Question about Whirlpool Water Heaters
I can not find the anode on my water heater
There isno obvious nut for anode on top
  • Whirlpool Master
  • 5,245 Answers
1) Copy following link:
http://waterheatertimer.org/Replace-anode-rod.html
2) Anode might be located on hot water nipple as a combo.
Insert carriage bolt when removing nipple to avoid collapsing nipple during extraction.
Regular combo anode rods are available, or buy sausage-link combo available in 12" length to fit low headroom installations.
3) Ordinary 1-1/16" hex Anode might be located under the metal cover on steel tank.
4) If unit has power vent, the anode might be under power vent.
Workaround; Install combo anode to replace hot water nipple.
Posted on Dec 06, 2012
  • 252 Answers
SOURCE: cant locate anode rod on rheem gaas water heater
It looks like a plug screwed into the top of the water heater (it IS plugging the hole so turn off water and release pressure b4 removing)
Posted on Oct 01, 2009
c7121
  • 160 Answers
SOURCE: Annual maintenance for Rheem water heaters calls
PROBABLY. THE ANODE PROBABLY FUSED ITSELF TO THE TANK VIA ELECTROLYSIS. I WOULDN'T WORRY ABOUT INSPECTING THE ANODE ROD UNLESS U LIVE IN AN AREA OF HARD WATER AND/OR THE UNIT IS OVER 5 YEARS OLD. DRAINING AND FLUSHING THE WATER HEATER TWICE A YEAR WILL HELP KEEP THE UNIT PERFORMING LONGER. ADDING A WATER HEATER BLANKET WILL HELP LOWER UR UTILITY BILL AS WELL.IF U FEEL U MUST HAVE AN ANODE IN UR TANK, ANY RV DEALER HAVE ANODES FOR A SUBURBAN WATER HEATER THAT U CAN ADAPT AND THREAD INTO THE DRAIN PORT OF UR WATER HEATER.
Posted on Dec 15, 2009
SOURCE: WHAT SIZE SOCKET NEEDED TO REMOVE ANODE ROD?
Hello EDAN I believe it is 1 1/16" socket.I had 1/2" drive & extention bar as it very TIGHT & hard to turn the rod nut.
Posted on Jul 16, 2010
  • 5245 Answers
SOURCE: water heater anode
If you have power vent, the anode might be located in a separate port on the top under the power vent.
Otherwise, the anode can be a 'combo' and connected to hot water nipple.
Copy following link for more information
Posted on Aug 08, 2012
  • 5245 Answers
SOURCE: how to replace anode in Reliance 6402ORS
Anode can be connected to, and part of hot water nipple.
This is called combo anode rod.
http://waterheatertimer.org/images/Anode-top-of-heater-600.jpg
There are also instances where the anode is on top, but does not line up with access holes.
This is more typical with older water heaters.
Don't forget to clean air intake located on bottom of unit, using feather duster or compressed air.
http://waterheatertimer.org/images/Flame-trap-inspection.jpg
Year of manufacture for Reliance is 2nd and 3rd digit of serial number located on label on side of tank.
Reliance is owned by AO Smith.
Posted on Nov 30, 2012
Check anode rod
There is a large nut on the top of the heater. Shut off the burner, shut off the water, unscrew the cap and remove it, you should see a long rod attached to the cap. This is the anode and it is designed to be consumed by the water minerals in order to prolong the life of the tank in the heater. If it is consumed, you can replace it.
Sep 16, 2015 | Water Heaters
WHERE IS THE ANODE ROD ON A 606 RELIANCE HEATER
It is the 1" or 11/8" hex nut on the top of the water heater some where near the supply line. As for the anode rod it could be either magnesium or aluminum depending where it was sold. If you are going to change it out call your water provider and ask which would be better for your area and type of water.
Sep 23, 2014 | Reliance 606 Series 40 Gallon Electric...
Rheem anode rod replacement
replacing the anode will increase the life of the tank. it is the large nut on top of the tank. it is a sacrificial material that helps prevent tank rust through.
Jun 01, 2014 | Rheem Water Heater Anode Rod AP12938
Where is anode located mdel no. 82yp30-1
Question posted under Rheem water heater.
Model number does not describe water heater.
Model number posted in question does not appear at Rheem, and does not appear in a web search for water heaters.
Here are options:
1) Add a comment and describe water heater in detail so expert can access more information
2) Contact Rheem.
http://www.rheem.com/Contact.aspx
3) If this is tank-type water heater, the anode is located on top of heater.
Look for 1-1/6" hex nut located under a plastic plug.
Some anode rods are connected to the hot-water nipple.
Sometimes the top cover has to be removed to find anode hex nut.
