Question about 2wire Computers & Internet
I have an AT&T Uverse provide 2Wire 3801HGV
I have a 2wire 3801HGV router and I just bought a panasonic viera tv and my tv connects to my wi-fi but it disconnects within three seconds, i bought this tv because i can connect it to the internet but i am having trouble making it work
JSPCEXPRESS
  • 178 Answers
SOURCE: 2wire 2700 not connecting to internet
Make sure you have DSL filters installed contact me if you need any help
Posted on Feb 11, 2008
One Piece
  • 53 Answers
SOURCE: Connecting a netgear wireless router to a 2wire
before you connect the netgear router to your 2wire modem, you have to get the modem configured first. you did not include the firmware version of your modem (firmware version is found at the UI, go to gateway.2wire.net, click on the system icon.) for firmware version less than 3.7, go to homeportal/management, click on configure services, uncheck enable routing, then click on submit. for version 3.7 or higher, go to homeportal/management, click on configure under broadband link, put a dot in disable pvc search, set VPI to 0 & VCI to 35, the connection type box should be direct IP, then click on submit. then go to configure services, uncheck enable routing box, then click submit. you will notice the broadband link on the 2wire modem turn orange/amber, then you have successfully set the modem to bridged mode. that way you can now connect the router according to manufacturer's instructions (or just read the manual for the netgear router....)
Posted on Apr 03, 2008
serra_baby
  • 144 Answers
SOURCE: win98, Linksys USB Adapter, 2wire router... no internet
hello!
try to uninstall/remove the old driver and reinstal the latest driver of your linksys usb adapter. you can download it from the linksys website.
check again if you can get a wireless connection from the router to your 98pc. if not try to change the wireless channel of the 2wire to channel 1 and configure the wireless security again using the linksys usb wireless utility
if you still cant get a connection try to manually assign this ip address on the 98pc then check connection afterward.
IP add: 192.168.0.5
subnet mask:255.255.255.0
gateway:192.168.0.1
dns: dns number of the 2wire router
if you still cant get a connection after this try to install the wireless usb adapter to a diff computer to further isolate the problem.
Posted on May 08, 2008
marked
  • 6487 Answers
SOURCE: CAN A 2WIRE DSL ROUTER WORK WITH A CABLE INTERNET CONEECTION
The 2wire dsl modem/router cannot be use with a another cable modem , since this 2wire device is also a modem/router and its made for the DSL conenction that's why it wont work with Cox cable, the best thing that you can do is to ask Cox to give a wireless modem/router like this 2wire so you can still use the wireless connection of your computer..
Hope that helps..........
Posted on Sep 06, 2008
  • 17 Answers
SOURCE: Can I use 2WIRE 2701HG-B router in COX internet connection
No. A router has 2 main interface types WAN (for the internet connection side, and LAN (for the home network side) the 'LAN' side often has up to 4 ports and wireless connectivity for the home network.
The most common routers available at electronics retail use a CAT-5 connection for the WAN ports and the LAN ports. Your DSL modem/router uses a phone line input for it's WAN port, which uses a signal type that is incompatible with the cable modem output.
If COX doesn't offer a router with the cable modem package, you can go and purchase and common brand of home networking router, and attach it to the output of the cable modem.
Posted on Feb 28, 2009
When I use the wi-fi connection with the LAN cable provided and run the connection test, all of the tests are successful except for the Viera connection. It is saying the connection failed 006. How do I...
Viera has a set-top box in the TV and the lan wifi router can be connected to cable plant for internet. TV can also send out programs on the set-top box to other wifi receivers. Error code 006 is server failed, Panasonic had a fix on jan11, 2012.
Feb 11, 2012 | Computers & Internet
How to setting the wi fi
hello, try this things ok
WPS stand for Wi-Fi Protected Set-up . According yo Wikipedia "The goal of the WPS protocol is to simplify the process of configuring security on wireless network, If your 2Wire router is equiped with that function it would be the BIG button on the bottom front of your router Look at this advertisement from 2Wire http://2wire.com/movies/pages/112.swf
im sure in can help you.
Sep 02, 2011 | 2wire Wireless-G 802.11g ADSL Gateway
Can't get tv to connect to new wireless modem, but everything else did connect
What is the model no of your 2wire wireless modem not all 2wire wireless modem can support cable tv might as well contact you cable service provider
just feel free to add comment if you have furthur queries:
can also call: AT&T ' Uverse
Call +1 800.288.2020
if your under the uverse service of AT&T
or try going to this site for more 2wire infomation
http://support.2wire.com/
Aug 12, 2011 | 2wire (2701HG-B) Wireless Router
I am trying to set up my hp printer and I am trying to find the wps button on my 2wire router that the set screen is telling me to press. But I don't see one on it. Does 2wire support WPS, what ever...
Hello pbufordjr,
Aug 04, 2011 | 2wire (2701HG-B) Wireless Router
My iphone keeps dropping the "password" for my 2wire router. Then anytime I do something that requires the router to do some things it shows that Im NOT connect to my Wi-Fi in my house. How...
first check for any computer that is connected to you modem.
try to access your modem gui or software
since you have a 2wire modem go to the wireless setting page
then configure your wireless settings
you can call your isp for the correct wireless setting configuration
May 27, 2011 | 2wire (2701HG-B) Wireless Router
Trying to hook up DSI to AT&T 2701HG-B gateway to make it wireless
hi,
So you want to connect your Nintendo DSI to your 2wire modem.
Here are the steps for connecting you DSI wirelessly:
1. First you need to realize that the game console the requirements for the wireless password should be WEP.
2. Open the Nintendo DS setup Utility
3. Select the Nintendo Wi-Fi Connection Settings
4. on the next page just click on the search for an access point.
5. then click on your wireless name.
(when you still using the default name for your 2wire it will be 2wirexxx "XXX last 3 numbers of the serial number of the 2wire modem")
6. when it is asking for the wep key it is the 10 numbers under the barcode of your 2wire modem.
7. Select No under Auto-obtain IP Adress.
8. click Save settings.
this is the steps on connecting your DSI for wireless connection.
If this doesnt work call At&t for connecting your DSI.
Thank you for choosing FIXYA.
Mar 04, 2011 | 2wire 2700HG-B Router (2700HGB)
Have ATT Uverse & it always drops the internet connection. I reset the main 2wire box weekly. The little router by my desktop is the problem - I have to disconnect & reconnect several times per...
check with 2wire website for a newer firmware version. if you are able to update to a newer version and still have problems, then your router is on its way out.
Aug 24, 2010 | 2wire (1000-400108-001) Router
I have an AT&T Uverse provided 2Wire 3800HG-B gateway in the basement. My desktop PC is on the 2nd floor and connects to the internet at 11Mbps when the TV is not on. When we turn the HDTV on, we lose...
Turned on the TV, but not the Uverse box and still lost the internet. Determined that it was the Panasonic Home Theater wireless speakers which operate at 2.4 GHz causing the interference. Next step is contacting Panasonic to see if they have a solution for that issue.
Oct 02, 2009 | 2wire (1000-400108-001) Router
I don't know how to configure my 2wire 2700HG-B wireless, I need to connect my ipod. can someone help me to set them up?
hi there, first is you need to know the wireless settings of the 2wire first, the channel, SSID and the encryption.
once wireless settings are verified then you may try to go to the IPOD, go to settings/wi-fi/ then choose the network there/ try to connect to your network/if it will ask you for a network key, input that as well/ try to connect and you should be connected now.
Jun 26, 2009 | 2wire 2700HG-B Router (2700HGB)
Computers & Internet Logo
686 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
