Where can I find and download a Luxpro psp511 thermostat user manual?
I simply want to clear the programming because the furnace will randomly change to 60 degrees, and the house cools down. I think a previous tenant must have programmed something into it, and I just want to cancel any programming that may have been entered. Luxpro's website is utterly useless.
tatunka
  • 85 Answers
SOURCE: i can't program my thermostat
use the mode button till program shows up then adjust temp with arrows and hit set
Posted on Nov 14, 2008
  • 85 Answers
SOURCE: Good morning I have a honeywell
Mebnme, is right, manually setting your therm and holding hold, will override any pre-setting program. Also go to honeywell website, order a manual and program your therm yourself, what model do you have?
Posted on Dec 06, 2008
  • 115 Answers
SOURCE: I have my thermostat set
Defective thermostat, If cooler air strikes the thermostat, this will set off the heat to come on.
Posted on Apr 01, 2011
SOURCE: My Luxpro psp511 ca is locked and I don't know how
to unlock/lock the instruction sheet says hit the following sequence of keys - up - down - next - hold - rotary dial - press software reset. The only problem is they don't say what to do with the rotary dial? Turn it which way, how far?
Posted on Nov 03, 2011
rayname
  • 70 Answers
SOURCE: Goes to 60 degrees
check the back up heat coil or emergency heat available heat pumps have a defrost which need backup heat the three way valve outside will change position indoor coil will warm up to thaw ice
Posted on Jan 04, 2009
I have a comfort furnace that change to celsius somehow HELP
the change of the denomination ( F to C ) will not affect the performance of the furnace
the thermostat still operates regardless of what is on the reading
0 degrees C is still 32 F and is still the freezing point of water
and 100 C is still 212F or the boiling point of water and a thermostat still works between those ranges
read you user manual as to how to change the read out back to F readings
Dec 17, 2016 | Heating & Cooling
How do I unlock it so I can program it? There is a padlock icon in the display,
Since we aren't the psychic hotline and you didn't give us a model, you get to find your own answer. EVER HEARD OF GOOGLE????
LuxPro Digital Thermostat manual
Google
Aug 08, 2016 | LuxPro Digital Thermostat
What filter is in the thermostat
When the change filter indicator comes on, it is referring to the filter in your furnace. The thermostat itself does not have a filter.
May 08, 2014 | LuxPro PSP711TS Touch Screen Programmable...
How do I change my luxpro psd111 thermostat to display temperature back to farenheit from Celsius?
On the Luxpro PSD111, Farenheit or Celcius are selected using the Jumper Switch J2 on the rear of the unit's circuit board:
Open = Celcius
Closed = Farenheit
Jan 20, 2014 | Cars & Trucks
TO LOCK THE KEYPAD: Start with the System Mode switch in either the
HEAT or COOL positions, and the Set Slide switch in the RUN position.
Perform a single press of each button, in the following sequence: NEXT,
NEXT, NEXT, HOLD.
TO UNLOCK THE KEYPAD: Start with the System Mode switch in either
the HEAT or COOL positions, and the Set Slide switch in the RUN position.
NEXT, NEXT, HOLD. The padlock should no longer be present, with the
thermostat now unlocked. If the padlock is still on the screen, please try
to enter the 4-button sequence again.
Jun 01, 2011 | Heating & Cooling
If i am away for any length of time, do i put the temp on vacation? does the water still get warm?
Since you didn't provide the brand & model of the thermostat, only generic help can be provided.
Most furnaces that run on oil or gas, make hot water all the time, 24 / 7 - winter, summer and everything between so to speak. They are controlled by an aquastat that may be set for any value between 140 - 180 degrees F. This is called "hot start" - simply because when the thermostat is set to a temperature higher than the room (turning heat ON), the water is already hot in the furnace, and is circulated immediately. If it was a "cold start", you'd have to wait for the water in the furnace to heat up from room temperature. This would substantially increase the amount of time it would take to heat the room.
Generally, the "vacation mode" simply halts the program from running. If your thermostat changes temperatures several times during the day / night, it will simply hold the lowest temperature - or a predetermined temperature built in - or chosen by you. You'll need to consult your manual to determine just how your thermostat handles the vacation mode setting. Post again if you can't find the manual - but tell us what brand and model it is.
I hop ethis helps - good luck!
Many heating thermostats don't allow for setting a temperature below 45 degrees F so freeze ups shouldn't be a problem.
Sep 30, 2010 | Heating & Cooling
I have an goodman model gsc130241ae unit will not
Hello Does the thermostat have a display?Check emergency wall switch and curcit breaker all on.Fan on should at least run if power.
Mar 31, 2010 | Goodman CLQ36AR49 Air Conditioner
HI i HAVE A THERMOSTAT ABOUT 10 TO 12 YEARS OLD I NEED A MANUAL
most user manuals are availble online, honeywell, white rodgers etc. do a search for the model #
Jul 11, 2009 | Heating & Cooling
Heating & Cooling Logo
613 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
