Question about Pro RX65 Radar Detector
Problem to turn on my RX65
good morning,
We have used, since September 08 (our purchasing period), around 3 times per month our RX65 for medium travels without problem, but since the middle of November 08, impossible to turn on this radar detector.
firstly, except the green light onto the connector, nothing appended (no starting test) when we connect it to the car. (This have been check on 5 cars so we conclude that it's not an alimentation problem (fuse on these cars are good too)
Nowadays, nothing append (green light is off too)
before to return it to BELTRONICS I would like to check if something can be done in FRANCE to solve this problem
Please help me
best regard
  • 134 Answers
Obviously you have pressed the power button on your RX65 in order to try to power it up since you mention that the green light on the SmartCord comes on. Here is one possible solution, which resolves any stored user settings which might have become corrupted due to power fluctuations:
First, press the power button so that the radar detector is turned off (green light is off). Then hold down the two buttons used for programming and, while holding these programming buttons down, press the power button. Release all three buttons once you see "RESET" displayed on the RX65's display. Your RX65 has now restored all factory default settings from a separate area of programmed memory, and this (hopefully) will restore your RX65 to proper operation.
Posted on Mar 17, 2009
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
How do you adjust valves on a 2006 3.5L V6 Toyota Avalon?
There is a Toyota Technical Service Bulletin issued for this:-
T-SB-0291-08 September 11, 2008 2GR-FE Valve Timing
Procedure Service Category Engine/Hybrid System Section Engine Mechanical Market USA Applicability YEAR(S) MODEL(S) ADDITIONAL INFORMATION 2005 - 2009 Avalon 2007 - 2009 Camry VDS(s): BK46K 2008 - 2009 Highlander 2006 - 2009 RAV4 Engine(s): 2GR VDS(s): BK31V, BK32V, BK33V, BK34V, ZK31V, ZK32V, ZK33V, ZK34V, ZK35V 2007 - 2009 Sienna Introduction This service bulletin provides information regarding valve timing inspection and service guidelines for vehicles equipped with 2GR-FE engines. © 2008 Toyota Motor Sales, USA Page 1 of 5 T-SB-0291-08 September 11, 2008 Page 2 of 5 2GR-FE Valve Timing Procedure Introduction (Continued) Figure 1. 3 2 1 5 9 8 7 6 4 1 RH Bank Intake Camshaft Timing Gear 2 RH Bank Exhaust Camshaft Timing Gear 3 RH Bank No. 2 Timing Chain 4 Crankshaft 5 Idler Gear 6 Timing Chain 7 LH Bank No. 2 Timing Chain 8 LH Bank Exhaust Camshaft Timing Gear 9 LH Bank Intake Camshaft Timing Gear Warranty Information OP CODE DESCRIPTION TIME OFP T1 T2 N/A Not Applicable to Warranty © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 3 of 5 2GR-FE Valve Timing Procedure Inspection 1. Set the No. 1 cylinder to TDC/compression. A. Set the timing mark to 0 on the timing chain cover by rotating the crankshaft clockwise. B. Verify the timing marks on the camshaft timing gears are in general alignment with the timing marks of the camshaft bearing cap: TIMING MARK IDENTIFICATION CYLINDER BANK INTAKE GEAR MARK EXHAUST GEAR MARK RH Bank (Bank 1) Small Mark Single Line LH Bank (Bank 2) Large Mark Double Line HINT When the engine is correctly timed, the timing marks will NOT perfectly align. Figure 2. Figure 3. RH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 4. RH Bank Intake Camshaft Timing Gear 2 1 1 Bearing Cap Timing Mark 2 Gear Timing Mark © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 4 of 5 2GR-FE Valve Timing Procedure Inspection (Continued) Figure 5. LH Bank Intake Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark Figure 6. LH Bank Exhaust Camshaft Timing Gear 1 2 1 Bearing Cap Timing Mark 2 Gear Timing Mark HINT If the timing marks appear vastly out of alignment, turn the crankshaft one revolution (360 ) clockwise and note the position of the timing marks. Component Removal Guidelines 1. If engine disassembly is required that involves removing the camshafts or timing gears, set the #1 cylinder to TDC compression, wipe away any oil, and mark the following items in relation to each other prior to disassembly: • Timing gears • Timing chain • Timing chain No. 2 NOTE This relationship MUST be maintained. The intake gear is timed in relation to the crankshaft via the timing chain; the exhaust gear is timed in relation to the intake gear via the No. 2 timing chain. © 2008 Toyota Motor Sales, USA T-SB-0291-08 September 11, 2008 Page 5 of 5 2GR-FE Valve Timing Procedure Component Removal Guidelines (Continued) 2. If NEW camshaft timing gears or the No. 2 timing chain are being installed, the two yellow links on the No. 2 timing chain can be used to ensure correct relationship between the intake timing gear and the exhaust timing gear. Figure 7. 1 1 Yellow Link A. Align the paint mark on the timing chain with the intake gear timing mark (to ensure the intake gear is correctly timed to the crankshaft). Figure 8. RH Bank and LH Bank 3 3 4 3 3 4 5 4 5 4 1 2 1 RH Bank 2 LH Bank 3 Yellow Link 4 Gear Timing Mark 5 Timing Chain Paint Mark B. Align the two yellow links on the No. 2 timing chain to the timing marks on
May 04, 2015 | 2006 Toyota Avalon XLS
I have the B60 model. It has been wonderful from day one and then...today...I made 2 cups this morning, went back about 2:00 to make another and it was off. Hummm...so I tried to turn it on and it will...
