Question about GE Spectra JBP78 Electric Kitchen Range
Front burning is either hot or cold
One burning cant control temp its either cold or very hot
  • dbowder
    dbowder Dec 06, 2012
    front burner sorry
    Top Expert:
  • GE Master
  • 9,472 Answers
Replace the surface burner switch. Here is the part to order.
Posted on Dec 06, 2012
Testimonial: "Thanks I will try this soon"
I have a jaguar x type my a/c blows hot on one side cold on the other. The it blows heat on both sides then back to hot one side and cold on the other
1st you do realize that the zones on this auto are adjustable from side to side not just front to rear??? , 2nd this auto has an electronic temp control that auto selects whether or not it blows hot or cold on that sides seating area biased on the temp settings of the person in that seat (body temp) , I guess its possible that the dash control module for this could be defective , but its been my own experience that if no one is sitting in that seat it gets a little "confused" and seems to cycle between cold and hot , one can only feel this if you direct all the vents towards the drivers side , simple fix is not to cross direct the vents over to opp. sides , as it will maintain (if working properly) a comfortable setting on drivers side (what ever set temp is )
Jul 17, 2012 | 2002 Jaguar X-Type
My car keeps dying when temp.gos up
your front oxygen sensor/lambda sensor is broken. you need to replace it. it stalls because o2 sensors start to work at higher temperatures(when cold car uses previous know error free mixture ratio - rich mixture). when engine is warmed up, your o2 sensor cant read correct values and engine controller cant decide on required amount of fuel to be burned in chamber.
Nov 19, 2011 | Pontiac Cars & Trucks
95 Chevy Surburban. Air conditioning issue, front air blows warm, rear unit blows cold. Have replaced orface 3 times, replaced compressor 3 times, replaced accumulator 2 times, flushed condensor,...
they run off of the same compressor if rear is cold and front is hot the hot and cold function in the heater box is not working possible cable problem ? or a vacum line under dash
Aug 04, 2010 | 1995 Chevrolet Suburban
My Kenmore front loader sometimes fills with warm water on cold setting.
Most washer today use automatic temp. control fill valves. If water is too cold the control might mix in some hot to bring up to a preset temp. The same is true when control set for hot. For energy savings cold water will be mixed in to maintain a semi hot temp. Check with manufacture just to be sure.
Feb 03, 2010 | Kenmore 3.5 cu. ft. King Size Capacity Top...
Whirlpool washing machine...only uses hot water
Make sure the hoses are connected correctly to the water valve on the machine. The connections will be marked with an "H" and a "C".
Given they are correct, most current washing machines have and auto temp feature on the water fill. It allows even cold water settings to bring in some hot water to make sure the water temp is hot enough to efficiently disolve your laundry detergant. The preset temps are usually around 75* for cold, and 105* for warm. Hot water comes in at whatever temp your household water temp is.
Sep 12, 2009 | Washing Machines
'99 eddie bauer, cold air in the rear hot air in
you may just be low on freon. The rear will often work ok when low, but the front won't
The same compressor serves both front and rear systems. Check that first.
ALso, check to see if your front blend door rotates when you raise & lower the temperature.
report back on results
May 09, 2009 | 1999 Ford Expedition
Passenger side blows hot air when front control set to Air
you cant adjust it ,this requires the dealers computer to re set it,or a phyiscal control has packed up like a vacumn pipe has split where it pushes onto the valve that controls the flap in the heater unit.
Apr 25, 2009 | 2005 Dodge Durango
Temp stuck on hot on my front loader washing machone
Water temperature is controlled by a switch which activates or deactivates the hot and cold water solenoids. Replace this switch, it is not expensive.
Apr 22, 2009 | Washing Machines
Heater only blows hot (well, warm) on full speed of fan
Replace the temp control on this car, it should be electrical control not cables.
Dec 03, 2008 | 2000 Ford Escort
Maytag mav6000 hot/cold problem
hi try to just regulate the temp by turning down the water flow from your taps if more cold is coming in than hot turn cold water down a bit to your satisfaction thanks THE APPLIANCE DOC
Sep 05, 2008 | Maytag Atlantis MAV6000 Top Load Washer
GE Spectra JBP78 Electric Kitchen Range Logo
241 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
