to Blow through all the Carburetor Passages to make sure they are Clear.
>>1- http://www.repairfaq.org/samnew/lmfaq/lmclctc.htm
>>2- http://www.cpdonline.com/692509.pdf .
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
Respectfully
jbridger (John)
Posted on May 13, 2009
SOURCE: toro recycler will start until primed gas is consumed.
I had similar problem and cleaned the spark plug and that seemed to have worked, but I think that may be a temporary fix because the engine still seems to be running unevenly. I feel that it must be a larger problem with the carb. If anyone can help this novice to adjust the carb or clean both carb and filter, or offer other solutions I would appreciate your assistance.
Posted on May 21, 2009
  • 10865 Answers
SOURCE: toro recycler will run until primed gas is consumed.
The problem is that the gas that sat in the carb all winter glazed it over and gummed it up. Begin by going to any auto parts store, like an aiutozone, and getting a bottle of carb. cleaner. Seafoam is one I use. Add it to your gas, one ounce per gallon of gas. Also, pick up a can of engine starting spray.
Remove the air filter and spray the engine starting spray into the air intake. Pull start the engine and give it additional squirts of engine starting spray until it runs smoothly.
Posted on May 30, 2009
SOURCE: toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
Posted on Jun 30, 2009
How to Start a Carbureted, Electric Start Outboard Motor?
didnt specify unit --generic answer--hook up fuel -prime unit with ignition system some have you push key in before starting to prime or choke --lift throttle to choke -or have auto choke and turn key to start
Oct 20, 2016 | Boating
Electric start does not work. how do i trouble shoot it?
Mine the electric cord had pulled out of the receptacle.on the blower so it was not working. I pulled it right out and reinstalled it It's ok now.
Do you have power coming to the blower or have you blown a GFI and it needs to be reset. Does the starter click or try to work? These are things that I have to know before we tear things apart.
If it buzzes it could need a gear replacement. on the starter itself.
Mar 03, 2015 | Toro Power Clear 418 ZE - Single Stage...
Will not start.but backfires..why?
Clean the spark plug, it might be dirty causing misfire.
Timing might be off, take to repair shop for this.
Feb 13, 2015 | Toro Power Clear 418 ZE - Single Stage...
Have toro 418 snow thrower prime it and starts but immediately stalls can only keep running if I keep pushing the primer button what's wrong
The fuel pickup tube in the carburetor is probably clogged. I don't know how handy you are, but you have to remove the carb, disassemble it and blow out all the orfices with compressed air and possibly run thin wires into the tubes and holes. Good Luck! the last time I had to do this was in the middle of a snowstorm!
Jan 28, 2015 | Toro Power Clear 418 ZE - Single Stage...
Cleaned the carb but now it leaks around bowl cover What is the needle valve on the side? I tried to clean it but the holes are still blocked tight. Is that normal ?
the gasket is not seated right . also the needle is above the float take the pin out that holds the float in clean it out put the float back in right make sure the needle seats right liftthe floa up and down to make sure it closes right , should not extend to far that is why it will stick on and leak fuel ,
Jan 19, 2015 | Toro Power Clear 418 ZE - Single Stage...
Procedure to start single stage electic start toro snow thrower
plug in Electric start. Push Choke to 'ON'. press Primer Bulb about 2 times. Turn Key to 'ON' Press Starter.
If you didn't run it completely dry of Gas last season I bet the Ethanol gas messed up your carburetor
Dec 15, 2014 | Toro Power Clear 621 ZE 21 163cc Single...
Control switch is broken how replace switch
they are not hard look at it real good you will see how it comes apart , this is easy
Mar 02, 2014 | Toro Power Clear 418 ZE - Single Stage...
Toro power clear 418 won't start
does it have good gas in it , clean it out if it is 2+2 mix put new mix most small snowblower are 2 stroke which takes gas oil mix , make sure you clean plug and are getting spark
Feb 18, 2014 | Toro Power Clear 418 ZE - Single Stage...
Garden Logo
1,779 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Roland W VanLue
Roland W VanLue
Are you a Toro Garden Expert? Answer questions, earn points and help others
