Question about Panasonic TC-P50G10 Plasma TV
Panasonic TC-P50G10 doesn't display image after lightening, but screen shows solid gray/light. How to diagnose problem?
We had a power surge and the tv will not show an image. when i push power button, the screen sort of becomes lighter, as if it is recieving power, but no image will display. I have replace the "main digital board" in the upper right...
5 Suggested Answers
  • 608 Answers
SOURCE: My panasonic lcd tv tc-L32x1.
I had a similar problem with my 42 in Philips LCD HDTV.
Here was the problem. My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of course) and found four bulged capacitors on the PSB. Many major electronics companies Philips/Magnavox, Sony, Panasonic, and others were sold capacitors that failed in 2-5 years instead of 10-20. The capacitors fail prematurely due to a lack of preservatives. Unfortunately, they were installed in all sorts of devices and cause a wide range of failure problems.
Here are some options for you.
1. Have it fixed by a professional $$$$$$$??????? (Is it under warranty?)
Remember, TVs CONTAIN HIGH VOLTAGE AND CAN KILL YOU! Do this at your own risk.
2. Open your TV and find PSB. (The board that the power cord plugs into) Check for faulty caps. If you find some (bulged or leaking) bad caps replace the entire board. The entire board costs around $250 right now because they are in high demand right now. They can be found online. I would definitely shop around though.
3. Remove and then replace individual faulty caps. This takes some soldering skill.
Caps are inexpensive and if you can take care of it yourself it will save you hundreds.
This may be your problem. If you determine that it might be.
I have a Tip/How TO tutorial on this site that may also help. It gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. Here is the Link: Fixing the Philips Turns/shuts off on its own problem. I'm working on uploading pictures to help guide people though the process as well. Let me know if I can do anything to help.
Hope this helps and if it does please rate it accordingly. Good luck.
Posted on Dec 20, 2010
  • 44 Answers
SOURCE: Need help with my panasonic tc-50ps14
This is a plasma TV to which there are driver boards Top/Bottom, Left and Right.
Sounds like some of the driver main transistors have gone bad.
Wondering how old the TV is?
Honestly may be best to search for a new TV. Sorry to break this to you but its the law of supply and demand and there is such a glutton of TV's, Plasmas, LCD and LED tvs out there.
Sorry to be the bearer of bad news. As a tech I hate telling you this. I don't make the money fixing these older units. Cheaper to go out and by new with a warranty!
Posted on May 24, 2012
vinceisaac
  • 2432 Answers
SOURCE: panasonic tc-p50g10
defective D board.
Posted on Aug 19, 2012
  • 41918 Answers
SOURCE: Hi! I have a Panasonic TC-50PS24 that has no lights and doesn't power up. I think it probably needs a new power supply board. I don't see any burnt contacts or bad capacitors. Any thoughts wou
My thought is that you are right about the power supply
Posted on Nov 30, 2012
Have Vizio TV, powers on, but blank screen, no backlight
Its probably damaged the board that powers the backlight in the surge. Repairs on this depending on the size of the TV might out way the cost of replacement. I
Dec 05, 2013 | Televison & Video
No picture on Vizio 60" E601i-A3
yes take it back 6 weeks i would return it
Dec 30, 2012 | Vizio 60" E601I-A3 Full HD LED-LCD TV
I was watching my tv when my son hit the reset button on my surge protector..now my tv will not turn on. Any ideas?
Turn everything off, the tv the power and make sure the button is not active at the moment. Some surge protectors do come with a fuse but when you turn the surge protector back on itself make sure it is recieving power, there is usually a red light on the switch while recieving power. Then try again once you know there is power to it.
Feb 06, 2011 | Vizio E370VL 37 in. LCD HDTV
TV does not show picture when turned on. Some times it does not come on. when it does it goes to a split Bright green screen, After that it will go to a lot of different screens with lines, full screens of...
It is possible that TV processor could have some garbage it do to a small voltage surge, and if you leave your set, unplug from the wall for 40 min,. that will reset it back to normal. If thgat don'rt work then remove the back and check for a couple of bulged electrolytic caps on the power supply nthat need change, or change out the power supply.
Nov 12, 2010 | Protron PLTV-26 26 in. HD-Ready LCD...
Seemed to short circuited through power surge from
You have a bad Main bd. Have a trained Samsung tech repolace the Main bd.
Jul 02, 2009 | Samsung LN-T4671F 46 in. LCD Television
Screen image overlaps edges of screen and entire image is not fitting the screen
if your tv has a format button on it just press it until your picture is to where you like it. plus if you have a hd reciever it also has a format setting on it to.
May 02, 2009 | Televison & Video
JVC AV-32D305(?) turns off sound but not picture
if you know how to solder ,resolder the amplifier your tv .or check speaker
Sep 03, 2008 | JVC AV-32D305 32" TV
Blurry text on 27-inch Zenith "Sentry 2"
I have had this problem before and restarting the reciever fixed it. Just push the red button under the front panel of your reciever, or unplug the reciever for a minute or so.
May 13, 2008 | Zenith B27A11Z 27" TV
SUBWOOFER
Sounds like the power supply in the subwoooooooofer box is dying.
Replace the whole thing . It's going to be the best way out.
Oct 25, 2007 | Sony STR-DE345 Receiver
Panasonic TC-P50G10 Plasma TV Logo
57 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