I have used impact wrench on anode, and could not remove in some cases.
4) More resources:
Sep 17, 2011 | Rheem Water Heaters
Where is the anode rod located on the rheem 81VP20s
Anodes are located on top of water heater.
There are no hard fast rules for location, either by model number or brand.
Most times the manual is likewise vague.
1) There is hex head visible on top of tank.
2) Hex head is located under a plastic cover
3) Hex head is located under metal top, so remove screws holding top, and lift top off to view hex head
4) Anode is connected to hot water nipple.
5) With 9-12-15-and lifetime tanks, you can have 2 anode rods, and each has to be made of same material to work properly. Usually magnesium-aluminum instead of aluminum.
But if you inspect and change anodes frequently to prolong life of tank, then one is as good as the next.
Open following links shows Rheem anode rods
http://waterheatertimer.org/pdf/Rheem-Ruud-anode-rods.pdf
http://waterheatertimer.org/pdf/Rheem-Ruud-water-heater-parts-guide.pdf
Tech resistor anode rod has resistor added to prolong life of anode.
You can cut rod off to fit size of tank. You want anode 5-6" from tank bottom so sediment build-up doesn't reach anode.
Anodes are standard 1-1/16" hex head.
http://waterheatertimer.org/images/Water-heater-anode-006-200.jpg
http://waterheatertimer.org/Clean-sediment-out-of-water-heater.html
Add a comment with your experience so others with same-similar problem can benefit.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on water heater or any do-it-yourself project.
Fixya is always less expensive than a service call.
Apr 01, 2011 | Rheem 81VP20S/430157 Water Heater
Where is anode rod located on 100 Gallon rheem water heater natural gas
Anode rods for tank-type water heaters are located on top of tank.
This is true since anodes are about 44" long.
Top of anode is standard 1-1/16" hex nut.
Anodes can be located in 2 different places: either directly screwed into top of tank -or- attached to hot water nipple.
Most times the exploded parts diagram in manual simply shows 'anode rod' without specifing exact location. If your tank has long warranty, then it can have two anode rods, and 1 will be on top and the other probably attached to hot water nipple, or there could be two anodes screwed into top of tank.
If anode is screwed into top of tank, then it will be under a plastic cap -or- it will be concealed under the top cover of tank.
Look for plastic cap, and if none shows, then remove screws holding down metal cover and look there for 1-1/16" hex nut.
Lastly, remove hot water nipple and check for anode located there.
If you have 2 anode rods, then replace with same metal for each.
Add a comment for more free help.
Mar 22, 2011 | Rheem Water Heater Anode Rod AP12938
I have a rheem heater M/N 81V40D how do I change the anode?
Unless you see a large hex head socket to remove on the top of the water heater, many
anode rods are built onto the hot side nipple. They are almost the length of the water heater.
Hopefully you have room to remove it if this is the case. If you see a hex nut that is silver
gray on top, then shut off cold water to the heater. Release some hot water at a tap to relieve
pressure on the tank or drain some out at the bottom which is better. Make sure power is
off to unit first or gas is off . Unscrew nut or nipple counterclockwise to remove. Best to
remove with a socket wrench or box wrench if it's a nut and a good pipe wrench if it's
on the nipple. Several light taps with a hammer if necessary on the handle of the
wrench or pipe wrench should help. Hopefully the nipple has a removable flex line if
it's located there. (Remember it's on the hot side and should be marked on the top
of the heater).
Feb 20, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
Where is the anode rod in a 606 electric reliance hot water heater--is it magneesium or aluminum
It is the 1" or 11/8" hex nut on the top of the water heater some where buy the supply line. As for the anode rod it could be either depending where it was sold. If you are going to change it out call your water provider and ask which would be better for your area and water.
Feb 05, 2011 | Reliance & 50gal Electric Water Heater
Does the 501 ahve an anode rod. If so, how do I replace it
Every water heater has an anode rod.
Reliant manuals
http://www.reliancewaterheaters.com/lit/om.html
Reliant is made by American
I don't find a 501 manual under gas water heaters at reliant.
The Reliant manuals that are available do not show the anode rod in the drawing.
But they do show an access port on top of tank.
The anode rod is usually under the access port which is a round plastic disc.
On some water heaters, the anode rod is under the steel top and you have to remove the screws holding the top on.
Some water heaters, the anode is connected to hot water outlet.
Below are two links for the do-it-yourself-er
http://www.thisoldhouse.com/toh/video/0,,20047047,00.html
Oct 23, 2010 | RELIANCE ELECTRIC WATER HEATER
Water Heaters Logo
185 people viewed this question
Top Whirlpool Water Heaters Experts
Donni Steen
Jim Goldsmith
Jim Goldsmith
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
