Question about Bosch Tools & Hardware - Others
Bosch 1273 sander dvs
How to install leaf spring
4 Suggested Answers
stug_57u
  • 99 Answers
SOURCE: toothed belt bosch 1274 dvs
If I am correct, when holding the tool in the normal operating position there should be an oblong cover on teh left hand side nea the back of the tool. It should be held on with a screw. remove this cover and you can access the belt . MAKE SURE THE TOOL IS UNPLUGGED. the belt should pull off/push on with a bit of force. Turning the pulleys as you put it on will help it go on evenly. If it is too stiff, put the belt in some boiling water for a minute or two to soften it up a bit.
Posted on Nov 04, 2008
  • 32 Answers
SOURCE: bosch 3283 dvs sander has unbalanced spin
This means the sander has been droped and the pad support and/or the bearing orbit has been bent, maybe even the motor shaft. Never leave any power tool sitting on a bench, always set it on the floor, it will end up there at some time anyways. You can try replacing a part at a time and spend a lot of money and time, but is it worth it?
Posted on Jul 18, 2009
rowdy45176
  • 2176 Answers
SOURCE: My Bosch 1276 DVS belt
that is possible, but was the tool operating properly first?? unplug tool and check the cord for any breaks, then what I would do is clean the tool as good as possible with compressed air and if you can remove the brush caps do so and check the condition of the spring and clean the area. DO NOT sand the brushes but look across the face to see if both look worn evenly. If you have a volt ohms meter check from the plug to the brush holder with the switch on brushes removed to see if you have continuity and if not then I would have to think the switch
Posted on Feb 12, 2011
My Bosch 1276 DVS belt sander abruptly stopped working. Could it be the switch?
Feb 11, 2011 | Bosch 1276DVS 4" x 24" Dustless Variable...
Sheets keep coming off during sanding
The sandpaper will come off for one of these reasons: 1. The spring clips are to loose to hold the sandpaper. 2. You are using sandpaper that the paper's either too thick for the clips to hold it or too thin to withstand the work you are putting it through. 3. (Most likely) You are pushing down on the sander too hard while sanding. These types of sanders work by their own weight with only a little help from you.
Dec 30, 2010 | Bosch 1297DK 14 Sheet Palm Sander Kit
Belt sander Craftsman 315.117150 The spring-loaded bolt that adjusts the front roller has an eye hole into which a spring is fastened to the roller. The eye has broken, consequently I am in need of a new...
Alright, I found the breakdown and it is not a very good one. I think I know the part number that you need, but I would feel more comfortable if you would look at it yourself, because the last thing you need is confusion.
http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Sander-Parts/Model-315117150/0247/0743000/00013345/00002?blt=06&prst=&shdMod=
You can also purchase this part right from the link. Their picture shows the spring actually attached to a small rod on the ordering page. Let me know if this helps.
Nov 26, 2010 | Bosch 1274DVS 3" x 21" Belt Sander
Bosch ROS not powering on
Checked the net for answers and got a couple of maybe's. 1.) Brushes, 2.) variable speed control, which some were direct wiring.
I tried the brushes firs and that has solved the problem for now. I guess the brushes stuck or somehow lost contact.
I got a parts diagram and found the brushes (will be covered with dust). Took the springs out and stretched them a little, replaced and the sander turned on. You will need to remove the top cover to do this. Verdit is still out as to long term performance. Not a great start.
My particular sander was lightly used (second project) and it has not been abused.
Jul 11, 2009 | Bosch 1295DVS 5" Palm Variable Speed...
Bosch 3283 dvs sander has unbalanced spin
Jun 02, 2009 | Tools & Hardware - Others
Bosch 3107DVAS Random Orbital Sander not working.
You must replace the fan assembly. The part number is
2606610901
Hope this helps
May 04, 2009 | Bosch 3107DVS Electric Sanders & Polishers
Toothed belt bosch 1274 dvs
Nov 03, 2008 | Bosch 1274DVS 3" x 21" Belt Sander
Tools & Hardware - Others Logo
41 people viewed this question
Top Bosch Tools & Hardware - Others Experts
Awesome12
Are you a Bosch Tool and Hardware - Other Expert? Answer questions, earn points and help others
