Question about Gateway 4530GZ Notebook
No display The power button will light but no display
  • 4 more comments
  • Anonymous Feb 02, 2009
    I have the same probs I fitted new 1gb ram underneath the keybd & realized no more display on reboot. Help (TOSHIBA M50-164 EQUIUM )
  • guardian95 Feb 03, 2009
    On LCD light is the battery. No display screen. No external display. I hear the hard drive spinning but can't tell how far it gets into starting Windows.
  • B Christopher Feb 28, 2009
    My HP dv9308nr laptop has no display. When I press the power button powers on and I hear the fan and hard drive. I replaced the LCD display inverter and the motherboard. And still nothing. I connected to an external monitor and I get display for a few minutes then it goes off.
  • johnny0110 Mar 30, 2009
    What is boz of monitor???
    I have a Gateway 4530GZ and the LCD panel is fine for a while and then it goes black. If I touch the little pin at the top right corner that controls the screen going on and off when you close the lid, it pops back on for a few seconds and then it goes off again. I dont think it has anything to do with a bad connection because it will do it if I leave it setting without touching it at all. I had a tech look at it and could not find anything wrong with it. Any ideas???? THANKS !!!
  • B Christopher May 11, 2010
    Would the bad lcd display on my laptop cause the display not to appear on an external monitor?
    Problem Solver:
  • 82 Answers
This is boz of monitor is faulty.............try repaiirng at the service center..............Sameeraryan
Posted on Jan 14, 2009
I am reposting this question with more detail in hopes that someone can help me! I have Lenovo Y550 that has been sitting for several months without being used. It was working fine the last time it was...
You may need to remove all the power from the device including the CMOS Battery. As well try using an external display to see if there is any display.
Oct 27, 2013 | Lenovo Y550 Notebook
Power on no display, light flash on shortcut button
check the monitor power adaptor i fits properly connects or not.
if its connects properly
(or)
if cpu led indicator is on but no display, then just press the restart button it works
Oct 20, 2013 | Fujitsu Computers & Internet
Not display monitor, only lights and fan is on
i think its a motherboard problem you have to change it
Jan 18, 2013 | ASUS Computers & Internet
Cannot turn on my laptop only the start button light turns on but no screen display and a few noises help
This is only the first of many things you may need to do to determine the fault. But it is a process for determining the exact cause.
Make sure the ac adapter is correctly plugged into the notebook and into the power cord.
If everything is plugged in correctly and it still will not power on, follow these steps to complete a 'power reset' of the notebook.
  1. Unplug the ac adapter. Keep ac adapter unplugged.
  2. Remove the battery and keep the battery unplugged.
  3. Hold the power button down for 15-20 seconds. (Nothing will appear on the display and none of the lights will light up.)
  4. Release the power button and plug in the ac adapter ONLY. (Please note that a power indicator light should be lit on the ac adapter when it is plugged in).
  5. Normally power on the notebook.
  6. If the unit does not power on, remove the ac adapter and insert the battery into the system.
  7. Plug the ac adapter back into the system, the battery charging indicator light will light up.
    If the battery charging indicator light does not light up, the ac adapter may not be providing proper power to the unit, and may need to be replaced.
May 15, 2011 | Acer Aspire 5500 5570-2609 Laptop
Inspiron 1150 lights up but no display at startup
disconnect all power cable, battery, then press the power botton for 1min. try reset the RAM, then connect power cable and battery and press fn & power button if still it doesn't have any display then you need to change the m/b
Dec 18, 2009 | Dell Inspiron 1150 Notebook
MY toshiba satellite 2430 CAN NOT POWER UP. BUT IT ALL THE LIGHT IS ON WHEN I SWITCH ON THE DC POWER SUPPLY SWITCH. WHAT IS THE PROBLEM? HELP.
remove the battery and remove the power adaptor ... press and hold the power button in the ON position and count to 20.
attach the AC adaptor only and press the power button ...this should fix the issue ... then re connect the battery.
if this does not work then add a external monitor .. if it lights up then hit the
Fn + F5 keys
Display modes
Fn + This hot key cycles through the power-on
display mode options.
The display mode options are:
Built-in display panel only, Built-in display panel and
external monitor simultaneously, External monitor only.
Fn + This hot key cycles through the power-on display options.
The display modes are:
❖ Built-in display panel only
❖ Built-in display panel and external
❖ External monitor only
video device simultaneously
❖ External video device only
Oct 07, 2009 | Toshiba Satellite 2430 Notebook
3 Lights on display panel Dell D505
YOU HAVE A FAULTY BIOS.I HAD THE SAME PROBLEM WITH MY DELL INSPIRON 5150.REFLASHING THE BIOS SOLVED THE PROBLEM.GOOD LUCK.
Sep 11, 2009 | Dell Latitude D600 Notebook
Toshiba M45, no display, no boot, display button lights up about 3 seconds.
I have same problem with L30/L35 mainboard
did u find solution for your problem?
/o\
May 18, 2009 | Toshiba Satellite M45-S2692 Notebook
No display
hi..the reason for ur problem is the
display button.There is a display button
available on the top next to the power button.
Make sure that the display button is turned on,
if ur display button is turned off,ur displayscreen
doesn't appear.It will look black.
check this out..
thank u..
Feb 07, 2009 | Toshiba Portege 3440CT Notebook
No boot No fan noise no display but lights come on
Somethings has happened to your motherboard, CPU and/or hard drive somewhere along the line if it wont power up when you hit the power button and this would explain the reason for no activity. When a motherboard fails, no activity will happen at all, so Im putting my money on your motherboard being defect so take it in for a service and you may have to buy a new laptop since repairs can be costly.
Nov 20, 2008 | Computers & Internet
Gateway 4530GZ Notebook Logo
107 people viewed this question
Top Gateway Computers & Internet Experts
Brian Sullivan
Brian Sullivan
Prashant M
Prashant M
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
