Question about Toshiba 46LX177 46 in. LCD HDTV
5 inch wide blue vertical stripe on lcd
I have a 5 inch wide blue vertical stripe on the screen. it is on the right side about 5" from the edge. the rest of the picture and audio is fine.
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
It can be but rarely the main board, most of these sets have either one or two boards that drive the image on the screen, different names like T-con or Y out etc. the right side board could be the problem or a bad connector or ribbon cable for that side of the screen unit.
Several possible cures and none are a snap to find in most cases.
Posted on Dec 06, 2012
SOURCE: Toshiba 40" LCD TV has bands each side where picture is brighter
Same Problem Here on different Toshiba Model. Did you get it fixed?
Posted on Oct 19, 2009
  • 280 Answers
SOURCE: fine color vertical lines in right and left side of screen
One of two things could be wrong.. One is the digital board and or connector. the second is that the LCD display is going bad..
Posted on Jan 30, 2009
  • 441 Answers
SOURCE: My 2 year old 37in Toshiba 1080 LCD HD tv has a dark shadow
it sound like one of the drivers is going out, not much you can do with out service
Posted on Oct 27, 2009
SOURCE: More of a Toshiba statement.
My 52 in regza has a vertical line on the right side as well just under 2 years old, out of warranty and to costly to repair, I paid $2500 as well. The TV has been on its stand since the day I bought it and has been moved once.
I have read of others who have this problem as well, just google toshiba regza red line, or vertical line
I Too will never buy Toshiba products and I will tell everyone I can about the **** LCD Toshiba
Posted on Feb 05, 2010
  • 3 Answers
SOURCE: Regza 52 inch LCD has a green and red line running
I have the same problem which started at about 10 months and became full blown after 14 months and now the warranty is up. TOSHIT BA 52u645
Posted on May 25, 2010
Vizio XVT3D650SV 65-Inch Theater 3D Edge Lit Razor LED LCD HDTV has a black vertical 6" wide line on the right side of screen. What is causing this problem? Is it the T-Con board?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Line faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent. Line faults to all LCD screen are similar, irrespective of its brand and screen size.
Feb 23, 2016 | Vizio Televison & Video
Tip
How to Troubleshoot Vertical Lines on an LCD TV Screen
<p>There are two prevalent formats for video programming: full screen and wide screen. LCD TVs are designed to show a wide screen picture to go with high-definition (HD) programming. When standard-definition (SD) programming is watched on an LCD HDTV in its default settings mode, there will be two vertical lines on the right and left sides of the picture. You need to go into your TV settings menu to troubleshoot this issue.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span><br /></span> <span>Instructions</span> <ol> <li> 1 Press the "Menu" button on your remote control and open the "Picture Settings" sub-menu.<br /> </li> <li> 2 Select "View" from the list of options.<br /> </li> <li> 3 Choose a viewing mode that will eliminate the vertical lines. Select "Zoom" to crop the on-screen image to fit the screen. Select "Wide/Widescreen" to stretch the on-screen image to fit the screen, or select "Panoramic/Panorama" to stretch the sides of the onscreen image to fit the screen (recommended).<br /> </li></ol>
on Dec 27, 2010 | Televison & Video
LG MODEL 55LM4600 THAT HAS A VERTICAL SHADOW ON THE RIGHT SIDE OF SCREEN ABOUT 3 OR 4 INCHES WIDE. hAVE YOU HAD THIS BEFORE?
Line fault. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Jun 03, 2015 | LG Televison & Video
My RCA L42FHD37YXII has dark green and light gray vertical stripes on left side of tv it is on all connections
the screen might be broken. when that happened to one of mine i found a crack on the edge of the screen in the glass/plastic? type stuff but it only affected the aria right near the crack. found out my roommate chucked his glasses at it. if not idk
Sep 30, 2012 | RCA L42FHD37 42 in. LCD HDTV
Vertical gray stripe on left edge, all pics and text gave a blur
any vertical or horizontal line (any color any size) showing stable on the screen that is the hardware damage at the LCD panel back board ( call panel driver board) . it repair complicate but easy to do change LCD panel (common parts). you need find a PC service dealer to do so.
Feb 07, 2009 | Dell E207WFP LCD Monitor
Dark vertical stripe on monitor
You screen "LCD" is broken , need new lcd panel. Very expensive
Feb 01, 2009 | Samsung T220HD LCD Monitor
42" Panasonic Plasma - Vertical red stripe 6" from left side
We originally had a red stripe roughly 3" wide running vertically on the ride edge area of our Panasonic 52" Viera plasma tv. It has now been joined by a solid black stripe of the same width running from the top to the bottom. Living in Germany and purchased at local PX long enough ago that the warranty is likely expired. Now what?
Jan 18, 2009 | Panasonic TH-42PD50U 42 in. Plasma EDTV
Blue vertical stripe
The bad news, it sounds like tou have a bad plasma panel.One of the vertical drive arrays are in the process of failing.This part is part of the display panel.
Mar 02, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Dark Vertical Stripe on Right Edge of Screen
I experienced the same approx. 1/2" vertical stripe on a Viewsonic vx1945 and ATI Radeon x1050 video adapter on Vista Business SP1, but the stripe appeared along the left edge of the screen, instead of right edge. I then temporarily decreased the monitor resolution, and the stripe went away. I then increased the monitor resolution back to its original setting, and the stripe did not re-appear. So, that was the 'fix' in my situation, hope this helps.
Dec 11, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Toshiba 46LX177 46 in. LCD HDTV Logo
189 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
