Question about Acer Aspire 7720-6827 Notebook PC
I reinstalled wds vista home prem after pc crashed and need to install ac er software to get pc back to original factory condition its an aspire 7720-6827
Where do i find the auto run set up for laptop?
  • 33 Answers
In this case i think you need to restore it from a pre-made cd/DVD or image supplied with the laptop or created from laptop.
Posted on Dec 06, 2012
oblivion2k
  • 150 Answers
SOURCE: acer problem
You will need to see if ACER has the software in question for Vista. You can find this on acer.com in support > drivers
Posted on Feb 27, 2009
SOURCE: factory restore
if you can load into your current installation search for a program on your c:\ called D2D.exe it should be located within c:\Acer\ this will start a program if you click the top option it restores the factory settings.
Posted on Sep 19, 2008
  • 3 Answers
SOURCE: restore factory settings for aspire 5570
Try re install windows and then go to http://support.acer-euro.com/drivers/notebook/as_5570.html and you can find all the drivers there.
Posted on Jan 26, 2009
  • 52 Answers
SOURCE: acer aspire 6920 back to factory settings
Acer sent me these instructions.
The other way before Vista starts up is to tap ALT + F10 (at the same time repeatedly) when the computer is first switched on.. The window of opportunity is very small, so this may take a few attempts
Once you have tapped both the ALT and F10 repeatedly, you may see a screen showing:
“Edit Boot options for Microsoft Windows Vista”
If you see this, unfortunately, you have missed the window of opportunity, and you need to restart, and try again.
If you see this:
“Edit Boot options for Windows Setup” OR “Edit Boot options for Acer eRecovery”
Then it indicates that you have tapped the ALT + F10 correctly, and all you now need to do is press “Enter” and the Recovery program should load on your screen after a short pause..
In some cases, you may need to remove the battery (for notebooks only) and run the machine directly from the mains.
The Disk2Disk recovery feature allows you to recover the system without recovery CDs.
This will return your system to factory settings and will delete everything stored on the machine.
If possible we strongly advise backing up anything important on your machine before starting the recovery process.
Posted on Jul 12, 2009
  • 43 Answers
SOURCE: Acer Aspire 5100 back to factory settings
You may be able to hold F2 as you power up to open up the "setup" screen. There should be an option to restore to factory defaults on that screen.
Posted on Jan 12, 2010
How can I get a disk to install in a new hard drive for a Dell computer with Windows 7 Home Prem
Dell will often sell the disks if you did not make a back up before your HD crashed.
Oct 07, 2014 | Microsoft Windows 7 Home Premium 64BIT...
Recover to factory condition windows vista
To use this feature put the original windows disk into your pc/laptop and reboot. As soon as the reboot starts starts pressing F12. Choose the menu option that allows you to boot from a CD. VISTA will start and in the next few screens allow you to install to the original factory conditions.
Dec 25, 2013 | Microsoft Windows Vista Home Premium with...
Went to nvidia website to check on driver update and they want u to download their driver scanner witch i did, then it shows just about all drivers in laptop outdated and want u to purchase scanner
Instead of using the driver scanner you should go to the manual driver search which is right before that. From there you can manually find your driver and it will not ask you to purchase anything.
Another option is to go to the Acer website and get your drivers from there. You will just have to enter the model of your system. On Acer's support site you can download all the drivers for your system.
Jan 08, 2013 | Acer Aspire 7720-6827 Notebook PC
I had to reinstall vista on my MX8711 after a system crash - I used the OEM system re install disc, but the reinstall left out the GW-specific programs and PC documentation - also, I'm not sure if the...
I would recommend getting another System disk from your manufacturer as the one that you have may be outdated as to why those essential programs have been left out of the installation process.
Dec 19, 2009 | Gateway MX8711 Notebook
Acer laptop stuck on Aspire screen
i/run operatin disk take prompt comman and type chkdsk/rr 2-3 times it can be repair your system 2/ repair by operating disk if not work by two methode reinstal operating system.
Oct 14, 2009 | Acer Aspire 5500 5570-2609 Laptop
I am needing to reinstall the empoering technology software.
Use the three recovery discs you created the very first day you bought the machine and restore it back to its factory default
May 18, 2009 | Acer Aspire 4720 Notebook
Unable to reinstall DVD backups after HP SYSTEM RECOVERY failed
Code "purple" means you and your computer are done. It is an unrecoverable error that means you need a new system. However, I have found a couple of postings that claim to know a fix. I can not verify these methods, I do not own a HP or other type of prefab PC (custom is the only way to go). Anyway, here are the links, good luck.
http://h30434.www3.hp.com/psg/board/message?board.id=HardwareDPC&message.id=6115
http://forums.techguy.org/windows-nt-2000-xp/469752-code-purple-configuration-error-hp.html
http://forums.techguy.org/all-other-software/644163-code-purple-advice.html
May 16, 2009 | HP Computers & Internet
My Acer laptop just crashes randomly..i used to have vista, but once it started to crash on vista i installed XP thinking it would stop the crashes....it didnt. now i cant install Vista for some reason.....
Acer usually has a hidden partition which allows you to reinstall the OS back to factory setting.When you boot hold down the ALT + F10 button and it should boot into the recovery disk
Apr 27, 2009 | Acer Aspire 5610-4648 Notebook
Acer problem
Feb 27, 2009 | Acer Aspire 5315 Notebook
Wmp11
hi, uninstall the media player and reinstall a fresh copy, or try using some other media player like winamp, realplayer, or MM jukebox.. let me know
Feb 12, 2008 | Acer Aspire 5610-4648 Notebook
Acer Aspire 7720-6827 Notebook PC Logo
99 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
