Question about Bose Audio Players & Recorders
BOSE CENTER SPEAKER WON'T WORK
    Sergeant:
  • 256 Answers
Try a different center speaker on the unit to see if it will work, One that you no is good, If it doesn,t work then you no there is a problem with the unit,
Posted on Dec 06, 2012
4 Suggested Answers
  • 8 Answers
SOURCE: Want to connect non-bose speakers to a bose lifestyle system
this is possible, however not a very good idea.
Bose speakers are designed a little different than other brand speakers, the Equalizer built into the bose system will probably not sound amazing when you hook up your other speakers. Are you looking for more bass? cleaner highs?
if you want more bass, you could try doubling up your subs, if you want cleaner highs you could buy Bose Jewel Cube Speakers (purchased from a Bose Built-Invisible Dealer
Posted on Sep 12, 2009
dunnbiker
  • 8546 Answers
SOURCE: front bose speakers and bass module stopped puttimg put sound
If you're saying you hooked the Bose speakers directly to the Yamaha's amp instead of the prescribed way through their own bass module - they're cooked.
Posted on Dec 28, 2009
SOURCE: We have a Bose Lifestyle model 5 music center and it won't go into surround sound mode. It will play a CD and all 5 speakers work. Any suggestions??
Are you sure the red and white wires plugged into the audio output on your TV because I had the same problem and learned thats where you plug them into
Posted on Nov 06, 2012
Nov 06, 2012 | Bose Lifestyle Model 5 Music Center
Hi There, I have a Marantz SR7005 Receiver and Bose 901 Series VI speakers with the Bose equalizer. I'm struggling to figure out the best way to connect the Bose equalizer/speakers to the SR7005. ...
It sounds like you've read one of my many posts on 901 deployment in the AV world.
Functionally, what is the difference between one amp with 'x' channels or 'x' mono amps? Nothing. Pre-outs don't know or care what else an external amp does.
According to this link http://www.ecoustics.com/electronics/products/new/642968.html those amps are 2- and 5-channel, respectively.
There was a time when I had two bridged-mono Carver Cube atmps (at a real 400 watts) pushing one 901 each but that was big time overkill.
I now use a Carver AV-406 (functionally the same as your MM7055) with the 901 EQ in between the AV Receiver's front pre-outs and two 110-watt channels. Other channels on the AV-406 pull subwoofer and surround back duties. My AVR directly powers only the center and surround speakers.
The MM7025 would work for you.
Jul 07, 2011 | Marantz SR7005 Receiver
How can i bypass the stock amp in a 2000 pontiac grand prix with the bose speaker system in it with out taking the bose speaker's out?
you can't. the bose system is just that, a system. you need all the pieces for it to work. the head unit doesn't have any power and you need the amp to drive the speakers. also, bose is a proprietary system. only bose parts will work for it. so you can't buy any amp off the shelf and swap it out. if the amp is bad you need to buy a replacement bose amp or replace everything with a new head unit and speakers.
Apr 12, 2011 | Car Audio & Video
@I got a bose acoustmass 7 it has three inputs left right center,and three outputs left right center dont have paper work I need like a diagram or instructions on hooking it up please help.
you need to run the left speaker output from the amp to the left speaker input on the Bose, the right speaker output on the amp to the right speaker input on the Bose, the center channel output on the amp(assuming it has one), to the center channel input on the Bose...then the right output on the Bose , to the right Speaker..the Left output on the Bose to the left speaker...and finally the center channel output on the Bose to the center speaker
Jan 07, 2011 | Bose Acoustimass 5 III System
I accidently pulled the wires from our bose VS-10 center speaker and now when I reconnect, it doesn't work. Why?
Since there are only the two conductors it's not rocket science to reconenct them. Did you short them together and damage the amp?
Dec 25, 2010 | Bose VCS-10 Center Speaker
I have a Denon AVR 3805 receiver. It does not have a Main Amp in or a pre Amp out in the back. How do I properly hook up the Bose 901 equalizer to this receiver? I use the 901 speakers as surround...
By properly, you must mean WITH the Active EQ.
According to this picture, you're in luck BUT...
http://www.audioholics.com/reviews/receivers/denon-avr-3805/denon_AVR3805_rear_lg.jpg
(Short answer from personal experience.)
There is no way around this part. Get a separate power amp for the 901's if you want to use them in a multichannel way or alongside non-901 speakers. A good 100-wpc amp will do. (I like Carver)
Connect the Active EQ between the Front pre-outs and the amp input. Run speaker assignment, levels, etc and have fun.
Helpful Hint: If you don't have sufficient between-speaker room for proper reflection off the front wall you CAN turn the 901's around and you won't believe the amount of air these things push! I have actually felt it ten feet away after explosions or crashing ocean wave sounds. Now THAT is multi-media.
Oct 14, 2010 | Bose 901 VI Main / Stereo Speaker
Hi want to connect bose 901s with active equaliser to my pioneer sc-lx81
http://www.avland.co.uk/pioneer/sclx81/rearlrg.jpg
Oct 09, 2010 | Bose 901 VI Main / Stereo Speaker
Hey i just bought a pair of bose 901's and was wondering what system would provide enough power but still cheap and mp3 compatable???
Keeping in mind that the 901's and multichannel recievers won't work unless you use an outboard amp for them, that should open up the choices pretty wide. But your MP3-compatible AVR MUST have front channel pre-outs. Any solid 100 watt x 2channel amp will drive them.
Sep 23, 2010 | Bose 901 VI Main / Stereo Speaker
Front bose speakers and bass module stopped puttimg put sound
Dec 23, 2008 | Bose Lifestyle 12 System
Additional speakers for 321 system
No. You would need some kind of audio out connections on the back of the media center. The only audio outs it has are the
Acoustimass® Module – SPDIF connector.
Unless you were to hook up an amp before the Bose media center. In other words, you could run your TV to another amp's line in. You would hook up additional speakers to this other amp, then run audio line outs to the line in of your Bose media center. Some stereo amps have a line out or record/tape out, it is from here that you would run the cables to your Bose media center line ins. The disadvantage to doing it this way is you would have to plug all your media devices (dvd, tv, etc) into this amp first and your Bose remote wouldn't let you switch between devices. If your media devices you have offer digital audio, then you would want an amp that also offers a digital out for the best sound. Otherwise you will end up with analog out from this amp to the Bose media center and thus lose any of the digital signal information like surround information. So there isn't much point in doing this. If your gonna get an amp that has all the digital in's and out's, you might as well just use it with new speakers and forget the Bose system you have.
Jun 06, 2008 | Bose (321GS) System
148 people viewed this question
Top Bose Audio Players & Recorders Experts
Electro Med Services...
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
