Question about Toshiba Satellite X205-SLI1 Notebook
Toshiba x205-sli1 how many video cards does it take?
Now i have taken it apart and found it has to different video cards, ls-3449p and ls-3443p. could this cause the video failure, or does has to be the same to work?
  • michael bell Dec 07, 2012
    when i took it apart, i found a large amount of dust balls i side the fan and heat sinks. i will clean it and try the paste and see what hapends.
  • michael bell Sep 14, 2014
    there it is done i have revived them and have been using them for almost 2 years now, but i am still looking for other solutions.
  • Toshiba Master
  • 5,660 Answers
In my mind it isn't correct.
SLI = Scalable Link Interface,
http://en.wikipedia.org/wiki/Scalable_Link_Interface
SLI means to have two, or more, graphics chipsets teaming up on the graphics task.
Two or more graphics chipsets used in an SLI -> CONFIGURATION.
Scroll down, read under -> Caveats
"In an SLI configuration, cards can be of mixed manufacturers, card model names, BIOS revisions or clock speeds.
However, they MUST be of the same GPU series (e.g. 8600, 8800) and GPU model name (e.g. GT, GTS, GTX).
There are rare exceptions for "mixed SLI" configurations on some cards that only have a matching core codename (e.g. G70, G73, G80, etc.), but this is otherwise not possible, and only happens when two matched cards differ only very slightly, -> an example being a -> differing amount of video memory <-, stream processors, or clockspeed.
In THIS case, the -> slower/lesser card <- becomes dominant, and the other card matches."
Meaning if one graphics card has 256MB of graphics memory, and the other graphics card has 512MB of graphics memory; it will operate at the SLOWER graphics card, graphics memory, rate.
In otherwords at the rate of the 256MB graphics memory, graphics card.
The LS-3443P has 512MB of graphics memory,
http://www.ebay.com/itm/Toshiba-Satellite-X205-512M-Video-Graphics-Card-Heatsink-LS-3443P-/370670017623?nma=true&si=1z6WXqlGkouFmRzOMNgmqRW8SK0%3D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
The LS-3449P has 256MB of graphics memory,
http://www.ebay.com/itm/Toshiba-Satellite-X205-256MB-Video-Card-W-Heatsink-LS-3449P-/130789325867?pt=PCC_Video_TV_Cards&hash=item1e73a6bc2b
Point;
Why would a laptop manufacturer go to the trouble of using two MXM style of graphics cards; in an SLI configuration; and use one with 256MB of graphics memory, and one with 512MB of graphics memory; only to have the graphics run at 256MB?
Doesn't seem logical.
Logic TO ME dictates using two ALIKE graphics cards, (MXM)
For me I concur with your thinking, and believe the 256MB unit is wrong.
http://www.irisvista.com/tech/laptops/Toshiba-Satellite-X205/take-apart-laptop-1.htm
http://en.wikipedia.org/wiki/MXM
http://www.toshibadirect.com/td/b2c/unavailable-product.jsp?poid=403632
GeForce 8600M GT uses the Code Name G84, GPU,
http://en.wikipedia.org/wiki/Comparison_of_Nvidia_graphics_processing_units#GeForce_8M_.288xxxM.29_series
http://en.wikipedia.org/wiki/GeForce_8_Series#GeForce_8600M_Series
http://en.wikipedia.org/wiki/GPU
Could I be wrong? YES.
It may be that the two ARE configured to run together, and have a total of 768MB graphics memory.
Again, though, To Me it doesn't follow the Scalable Link Interface, basic technology.
It MAY be that -> BOTH graphics cards need to have the top of the GPU, (Graphics Processing Unit, or simply - graphics chipset), cleaned; and new fresh Thermal Paste PROPERLY applied.
If a Thermal Pad is used, it is carefully peeled off, plus top of GPU, and copper Cooling Tube plate cleaned; and a new piece of Thermal Pad is used, PLUS apply a sparingly amount of new, fresh Thermal Paste.
Also using Anti-Static Precautions, (For everything, of course. Standard procedure), I would use a pencil eraser, and clean the gold plated contact pins of the MXM graphics cards; on BOTH sides. Use compressed air for computers, in the MXM graphics card's slots; on the motherboard.
IF one MXM graphics card is bad, you should be able to remove it, and just use the good one.
Perhaps this was a problem in the past; and whoever had it could only afford the 256MB LS-3449P.
In searching I found one place that wanted $549.00 for the LS-3443P!
Just my thoughts, Michael.
Regards,
joecoolvette
Posted on Dec 07, 2012
  • michael bell Dec 08, 2012
    i tried cleaning and new thermal paste, and same thing. the big problem i have is that i don't have any parts to switch for anything
  • joecoolvette
    joecoolvette Dec 08, 2012
    What happens if you take the LS-3443P out? Still no? Then leave it in, take the LS-3449P out. Just want to see if either graphics card is good. BIOS should reconfigure back to using just one MXM graphics card, and not two in an SLI configuration. When cleaning, may I ask if you followed Anti-Static Precautions, and what did you use to clean with? Are there small cables that connect from motherboard to graphics card/s? Do you have a multimeter, and know how to check the wires in the cables for continuity? (OHM's - 1K)
5 Suggested Answers
Basilio00920
  • 155 Answers
SOURCE: Toshiba wont turn on, has beeping after i press power
Check the memory modules. Test one at a time to see if any of them is damaged. If you have only one, try a borrowed chip, or test yur modules in a borrowed laptop (it doesn't have to be the same brand/model, only the chips must be the same speed).
