Question about General Electric GE GLDA690PBB Tall Tub Built In Dishwasher
Dishwasher flooding water is not emptying
  • 3 Answers
You can try checking the water level sensor/pressure switch hose/tubing has no holes in it or that the switch/unit is not faulty. A dishwasher will pump water out as soon as it is turned on. This is to ensure any remaining water that has collected in the unit is pumped out before filling for normal use. So if the drain pump does not pump out at power up, either the pump is faulted or the control board is faulted or (less usual) broken wires, connector plugs at control board or pump have come off. If the pump works, then the problem will be with the water level sensor or the tubing that joins the sensor to the dishwasher tub. Hope this helps. Any electrical work should be done by a licensed electrician.
Posted on Dec 06, 2012
Why is my dishwasher running without water?
It is likely the sound you are hearing is that of the pump motor which is triggered because the flood switch has been triggered. This means the dishwasher is trying to empty itself to avoid damage likely casued by water leak. You need to find out why the flood switch is triggered. It would be helpful if you provide the model number of the dishwasher.
Jan 12, 2013 | Kenmore Dishwashers
Water empties immediately DW711
It will be a fault with the water level sensing circuit, try adjusting the inlet tap pressure as it is a time fill and if the pressure is too high or low it will pump out. Also a flood switch fault could cause the same issue.
Mar 12, 2012 | Jenn-Air 24 in. DW711 Built-in Dishwasher
I just bought a dishwasher SE34E200SK. The washing program always gets stuck in program 3 and it cant move further unless one has to turn it manually. Also it doesnot empty out the waste water after...
Hello
Most faults can be referred to the fact that the Anti Flood Overflow device has activated.
Modern day dishwashers like those manufactured that have a built in safety feature protecting the dishwasher against flooding. The technical term is 'Anti Flood Device'.
In the base of the dishwasher in the plinth there is a float switch. This is your 'Anti Flood Device'. In the event of your dishwasher over filling, the plinth fills with water, the float rises and actuates the switch.
Firstly, it will send a signal to the programmer device to notify there is a fault and output a message in the form of a code to some sort of display.
Secondly, the pressure switch acts as the water level indicator for the sump of the dishwasher so when the water level rises the pressure switch will activate the drain pump.
So before you consider throwing good money at new dishwasher, try doing a bit of fault finding your self and you might save yourself a ton of money.
Sep 10, 2011 | Dishwashers
Flooding in both drawers of dishwasher
I suppose "flooding in both drawers of ..." implies water is not draining out. Is that right?
It is a very little information to give you any clear solutions.
Did the water get into the drawers without starting any wash program? Most likely it is the backflow from kitchen sink back through the dishwasher drain hose. Does your kitchen sink plumbing have an air gap sowehere. If so, is it clear?
If the water is the back flow then it is likely to be smelly and you do not want to run it through the dishwasher. I would suggest take the drain hose out from under the sink downpipe and drop into an empty bucket. Then take all the fixtures out from the drawers and empty out water using a small container.
Put the washer arms back and run each drawer on a short rinse cycle collecting the drain water in the bucket. If cycle runs clear, then get plumber to check the kitchen downpipe.
Reconnect drain hose.
Hope this helps.
Dec 28, 2010 | Fisher DD603FCSS Dishwasher
THE anti flood device has been activated. I have emptied the salt tank, how do I reset the safety valve on the water inlet hose?
The answer is that you don't reset the anti-flood device. The anti-flood device re-sets itself when there is no risk of a leak. I don't really understand why you emptied the salt tank . . . ?
I cannot help you any further than this as you haven't specified your brand and model of dishwasher. If you can post these, I will try try to help further - if it's a model I support.
Oct 17, 2010 | Dishwashers
Bosche dishwasher serial no, SGS 456 . The machine won't admit water, but it makes all the washing sounds
Are you please able to provide the actual model no. of the bosch dishwasher. The serial no. is not much help.
The reason it may not be admitting water is because the flood switch may be triggered. This means it will not take any more water and the sound you hear is the pump running to empty the dishwasher. YOu will have to find why the flood switch is turning on. Are you using the AquaSafe circuit in the dishwasher inlet circuit? If water is leaking then this circuit will trigger and stop water from coming through inlet. But then you should also get some alarms on the display.
Please provide the model no.
Sep 30, 2010 | Bosch Dishwashers
Drain pump running when unit starts but no water to appliance
The machine probably has water in the base (not visibly in the machine, but in the base where the conponents are). Pull the machine out, sit the front on a large towel and holding the back of the d/w pull it towards you. Any water trapped in the base will drain out. It may be a fair amount as the flood safety switch will activate on approx 1.5 ltrs. Once you've cleared the water run a prewash or quickwash to check d/w. Hope this helps.
Jul 05, 2010 | Bosch SHU5315UC Dishwasher
The dishwasher fills up it starts to spray the water but after 5 seconds it emptys. It then does the other the rest of the wash normally. This happens in all modes.
Check to see if water at the base of the washer has caused the "anti flood system" to trigger. The anti flood device is a polystireene float and micro switch that does trigger (and puts the washer in pump out mode) once water via leak or spill is detected. You can tilt the washer to 45 degrees and check if a small amount of water comes out of the bottom. As you indicate that the washer emptys after 5 sec I do think that the anti flood system is causing this.
Apr 21, 2010 | Whirlpool Gold 24 in. Built-In Dishwasher...
Keeps flooding: pump comes on when switched off.
This sounds like an inlet valve problem, Replace it. Often a dirt particle gets in the valve.
Nov 01, 2009 | AEG 18 in. Favorit 44630W Slim-Line...
Water flooding out
Hi KellyW,
The dishwasher drain hose may be clogged.  When the dishwashr starts up can you hear the water running into the Sink faucet drain. If not inspect the hose that attaches to the Sink Drain for restrictions.  Also in the bottom of the dishwasher you should have a filter.  If this filter is clogged you cannot expel water.  Clean the filter.
Oct 23, 2007 | Asko D1776 Stainless Steel Built-in...
General Electric GE GLDA690PBB Tall Tub Built In Dishwasher Logo
82 people viewed this question
Top General Electric Dishwashers Experts
Dan Webster
Dan Webster
Are you a General Electric Dishwasher Expert? Answer questions, earn points and help others
