Question about Toshiba Televison & Video
My Toshiba 32RV753 was fine. then all of a sudden the picture went black and the green light started to flash. I get my picture through cable , but I think its the T.V. as the light remained constant
My son-in Law said something about it being a Lamp. there is no lamp mentioned in the instruction booklet. What is this lamp? Where is it? and is it covered by Dom gen Insurance? Thank you.
techman
  • 3130 Answers
SOURCE: Lamp Light Red - No Screen Image
It could be the a problem with the lamp ballist circuit, or just a bad lamp socket, or simply a bad lamp. The only way to tell is to call out a servicer as that would be alot less expensive then to get a new lamp and then that not be the problem. These problems can be a little hair pulling at times, thats why i have no hair left!! LOL Good Luck
Posted on Mar 21, 2007
Shuttle83
  • 1139 Answers
SOURCE: TOSHIBA 62HM15A NO PICTURE
Have you tried checking the socket to make sure there is voltage present and that the contacts are making connection with the bulb. Sometimes melted plastic blocks the connectivity of the contacts of the bulb with the contacts of the socket. Use a voltmeter to check for the voltage on the socket contacts.
I hope this helps,
Shuttle83
Posted on Dec 21, 2007
ginko
  • 19396 Answers
SOURCE: Green light flashing-tv will not reset-no picture no sound
When TV does not start, and sometimes you hear a clicking noise, that means that the TV is on protect mode.
Try first leaving the TV power cord unplugged for some times, let say one hour or so.
Also ensure that the fault is not coming from a faulty receiver box sending bad signal, check if you get same problem with no receiver box or dvd connected.
If that does not work, and you keep having a flashing led on front of the TV, and tv turning off by itself after a while, that indicates a fault condition.
The flashing light indicates a diagnostic state called protection.
When the TV goes on protection there are only two possible reasons.
1The internal circuits are jammed because of electrostatic charges accumulating on capacitors, or because of a wrong voltage read by the main chip on your monitor controller board. this started the protection circuit.
2 The protection circuit detected a wrong voltage or abroken contact, identified an internal fault and kicked in , startingthe flashing light.
If you are in situation one, then theTV will reset just unplugging power cord for one or two hours,sometimes even minutes.
If you are in situation 2 , then there is an internal fault.
Common faults that can occur are a blown capacitor on power board, a convergence IC has blown, or a fault on Digital board.
Check also the video cable or any external connection cable, if the cable is shorting, or the connector is bad, you can get same flashing state because of the video cable.
If under warranty contact the manufacturer ringing the number on the user manual
If you want to repair at your own expenses, just locate any good qualified repairer.
Posted on Apr 21, 2009
  • 3 Answers
SOURCE: I have a Samsung TV # HLP6163WX/XAA. A loud
I also have a Samsung HLP6163W 61in TV,had the same problem had to replace the color wheel. Went on youtube showed us how to do it our self. Saved a lot of money very easy. Good luck!
Posted on Jan 19, 2010
welcomejee
  • 10594 Answers
SOURCE: Suddenly turned off without warning Sony KDS-50A2000
Symptom shows tv needs lamp replacement as existing lamp is reaching to end of its working life and causing that problem.
If you have not replaced lamp in last 2-3 years, replace it to fix the tv issue. I can explain why tv shuts down itself and turns back on.
I do not agree with info provided about bulged capacitors in power supply so please do not take off back of tv unnecessarily.
Lamp replacement procedure would be written in user manual and let me know if you need to download manual copy.
Thanks.
Posted on Jul 23, 2010
No picture and green light flashes rapidly!!
Disconnect cam, restart computer, plug back in.
Nov 15, 2012 | Logitech C120 Webcam - Black
Our Hitachi Plasma TV suddenly went black and the indicator light started to flash green. We turned it off at the wall and back on. The screen flashed green, went black again and the indicator light...
If you want it fixed, you'll have to take it to a real tech. If you read this garbage you'll probably end up spending more that the tv is worthed in the long run to fix it.
Nov 02, 2010 | Televison & Video
No picture, siren type noise as restarting
My Toshiba dlp 62hm116 was used for 3 months then stored for 2 years, I turned it on yesterday and it makes a loud grinding noise which I think is probably from the exhaust fan area and the picture is black except white at both vertical sides. It worked fine the last time I used it 2 years ago. Any ideas?
Jan 13, 2010 | Toshiba 62HM95 62" DLP HDTV
Flashing green light on toshiba 2877db and wont switch on
i have a old toshiba 2877db tv it was working great then it just went off with a green light flashing on the on/off button but no picture and no sound can you please help
Nov 10, 2009 | GE 13GP243 TV
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
SUPER DARK SCREEN, BLACK PICTURES
I have seen this several time the lens cable can cause this issue it could also be the back light or the LCD I repair these all the time If you do not fill comfortable replacing the parts you can go to www.digitalcamrepair.com if you need further assistance.
Oct 02, 2008 | Casio Exilim EXZ75 Digital Camera
No picture
Hav 50 inch lg no pic but got sound wtf how do i fix it an there r 5 flashes b4 green light stayes on at the start
Apr 10, 2008 | LG 42LC2D 42 in. LCD HDTV
Toshiba Plasma TV Green and Pink (Diffusion?) Problem
I could be wrong but sounds like your plasma display is going bad. What is your model number?
Dec 28, 2007 | Toshiba 42HP66 42 in. LCD Television
Televison & Video Logo
27 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