Try the following steps to reset the processor:
1. Simultaneously press and release ?small mug? and ?medium mug?. Immediately afterward press ?menu? 3 times. You should see a time 6:09 (or similar) on your screen.
2. Press ?menu? once. Your LCD screen should say Brew 0:00.
3. Press and hold ?medium mug?. While holding ?medium mug? press and release ?menu?. Immediately after releasing ?menu? (while still holding ?medium mug?) press ?small mug?. Release ?small mug? and ?medium mug? at the same time. This entire thing needs to be done very quickly.
4. Unplug the machine (do not turn it off). Wait for 3 minutes or so. Plug it back in, turn it on and follow the instructions for priming.
Jan 05, 2011 | Keurig B60 Coffee Maker
I have the same problem since 1 year. getting worse every months.
its more than likely going to be the camshaft dephaser, this is quite a costly job as it requires replacing along with the cambelt and auxillary belt, its a common fault
Aug 10, 2009 | 2004 Renault 181
I have this same problem since my purchase last september 08.
Do check if the printer is in sleep mode,if yes turn it off and restart you printer again.
Jul 12, 2009 | HP Photosmart 4180 All-in-One Printer
Calculate Quarters between any two dates
not sure if this is what you are after entirely but should at least help you out some what
=DATEDIF(A3,C3,"m")/3
As you said you cant just divide by 3 but I have divided the formula by 3 to see how many 3 months will go into the output you could maybe have another formula to divide it by 2 to see if it will divide by 2 to see if you get a whole number or not, if you do then you can just return the first part before the dot ( using split function ) and if the value is less then 1 then obviously the 3 months has not passed between the 2 dates
May 09, 2009 | Microsoft Office Excel 2003 for PC
My Kenwood SB300 Smothie maker blade won't whizz around
Hi. Go to http://www.kenwood.co.uk/Customer-Service/ and hopefully that will get you headed in the right direction!
Mar 10, 2009 | Blenders
No audio
Hi everyone,
Bel/Escort now uses a special and proprietary "high temp" speaker which resolves issues of speakers blowing due to high ambient temperatures or heat which builds up within the speaker when it is alerting for extended periods of time. If your RX65 is in warranty and you can make a photocopy of your sales receipt, then great! All you have to pay is shipping to Bel. Bell will replace the speaker with the new version, flash your RX65 with whatever the latest firmware is, and calibrate and test your RX65 too. So, all of this is peachy if your RX65 is under warranty.
If your RX65 is out-of-warranty or if it doesn't have a serial number or was bought from a non-authorized dealer, then the service charge as I recall is $80. Thats not bad since your RD will come back working like brand new.
A note about the speakers: They are made by PUI, but the speakers are proprietary to Bel/Escort. Thus you can not buy them from any source -- not even direct from PUI.
Dec 15, 2008 | Pro RX65 Radar Detector
Service needed
The internal self-calibration procedure has repeatedly failed, causing your RX65 to display the Service Required message. You need to send it to Bel for repair.
Dec 13, 2008 | Pro RX65 Radar Detector
Bel RX65 not working properly
Regarding the problem of the unit turning on for a second, then turning off after you plug it in....
Plug it in and hold the power button down for 5 seconds. This resets the unit. The unit will still turn off after this however. After that, push the power button on again for one second and it should remain on. Good Luck!
Jan 12, 2008 | Pro RX65 Radar Detector
Pro RX65 Radar Detector Logo
317 people viewed this question
Top Beltronics Vehicle Parts & Accessories Experts
John Nolan
Steve
Jerry Greenberg
Jerry Greenberg
Are you a Beltronics Vehicle Part and Accessory Expert? Answer questions, earn points and help others
