Question about Altec Lansing VS3151 Computer Speakers
Altec Lansing Vs3151 Control Pod
My push button on my control pod broke where can I get a replacement part.
The green connector on the control pod broke. Where can I get a replacement? The orange and black connectors still work and everything else work.
Posted on Aug 03, 2009
Turn signal relay 2008 jeep location
There is no relay , controlled by integrated power module . Electronics !
Feb 12, 2016 | 2008 Jeep Grand Cherokee Laredo
Do u need fx4021 control pod
yes, please mail me on mrumax@yahoo.co.in
Sep 27, 2013 | Altec Lansing FX4021 Computer Speakers
No sync
Try getting a software update for i tunes, also it depends how old you i pod is. after a while my i pod didn't want to sync either. Maybe you need to buy a new charger.
Aug 27, 2012 | Altec Lansing inMotion iMV712 (576027)...
I am running windows xp on a desktop computer with a INT D945GNTLR motherboard which I believe has a built in audio for 5.1. The speakers are Altec Lansing VS3151. They worked fine for years but now I...
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar for any further volume control settings you will need to right click on the volume icon system select adjust volume
click start control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps you
Sep 10, 2011 | Altec Lansing VS3151 Computer Speakers
My altec lansing im7 stopped working during class
I am having the same problem. Did you ever figure it out??
Jul 28, 2009 | Altec Lansing inMotion iM7 (021986950806)...
The vinyl covering the speed control buttons gets hard in cold
There is no recall that Iam aware of. You have to replace the switches if they break.
Feb 01, 2009 | 1999 Ford Explorer
Altec lansing FX5051
I have Altec Lancing Fx5051 5.1 No doubt the Sound Quality is Awesome however, I had some Issues with the Speakers and the Power.. While Playing the Device .. Suddenly the Sounds become so Low that it becomes Difficult for any one to Listen.. but again after some Adjustment is Volume.. the Sounds Come back ... and this Things had to be Repetead every 2-3 minutes .....
I had Called up the Service Center Guys .. they asked me to Change the Power Supply to another point and Try ... I did but nothing worked ...
Now that I have Changed my entire Home with New Electrical Wires and Earthing Properly Fixed ... the Problem Still Persists ... But Now I see that the main Woofer is Not taking Power ... I dont Know wot is wrong ... Can you Please help me ... ...
Nov 08, 2008 | Altec Lansing MX5021 Computer Speakers
Altec Lansing VS3151 Computer Speakers Logo
389 people viewed this question
Top Altec Lansing Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Sharps s
Level 1 Expert
Are you an Altec Lansing Audio Player and Recorder Expert? Answer questions, earn points and help others
