Question about Sony KDL32EX500 32 in. TV
Connecting DVD player - Sony KDL32EX500 32 in. TV
    Top Expert:
  • Sony Master
  • 14,553 Answers
What do you need to know?, go from the outputs on rear of player to matching ones on rear of set marked input, The Sony owner manual should have detailed instructions and diagrams for you as well as the player.
Let me know what issue you are having and I will try to help.
Posted on Dec 06, 2012
How to connect dvd player to tv
    1. If so you can get yourself a component cable and connect the DVD player to the TV using those plugs. Otherwise, you will need to get an RCA to HDMI converter.Nov 23, 2015
      Connecting old VHS/DVD Player to my Smart TV - Tom's ...
      www.tomsguide.com/.../id.../needed-connecting-vhs-dvd-player-smart.html
    Feedback
  1. 5 Easy Ways to Hook Up a DVD Player (with Pictures)
    www.wikihow.com/Hook-Up-a-DVD-Player
    wikiHowHooking up a DVD player to your TV will give you access to countless hours of movie-watching bliss, and most modern TVs and DVD players make the setup ...‎Setting Up your DVD Player - ‎Connecting with an HDMI Cable
    How to connect a standard DVD player to a TV - YouTube
    ? 2:57
    https://www.youtube.com/watch?v=8pARHjY8xoo
    Jul 5, 2011 - Uploaded by All About Home Electronics.com
    Lol I used my standard AV cables for the component, and I used an adapter to plug the audio into my speaker ...
Dec 30, 2015 | Televison & Video
How to get off blue screen
Check the TV by connecting it to an external antenna. If it works well with external antenna, check the input selection done after connecting the DVD player. Check whether Power to the DVD player is pluged in and it has been switched ON.
May 14, 2012 | RCA TruFlat 27F520T 27" TV
My dvd player only plays back in black and white, no color. any ideas?
If you haven't done so already try connecting a different DVD player (or some other device) to the same part of the television to see if there is color. You can also try changing the cables connecting this dvd player and the television. If there is color on another device then you know that the problem is with the DVD player. If there is color with the same DVD player when you have changed the cables then you'll know that they were the problem. If the television does not play in color no matter what (DVD player or tv channels or anything connected to the television with all different cables) then you'll know it is at fault.
Apr 05, 2011 | Onkyo DR-C500 Multi-disc DVD Player
Hook up player
Your TV hopefully supportsw more then one unit connecting to it. if not you will need to use an input on one of your units (direct tv unit or DVD player) for the other unit. Example your direct tv is connected to your TV, on the back of your direct tv unit is a video /audio input. connect your dvd player to that input. on your direct tv remote or menu should be an option to use that input.
Aug 25, 2009 | GoVideo Go Video DVD/VCR Combo
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
Jul 25, 2009 | Sharp DVMX1U DVD Player
Connecting panasonic dvd to olevia tv
when connecting a dvd player you want to try using the yellow red and white cables.. ( AV CABLES) to the television.. just match the same color on the back of the television. Once that is done change the source on your remote until it displays composite then the image should be on.
if you will like a better image quality use the component cables (green, red and blue cables) but the dvd player has to have does colors as well or else it wont work.
Mar 21, 2009 | Panasonic DVD-RV30 DVD Player
Connecting my dvd player to my lcd hdtv tv
Do you already activate the progresive scan function,if not put it on.
Jun 20, 2008 | Cyberhome CH-DVD 300 DVD Player
Unable to get sound when connecting DVD player to TV
connect one end of white cable to dvd/vcr audio output and the other end of white cable to tv audio input L .
connect one end of yellow cable to video output on dvd/vcr and the other end of yellow cable to video input jack on tv
If you connect like this after checking you connections this should fix problem.
Jan 02, 2008 | Insignia IS-DVD1001 DVD Recorder/VCR
Open Questions:
Sony TV EX500 32 inch was not turning on Turned on with below SOny TV support: 12:09 AM Connecting... 12:09 AM Connected. A support representative will be with you shortly. 12:09 AM Support session established with Pamela - (C4IC). 12:09 AM Pamela - (C4IC): Hi. Welcome to Sony Online Support. I’m Pamela. 12:09 AM Customer: Hi 12:09 AM Customer: I am facing problem with my SONY tv 12:09 AM Customer: power on problem 12:10 AM Customer: I purchased it 1.5 year back 12:10 AM Pamela - (C4IC): I understand that the TV is not turn ON and the light is blinking. Is that correct? 12:10 AM Customer: till now i had problem with HDMI only. 12:10 AM Customer: Yes 12:10 AM Customer: yesterday screen started blinking 12:10 AM Customer: but after few mins, everything was fine 12:11 AM Customer: but today when i turned it on, i saw same thing. 12:11 AM Customer: So i did factory reset 12:11 AM Customer: and now it doesnt turn on 12:11 AM Customer: it was responding to menu after turning on. but blinking. 12:12 AM Customer: I turned off ambiant sensor from menu. 12:12 AM Customer: now it doesnt turn on even for a nano second 12:12 AM Customer: red light is blinking. 12:12 AM Customer: when i press power on, it show green and immediatly red ligh 12:12 AM Customer: what do i do 12:13 AM Pamela - (C4IC): Thanks for all the information. I will assist you in this regard. 12:13 AM Pamela - (C4IC): Are you with the unit now? 12:13 AM Customer: yes 12:14 AM Pamela - (C4IC): I am going to ask you some additional questions, in order to determine what is causing the TV not to turn ON. 12:14 AM Customer: ok 12:14 AM Pamela - (C4IC): Let me know the # of times the standby light blinkng on the frpont panel of the TV. 12:15 AM Customer: i have to check 12:15 AM Pamela - (C4IC): Sure, please go ahead. 