Ilost some of the channels on my panasonic tv vhs combo how can reset it my model # PV-M1323 THANK YOU
I GET CHANNEL 2 THRU 6 THEN GOES TO 14 . SKIPS 7 HTRU 12 AND IF I PRESS MANUALLY ANY OF THE CHANNEL THAT AM NOT GETTING A BLUE SCREEN
    Top Expert:
  • Televison & ... Master
  • 14,553 Answers
What you have is a bad tuner in the set---2-6 is low vhf band-7-13 is the next band--14 and above is the next band of channels---clearly your 7-13 band is bad.
The tuner may be able to be removed and the board inside it resoldered---a replacement tuner even if available would cost more than a new unit.
Posted on Dec 06, 2012
  • 9 Answers
SOURCE: I have a Panasonic TV/VCR combo my kids deleted
A universal remote can be programmed for your tv/vcr. Then you can access the menu to auto program your tv. Otherwise there should be a button on the front that allows you to access the menu and then auto program the unit.
Posted on Feb 18, 2009
pgh_pa_guy
  • 2992 Answers
SOURCE: Only goes up to Channel 19.
Go into the TV's setup screen and make sure its tuning mode is set for "cable" (may say "CATV"). I'm not familiar with this set so I don't know exactly what the screen will say, but there should be some reference to channel setup, TV setup, tuning band, etc. It's probably set on "AIR" now.
Normally, when set for off-air reception, the set works properly for channels 2 through 13, and 14 up don't tune properly. Since you're getting channels up to 19, there may in fact be some kind of tuner problem. If the TV is already set for cable tuning, you may have found why the former owner was freecycling it. But check that tuning mode.
Posted on Apr 06, 2009
SOURCE: Blue screen?
I read about a similar problem and used the cords that came with the ps2, that ended up working. I also just bought a remote for the tv, so that fixed the channel problem.
Posted on Jun 12, 2009
  • 476 Answers
SOURCE: Panasonic pv-c1350w channel/clock auto set
You are probably talking about the main menu that appears when the TV is taken off the AC power outlet, to get rid of this page just turn the tv off and on again and it should give you access to what ever channel was tuned before, if your game console has an RF out, your TV should be set to channel 3 ir 4, if the console has composite outs the change the channel until the TV goes to Aux in or Video in. Retrevo.com has an instruction manual available which you can download free, just in case you need more informantion, if the channel keys do not work, then you may have to get a universal remote ,they are fairly inexpensive and will come in very handy at least for the basic functions or just have theTV worked on.
Posted on May 12, 2010
SOURCE: Remote code for Panasonic TV/VCR combo
Use the RCA universal control programing the code 109 in vcr funtion and will work..... i try and work....
Posted on Nov 23, 2010
How do i hook it up to my tv
The simplest way is to connect the screw on connector marked Output on the back of the VCR to the screw on connector marked antenna or cable input on the back of the TV. There will be either a switch or menu item on the VCR where you chose to have it output on channel 3 or 4. Chose which you prefer and then tune the TV to that channel.
Sep 30, 2014 | Panasonic Pv-9400 Vhs Vcr Hi-fi Video...
We have no remote. Is there a way that I can get my tv to stop on channel 3? It just goes from channel 2 to channel 4 and does not allow 3 to come on -- skips right over it . I just need to use it for a...
it simply means that channel3 has been set to skip/go to the tuning menu and select manual search.select channel position3 and cancel channel skip function.
Oct 05, 2013 | JVC AV-32F703 32" TV
May 12, 2010 | Panasonic PV-C1350W Combo
I have a 1990 panosonic tv vcr combo,I have the remote but can't seem to add any channels above channel 13.model is pv-m2028-k.the remote has add /delete button and I can delete a channel and add it back...
No,all CRT tvs can't get digital signal,all CRT require a digital converter box,if u don't have pay tv.Yes the converter box hook up it getting the digital signal from the box,not the Analog tv.
Mar 13, 2010 | Panasonic PV-C1323 13 in. TV/VCR Combo
VHS tape only partially goes in & then automatically ejects Panasonic PC-C1332W 13 in TV/VCR combo
sounds like there is a tape in it you are not aware of ,it may have one (vhs tape) stuck in it.
larry
Nov 22, 2009 | Panasonic PV-C1332W 13 in. TV/VCR Combo
When I connect my PVC 1320 to a converted box I
used converted box vedio ouptu to vcr pv-c1320 vedio input used VCR LINE...
Wach tv...
Sep 17, 2009 | Panasonic PV-C1320 13 in. TV/VCR Combo
I lost my remote control for my tv/vhs panasonic omnivision
how do you access the menu without the remote panasonic omnivision tv vcr combo
Mar 31, 2009 | Panasonic PV-C2010 20 in. TV/VCR Combo
Panasonic PV-V4021 VCR.
An analog VCR can only be used the same way as an analog TV. You should be able to set the VCR to the converter boxes output channel ( 3 for example) and then set the VCR to record that channel at the correct times. Then just tune the converter box to the correct channel. Please note that if you try this while you are at home (recording one thing while watching another) you will wind up recording whatever is on the channel you change to.
Oct 11, 2008 | Panasonic PV-V4021 S-VHS VCR
Just want the Orion TV (Model: STV 2763) to play VHS videos
Problem Solved:
Take your connector with the 3 colors red,white & yellow and plug into VCR OUT. The other end (w/ 3 plugs) goes into the INPUT on the back of the TV. Next insert a VHS Tape & search the TV for input or a channel below #2 for Cable#1,2,3 or AUV Channel.
In this case; Channel AUX #1
Shows / Plays Video w/ clear sound & picture.
Yahoo.
May 21, 2008 | Orion STV2763 27" TV
Just want the TV to play VHS video
check channel and check plugs
Televison & Video Logo
48 people viewed this question
Top Televison & Video Experts
Electro Med Services...