Posted on Apr 28, 2009
nonontech
  • 4737 Answers
SOURCE: I have a Toshiba Satalite
If you haven't any mistakes with the connection, you're going to do a deep research. Your only solution will be from the Bios Settings. This issue is very common for Laptop users; it'll take time but I'll try my best to assist you step by step. I will also suggest you to make print out if you're gonna do it on the same computer you are using right now. Please be patient while I am preparing the tips for you so that you can understand better. Thanks.
Posted on Jun 07, 2010
  • 1542 Answers
SOURCE: Does the Toshiba X205-SLi1 have
Hi
i believe so
here is the manual if you need it you will probably need adobe reader installed to read it
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1854787&rpn=PSPBUU&modelFilter=X205-SLi1&selCategory=2756709&selFamily=1073768663
Posted on Mar 12, 2011
  • 525 Answers
SOURCE: I have a Toshiba Satellite
http://www.sparepartswarehouse.com/Toshiba,Satellite,X205,PSPBUU-00D00JB,Laptop,System-Boards.aspx $221 used $286 new
Posted on Mar 13, 2011
X205-SLI1 17" Notebook PC PC Notebook 3 beep
Memory problem:
Sometimes when the computer is moved or over time a memory stick can become loose causing the computer to be unable to read the memory or get errors as it's reading it. Try fixing this issue by opening the computer removing each of the memory sticks you have in the computer and then placing them back into the computer.
If you have more than one stick of memory try removing all but one stick of memory and boot the computer. If this does not resolve the issue try removing that stick of memory and try one of the other sticks of memory.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
May 23, 2011 | Toshiba Satellite X205-SLI1 Notebook
Satellite x205-sli1 will not boot black screen error beep 1long 2 short please help. Powers up good and reseated ram nothing.
Thank you for sharing the beep code. It means that its a problem with the Video Card and Video Cards are usually buit-in to the Motherboard for laptops. The only way to fix it to replace the Motherboard in order to get the new Video Card. Hope I've helped you somehow.
AnEspera
Apr 24, 2011 | Toshiba Satellite M65-S809 Notebook
Does the Toshiba X205-SLi1 have a recovery partition?
Hi joshpop1920,
"Go to this "Website!"
"Download the Manual!"
In the "Manual: search for the {Chapter} "System Restore."
It will explain the: [Recovery Process].
!Important: "Take a 'moment to rate the help', so I can get 'credit' for the work.
Thank you!" - paul7of9
Click here: http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=DL&os=&category=&moid=1854787&rpn=PSPBUU&modelFilter=X205-SLi1&selCategory=2756709&selFamily=1073768663
Mar 12, 2011 | Toshiba Satellite X205-SLI1 Notebook
Iam having a problem in my toshiba satelliate x205 sli1 it want start up it only gives me 3 bippes and no screen i cant see anything i removed all my rams and it still wan't run and don't even give any...
The beeps may be from the ram memory ..remove them and use one at the time and see if you get at least the devices or the logo on the screen ..the idea is to see if it is a ram issue or a video card ..
I think it may be the ram ..but ..the fact that it does nto show anything on screen is odd..usually even if ti is teh ram memory it shows a splash screen or so ..
If trying ram one at the time (in case of multiple modules ) does not make a difference ..you may try to see if an external monitor works ..This will eliminate the dead display ..
In the last case you should see what options have for a new video card ..the issue with this is the card may be on board ..and not having space for another one ..You may need to change the motherboard ..let me know what you've done ..and how it behaved..
Dec 10, 2010 | Toshiba Satellite X205-SLI1 Notebook
I have a Toshiba Satellite X205 SLI1, a couple of months ago my video card failed. Had no display, and three long beeps on startup. After replacing the video card, the system booted and was working fine...
check the power wires..inside ..maybe you didn't plug something when you changed the video card ..also you should check the new card for power needs..and see if it is a match ..some of them may be a problem in this matter .Anyway if you got a similar one this is not an issue ..
from what you say ..it seam a power mater and this is why I suggest to open it up and check all wires..even plug the charger with the board exposed..and check all plugs and wires and see ..whats all about ..If it does not power at all it may be the motherboard ..and probably you wired it wrong ..or it just gave up ..
Sep 06, 2010 | Toshiba Satellite X205-SLI1 Notebook
Pink dots on screen
Could be try connecting to an external monitor using the vga port. If the same problem appears on the external display the problem is most likely the video card. You may wan to update the display drivers.
Jul 27, 2010 | Toshiba Satellite X205-SLI1 Notebook
3 bits
I think when the tree beeps is on ..the blame is on the video card ..so unless you changed the video card as well you just made a wrong move ..The part that should be changed is either teh video card or the ram memory ..cause they are the only one that causes beeping when something is wrong ..So check the card it may be just not plugged well ..and the ram memory as well ..Unplug them ..and use them one by one and boot up and see how it behaves..Even if it is not enough ram in it for to run the operation system ..it should at least show the devices and the logo screen ..
Apr 09, 2010 | Toshiba Satellite X205-SLI1 Notebook
Toshiba x205 Sli1 suddenly died. Got 3 beeps.
3 beeps usually means that either the chipset or the processor is dead. Nothing you can do, take it to a repair shop.
Nov 06, 2009 | Toshiba Satellite X205-SLI1 Notebook
Getting 3 beeps when starting the comp. with no screen.
some prblm is dere wid d ddr1 or ddr2 compatibility...jst check d compatibility of d ram n insert accordingly..having fit at both ends...that's it...it's not a big issue...
Apr 11, 2009 | Toshiba Satellite X205-SLI1 Notebook
Toshiba Satellite X205-SLI1 Notebook Logo
221 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