12:16 AM Customer: i plugged power cable to switch 12:17 AM Customer: it showed red light 12:17 AM Customer: then i click power on on my remote 12:17 AM Customer: it showed green on tv 12:17 AM Customer: in few milliseconds , i heard a sound.. 'tnn' 12:18 AM Customer: then green light turned to red and screen is black 12:18 AM Customer: it is blinking continuously for 5 times 12:18 AM Customer: then a pause of a while 12:18 AM Customer: and then again 5 times blink(in red light only) 12:18 AM Customer: then pause 12:19 AM Customer: and so on...blink continue in sequence of 5 12:19 AM Pamela - (C4IC): Thanks for the information. 12:19 AM Pamela - (C4IC): Let me know if the TV is connected to a surge protector or to a power strip. 12:19 AM Customer: power strip 12:20 AM Pamela - (C4IC): Let's try power resetting the TV and check if that helps. 12:20 AM Customer: how do i do that 12:20 AM Customer: ? 12:20 AM Pamela - (C4IC): First, turn OFF the TV. 12:20 AM Pamela - (C4IC): Then, disconnect the power cord of the TV from the wall outlet for one minute. 12:20 AM Pamela - (C4IC): After one minute, reconnect the power cord directly to a different known working wall outlet without using any power strip or surge protector. 12:20 AM Pamela - (C4IC): Then, turn ON the TV and check. 12:22 AM Customer: turned on... green light is there..after few milliseconds, there was a brightness on tv but with a sound, it turned in black screen and green light turned to red 12:22 AM Customer: n red light blinking 12:22 AM Pamela - (C4IC): Did you try connecting the TV to a different wall outlet? 12:22 AM Customer: ok.. trying 12:23 AM Pamela - (C4IC): Okay, please go ahead. 12:25 AM Customer: A different behavior this time 12:25 AM Customer: i attached tv power cable to a power strip and power strip to different wall outlet 12:25 AM Customer: now turned on 12:26 AM Customer: green and yellow both lights are blinking 12:26 AM Customer: nothing there on screen 12:26 AM Customer: its black 12:26 AM Customer: this time it has not turned to red 12:26 AM Customer: yellow and green lights are blinking 12:27 AM Pamela - (C4IC): Please connect the power cord directly to a known working wall outlet without using any power strip or surge protector. 12:27 AM Customer: ok 12:29 AM Pamela - (C4IC): Let me know the status of the issue. 12:29 AM Customer: i put power cable on different port 12:29 AM Customer: wall outlet i mean 12:30 AM Customer: this time TV came up with green light 12:30 AM Customer: stream is there on tv screen 12:30 AM Customer: but it is blinking a lot 12:31 AM Customer: same problem which i saw since yesterday 12:31 AM Customer: TV channel stream is playing properly but screen is blinking 12:32 AM Pamela - (C4IC): Unfortunately the available troubleshooting has not resolved your issue. 12:32 AM Pamela - (C4IC): Based upon these results, it appears that the issue can be resolved only after physically examining your TV. 12:32 AM Pamela - (C4IC): Therefore, I suggest that you contact our authorized service technicians to get the unit physically examined. 12:32 AM Pamela - (C4IC): May I have your area zip code so I can check if there are any Sony authorized service locations near you? 12:32 AM Customer: 201301, noida, in India 12:33 AM Pamela - (C4IC): Thanks for the information. 12:33 AM Customer: Yes, i purchased TV from authorized SONY TV showroom. They must be providing service. I am not very sure 12:34 AM Pamela - (C4IC): In that case, I will forward a link to the page where you can find the contact information about the Sony service center in India. 12:34 AM Customer: what actually problem earlier... you asked to change port and now TV turned on... why so, is there any fault with that wall outlet.. I daily connect to same wall outlet.. 12:35 AM Pamela - (C4IC): Yes, there may be some power conflict. 12:35 AM Customer: today when i connected to same port, TV didnt turn on... but after your steps, TV turned on.. 12:35 AM Customer: power conflict?? 12:36 AM Customer: what does power conflict mean? 12:37 AM Pamela - (C4IC): Power conflict may be some issues with the wall outlet to output the power. 12:37 AM Pamela - (C4IC): I will forward a link to the page where you can find the contact information about the Sony service center in India. 12:37 AM Pamela - (C4IC) has sent a link: http://www.sony.net/SonyInfo/Support/ 12:37 AM Customer: My TV is just few inches above my refrigerator.. and these days due to hot weather outside, i have set refrigerator on high power. 12:37 AM Customer: could it be a reason? 12:38 AM Customer: i heard there is a humadity sensor, n due to more humadity, TV doesnt turn on.. i read on internet, people use blow dryer and vaccum cleaner to reduce humadity and to turn on their TV, when they face this problem 12:39 AM Customer: is it right way? 12:39 AM Customer: Many people solved problem this way... i havent tried because i dont have blow dryer.. could humadity be a reason on not turning on? 12:40 AM Pamela - (C4IC): It is not recommended to operate the TV below 41 degree Fahrenheit (5 degree Celsius). 12:41 AM Customer: Temp here is 32 celsius these days in night. 12:42 AM Customer: I will call TV service senter to repair blink problem... do u have any troubleshooting guide for blink problem? 12:44 AM Pamela - (C4IC): We have tried the possible troubleshooting steps. 12:44 AM Pamela - (C4IC): I suggest that you get the TV physically examined by the service technician to kno
May 17, 2012 | Sony KDL32EX500 32 in. TV
Sony KDL32EX500 32 in. TV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
