Question about Brother BRTPT65 PT-65 Label Maker Printer
Brother pt-110 wont feed or print - Brother BRTPT65 PT-65 Label Maker Printer
3 Suggested Answers
SOURCE: pt-110 problem
I have the same problem. There is a little arm attached to the base of the pinch roller. It's broken on mine causing the problem. Attempted to epoxy the part back together, did not work, part is too small where broken. Don't know if there is a replacement part. New P-Touch was $39.00 at Staples so I'll probably just buy a new one. You have to be pretty mechanically inclined to get the thing apart anyhow.
Dave
Posted on Sep 28, 2008
komguy
  • 2306 Answers
SOURCE: Tape on Brother PT-65 wraps on roller
If the end is already messed up you may need a new cartridge, if you can remove the tape and feed the end under the guide on the cartridge and re-install it should work properly again.
Posted on Sep 17, 2009
How do i feed
Sir/Madam
Go To Below official Brother Printer Page For Your problem, MANUAL FEED Brother
Hope It's resolve all Your HP Printer Problem,
Or
Still having Problem Then follow Us For Brother Printer Support
Feb 06, 2014 | Brother P-Touch PT-1880 Printer
Sep 15, 2009 | Brother PT-65 Personal P-Touch Electronic...
Brother P-Touch 1200 label printer doesn't feed whole label
Take out your cartridge and look at the end of the tape, it should be under the guide, the skinny bar, before going into your machine. Make sure you tuck it in under that bar and it should be OK.
Aug 28, 2009 | Brother P-Touch PT-1200 Label Printer
Brother laser printer wont print on cardstock My brother printer won't feed teh card stock paper. It used to work but now it won't feed it, normal paper works fine. Even if i nudge the card stock paper,...
If there printer is not able to print on card stock then check the recommend
card stock paper thickness, if the printer works with normal paper but not card stock then there is problem in the card stock and by using this paper may also damage the rollers on the printer and make the printer useless ...
Good luck...
Feb 09, 2009 | Brother MFC-5840CN All-In-One InkJet...
I have a Brothers home and hobby PT110 labelmaker. It has new batteries. I can type the words but the tape won't feed even though the labelmaker is making a sound as if it is about to print.
You have to make sure the new tape is snapped in and then put the back back on it. After its reassembled press CODE SPACE. This will feed through the tape. If the back of the P-touch is not on it will not work... Crazy but true :)
Dec 28, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
I have a Brothers Printer/Scanner.... I have not had a problem scanning until today. I can make a copy but cannot scan a copy and set it to file. wont scan i have a 110 brothers printer
check if the ip address of your computer changed...and see if you can print... if you cann't print... then its a network issue... if your ip address changed then its a network issue... if its connected via usb... then reinstall the scanner and see if that helps...
Dec 24, 2008 | Brother DCP-110C All-In-One InkJet Printer
Need help loading cartridge for brother label maker
when you have the label maker upside down...
place the cartridge so the WHITE 12mm ect sign is on top.
pull the tape out a bit and pull it up so that it stick out where the tape would print out of.
place the cover back on tightly and turn on..
push CODE, SPACE, it will feed though and you'll be all set.
Dec 08, 2008 | Brother BRTPT65 PT-65 Label Maker Printer
Brother PT-85
Make sure you have fresh batteries, It sounds like the batteries are low,
Lou
Aug 10, 2008 | Brother P-Touch 1180 Label Printer
Pt-110 problem
Dave
Jan 28, 2008 | Brother P-Touch 1180 Label Printer
Labeling system trouble-shooting
This is a duplicate post, click on the following like for the original: http://www.fixya.com/support/t133614-labeling_system_trouble_shooting
Feb 10, 2007 | Brother PT-65 Personal P-Touch Electronic...
Brother BRTPT65 PT-65 Label Maker Printer Logo
65 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
