Question about Kenmore Dryers
Kenmore dryer 68202794 won't dry - Kenmore Dryers
heatman101
  • 43501 Answers
SOURCE: when we push the button
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Posted on May 20, 2011
jdhnmi
  • 143 Answers
SOURCE: Kenmore dryer model 417 won't
if it is electric you need a new heating element they can cost around 80 dollars for the string it yourself kind and the pre strung kit cost double that price mabye more . if you are handy i can tel you how to replace the part in detail. I have also written a few time how to replace this part if you look through my solutionshope this helps feel free to write back for more help i would love to assist you
Posted on Jun 27, 2011
heatman101
  • 43501 Answers
SOURCE: My series 80 Kenmore dryer won't start
heatman101
Posted on Aug 05, 2011
heatman101
  • 43501 Answers
SOURCE: kenmore 90 series dryer..motor won't
heatman101
Posted on Aug 11, 2011
Macmarkus
  • 2605 Answers
SOURCE: My dryer panel is marking
Hello, welcome to FixYa.
Based on your post, you have a Samsung dryer, is that correct ?
If so, the "tO" error code as you may or may not know is in relation to poor air flow or a failed thermistor..."Thermistor Open" = tO. (I would advise cleaning the vent thoroughly and the lint screen with hot water and mild soap and run a cycle with the vent off to see if the tO re-appears.)
Here's how you can check the thermistor.
**Unplug the unit before proceeding...safety first**
This test can be done on the control board with an ohm meter. Find pins number 2 & 6 on the white connector as shown here...
The values you'll want to see are around 10K ohms (10,000ohms) at room temperature.
To access the PCB you must first remove the top. To do so you simply remove the screws at the back, i.e.
Once you have removed the top, you'll have access to the main control board/PCB.
Then you should be capable of testing the thermistor (blue and red - 2 & 6 wires on the white connector with 4 wires in total)...with an ohm meter of course. Let me know if anything is not clear and I'll try to be available asap.
I will try to help in any manner I can going forward of course as well. Good luck.
Regards,
Macmarkus :)
Posted on Aug 31, 2011
Kenmore electric dryer won't dry clothes. The
What is the model number of your unit?
Nov 17, 2012 | Dryers
Dryer takes a long time to dry
If the dryer won't takes to long to dry, check the venting. A clogged or partially clogged vent will reduce the air flow through the dryer and greatly increase the drying time.
Nov 12, 2012 | Kenmore Elite HE4 Electric Dryer
Kenmore dryer 110.86864100 - Where is the moisture sensor?
Ain't no moisture sensor. This is is not an electronic sensing machine. It uses another method to determine dryness. An orange wire connects to the base of the heating element. The timer motor is driven by power from it in auto dry. The timer motor is VERY slow. Slower than most dryer timer motors.As the clothes get dryer the heat is not needed so the element is turned off by the control thermostat which is mounted next to the skinny white fuse on the blower housing. This allows for the turtle like motor on the timer to advance. Once the clothes get to the point of dryness the heater stays off way longer and the timer motor advances on over to the cool down and carry on over to the end of cycle. So the clothes won't always be dry due to factors like lint buildup in the blower housing, venting to outside and so forth. having said that my mom bought a brand new Kenmore dryer and I set it on 55 minutes timed drying. At the end of that them clothes is still damp. I then set it to auto dry high heat and that usually gets em dry. I think the main probo with this dryer is the thermostat ain't set as high as older models to keep the heat at a moderate temp so that the limits won't blow on models in apts and such. Just a theory.
Sep 16, 2012 | Kenmore 659 Electric Dryer
Dryer heats but not drying
could ber one of a couple things. 1 the exhaust line is clogged. I know this sounds silly but if the hour air can't get out properly it throws off the entire cycle and it won't warm up right. 2 the thermostat could be bad 3 the fan could be not spinning due to being cracked or otherwise messed up
Feb 01, 2012 | Kenmore Dryers
My kenmore elite HE5 gas dyer won't dry properly. It will heat but not as well. It take along time to dry. Sometimes I have to dry my clothes twice before they will get completly dry. What could this...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Aug 16, 2011 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
