Question about Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw
Wher do the two carburator linkages hook up to a husqvarna on a 455 rancher
Also which holes it hook up to? Thanks Chuck in advance.
  • 3 more comments
  • Charles Ray Hickman Dec 07, 2012
    Thank's Andrew, worked like acharm
    Thank's Andrew, it worked like a charm.
  • Charles Ray Hickman Dec 09, 2012
    Hello Sir,yes this solutation took care of the problem very quickly,and answered very quickly.
    I rate your site as A++++++ all the way.
    Hello Sir I rate your site as A++++ all the way.
  • Husqvarna Master
  • 2,239 Answers
The throttle wire plasric end sits through the back of the crancase and into the square cut a way into the tank back handle, the hooked wire end drops into the carb throttle spindle on the r/h side of the carb, the blue clip on the spendle then rotated and locks the wire in, the choke pull just pushes into the choke spindle on the l/h side of the carb, it has a bullet style end to stop it popping out again
Posted on Dec 06, 2012
Testimonial: " Thank's Andrew,it worked like a charm. And may GOD bless you. Chuck."
dontbother10
  • 2220 Answers
SOURCE: magneto to flywheel gap for Husqvarna 455 Chain Saw
Ignition module gap
Place a business or index card between the fly wheel and coil, rotate until the magnetic attraction pulls everything tight together. Tighten the coil screws, rotate the flywheel until the attraction eases and remove the card. Ensure nothing contacts when flywheel is rotated.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Posted on Mar 22, 2010
dontbother10
  • 2220 Answers
SOURCE: How do I replace chain on Husqvarna 455 rancher
Unlock the chain brake and remove the clutch cover. This should provide what you ask:
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If you get stuck or need model specific instruction, there is very detailed illustrated instruction in your manual under "Fitting the bar and chain". The tool-less adjusters add needless layers of complexity IMO.
HusqvarnaUSA.com
http://www.husqvarna.com/us/homeowner/support/download-manuals/
Enter the 3 digit model number (no XPs, Es, just the numbers)
Serial number decode – useful when downloading IPLs and Manuals
06 1500198
06 = year produced – 2006 (single digit before 2000; please contact Husqvarna for single digit clarification)
15 = week produced – March
00198 = 198th unit Husky produced that week
Lou
Posted on Mar 06, 2010
dontbother10
  • 2220 Answers
SOURCE: What is Fuel Mixture Husqvarna 455 Rancher Chain
Duplicate post Close/delete
Posted on Sep 25, 2009
dontbother10
  • 2220 Answers
SOURCE: Fuel Mixture Husqvarna 455 Rancher Chain Saw
Page 17 of your Operator's Manual says 50:1.
Fuel/Oil Mixture
  1. Use a quality 2 cycle oil and mix it to the OIL supplier's recommended ratio. Today I use Stihl 2 cycle oil mixed @ 50:1 in a Pioneer that I purchased new in 1980. There are no gouges or scratches on the piston or cylinder and I have no carbon build up on the piston top. The manual (on stone tablets) recommends 24:1. Over the years the mixture has leaned from 24:1 (Saw Recommendation) to 28:1 (Lawn boy mower recommendation) to 32:1 (Oil provider 8oz/2gal - used for many years) and finally the last 5 (±) years 50:1 (Stihl 2.6oz/1gal)
  2. Most gas in the US of A contains ethanol; not good with chainsaws. Mix what you expect to use within a few months. Anything over 6 months old use up in a 4 cycle engine. HTH
    Lou
dontbother10
  • 2220 Answers
SOURCE: I have a husqvarna 455 rancher. It was working
Why would you pay for something and then not force them to make good? I have a large bridge for sale, CHEAP. Make you a heck of a deal.
Take it back!!!
Lou
Posted on Sep 17, 2009
Just changed the ring and now can't stop the chain from moving, Is there anything to check besides the carburator?
For the 455 Rancher.
First check the idle speed. It should be 2700 rpm. Clutch engages at around 3800 rpm. If the clutch is engaging below the 3800 then clutch springs need checking and replacing if needed.
If you can't get the idle speed down check for air leaks.
Jan 24, 2015 | Husqvarna , No.455 Rancher, 20" Gas -...
What is the gas / oil ratio mixture for husqvarna 455 rancher model ?
50:1 that's 2.6 ounces of 2-stroke oil (preferably with fuel stabilizer) to one gallon of gas. I recommend using 89 octane gasoline for all small engines. It has little or no ethanol in it, as opposed to the 10% typical in 87 or 86 octane fuel. This will prevent a lot of fuel issues, especially if you are not using the tool daily or at least weekly.
Aug 02, 2014 | Husqvarna "965030298 - 455 Rancher, 20""""...
Hello,i would like to know how to adjust the float on a john Deer 425 20 HP Motor. Any Help would be greatly appreciated. Thanks Chuck.
Before you make any adjustment be sure the float needle is not stuck closed in the seat. Also shake the float to be sure there is not fuel inside the float.
Aug 29, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
Connecting carburetor to the throttle on husqvarna 44 chainsaw
The wire linkage has a short Z bend in one end this hooks into the throttle lever from the outside, the other end has a long loop this goes into the trigger arm from the outside, you will need to twist the top of the trigger arm slightly to allow the linkage to go into the hole in the trigger arm.
Dec 29, 2017 | Husqvarna , No.455 Rancher, 20" Gas -...
Where does the linkage from the trigger to the carburetor hook up to on the carb end
there will be a spring and a flat plate that has multiple holes in it, the trigger cable will hook into one of these holes. the easiest way to locate this is to look into the carb, and pull in the levers, when the fly inside the opening moves this is the one, but be careful there will be two and one is for the choke. the choke will have 2 to 3 position and will make kind of a click each time. you want the one that does not make a click or is the largest one.
Dec 31, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Will not crank,low compression husqvarna 455 rancher
How you cnow its low pressure? check spark, air filter, and any air leak from between cilinder and carburator.
Oct 14, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna 455 rancher . it has low compression and no fuel to plug . wont start but piston and rings are fine .Help
it could be the small gasket between the head and carb. they are also bad about the fuel line coming out of the tank gettin rubbed and making a small hole or pinched.
Oct 12, 2010 | Husqvarna , No.455 Rancher, 20" Gas -...
Take it right back to repair shop and have them fix under their warranty.
It is possible the fuel hasn't got to the carbureator due to plugged fuel filter or fuel finder OR an air leak in the fuel hose.
Sep 15, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
455 rancher will not produce oil for the chain. Oil pump replacement? Need repair manual or parts breakdown. Thanks Warren
Also make sure that where the oil is pumped against the side of the bar that the oil port (little hole) that feeds oil into the bar's slot is clear. Mine would go through a tank of oil with each tank of gas, but the chain wasn't getting oiled until I cleaned out this little hole.
Jun 29, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Husqvarna , No.455 Rancher, 20" Gas - Powered Chainsaw Logo
243 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
