Question about Canon imageCLASS MF5750 All-In-One Laser Printer
Printer not working
Printer is not detected by the computer, printing , scanning, fax all are not working. give any helpline number, and address of any service centre in delhi.
  • 565 Answers
Http://software.canon-europe.com/products/0010260.asp
Posted on Jan 12, 2009
No fax detected
check your printer fax setting from printer menu by using printer digital lcd
Jul 30, 2014 | HP LaserJet Pro M1536dnf Multifunction...
PRINTER WILL NOT PRINT
you need to assign an ip address most likely to the printer and hook it up to your wi fi, it will need to know the encryption code for your wi fi router or ethernet and then you need to set it up most likely with the driver setup disc to allocate it an ip address from your network. then each p.c will need to have driver disk run and driver should detect printer on network.
Apr 15, 2014 | Lexmark Pro915 All-In-One...
Hp laserjet m1522 printer unable to print after i change router
I would not post your ip address to either of these online. someone with a small amount of routing skill could cause some damage with that info. just saying. i have no answer to you question just trying to help you otherwise.
Feb 12, 2013 | HP LaserJet M1522 MFP Series PCL 6
U162 error on black ink cannon printer
This error occurs when printer fails detecting ink level or printer assume that no ink in the cartridge. We cannot use print, copy,scan, and fax function before the problem fixed. It's recommended for you to replace ink cartridge. To continue using the printer without replacing the cartridge we must deactivate ink level detection function. Be aware that printing in this condition can damage the printer while sending fax or scan is not problem.
If you need any technical help on printer then you can reach at http://www.vtechsquad.com/
Original source: http://ij-forum.blogspot.com/2008/12/error-message-check-ink-u162u163.html#ixzz2Cpr4Be1K
Nov 20, 2012 | Canon PIXMA MX340 Wireless Office...
Scanner
Try updating the drivers. Take this link to Hp and either enter model number and then operating system or let Hp detect your hardware and select drivers.
http://www.hp.com/#Support
Aug 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
NO CONNECTION (LAN) on Brother MFC-440CN
I had the SAME problem. I have 3 pc laptops and 1 Mac. The Mac could still print, but the pc's were hosed. I called BrotherUSA and this fixed the problem!
Go to your printer and after making sure it's connected to the network with the Ethernet cable, go to Menu > Print Reports > Network Config. This will print a page that shows your printer's IP address. We need to config that address in your Printer, Fax and Scanner settings in Control Panel.
Go to Control Panel > Printers & Faxes. Right click on your printer > Properties > Ports tab. Click Add Port and select Standard TCP/IP Port. Click New Port and click Next on the wizard. Enter the IP address of your printer in the first field (the second one will auto-fill). Click Next and Finish. Printer's done!
Right click on your PC-FAX in Printers & Faxes and Properties. Click on the ports tab and just check the box that you just created for Standard TCP/IP Port. Click OK. Fax is done!
Go back to Control Panel and select Scanners & Cameras. Right click on your printer/scanner > Properties > Network Setting tab. Select the Specify your machine by address radio button and, if it's not already in there, enter the IP address of your printer. Click OK. Scanner's done!
This will work as long as your router is running. You may need to repeat this process after a power outage or if you need to reboot your wireless router. Not too bad, though! I just wish everything was as easy as a Mac!!!
Jun 25, 2009 | Brother MultiFunction Center MFC-440CN...
Canon IR3300 would not scan when use the
give the same class ip address to your printe and computer and install ms office soft ware, and then microsoft tools click that we find the microsoft document scanning create shortcut to the desktop.
ping the printer for computer
run the network scan gear and click on the ip, enter the ip address in the blocks and then the discover.
then scan the document for the ir 3300 scanner.
Apr 15, 2008 | Canon imageRUNNER 3300 All-In-One Laser...
Fax device I/O error
installed samsung scx-4521f multi function printer. can't fax from smarThru program. get message : Fax device I/O error
Jan 11, 2008 | Samsung CLX 3160fn All-In-One Printer
Hp officejet 4315 how to switch from fax mode to print
There is no "print mode", Fax, Copy and Scan are modes one can enter, printing on the other hand is done when a print job is detected from your computer
DRIVERS to suit download link
Download Manual and Setup guide HERE
Please rate solution as fixed.
Nov 19, 2007 | HP Officejet 4315 All-in-One Printer
Canon imageCLASS MF5750 All-In-One Laser Printer Logo
97 people viewed this question
old marine
old marine
