Question about Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive
The Driver for "USB MASS STORAGE DEVICE" is disabled ... is there any way to fix teh same
  • 2 more comments
  • sanjana_kish Jan 12, 2009
    This is the thing that is displayed
    let me explain you better, the USB ports are working fine for my USB mouse and keyboard but not for the USB Mass Storage Device (Pen Drive). If you can observe the picture which i had posted earlier, the USB mass storage tab showed with yellow icon..which means that the drivers for this is not available or isntalled properly.
    The same port was working fine until few days back and i was able to use my drive but not now. Let me know how best i can correct the drivers issue
  • sanjana_kish Jan 30, 2009
    Mine is Dell Optiflex 740. Seems the USB2.0 drivers are disabled. Please let me know how can i enable the same or Install the drivers and the website from which i can achieve the same
  • Anonymous Mar 14, 2014
    USB Mass Storage Device(USB 2.0 SD/MMC Reader USB Device)
    President:
  • 373 Answers
Go to My computer>right click>properties>Hardware>Device Manager
find the Universal serials bus controllers expand it, find the usb port right click on it> select enable.Please do post further comments.
Posted on Jan 12, 2009
  • Suresh Thrithandam Venkata Lakshmi Narayana
    There might be more than a single USB option in the device manager.Expand the USB connections, right click on each and find the disabled one and enable it.You can repeat the same if you want to disable it.
    yeah> In the same, expand the USB field. You might find something like this(check the image for reference). Just right click and you find the options like in the image as follows.
    Novelist:
  • 210 Answers
From what I can see, the device is not recognised by Windows. Likely, this is because you do not have the USB 2.0 drivers installed. Your mouse and keyboard will use USB 1.0 (which I can see as being installed).
You should check the website for your mainboard manufacturer and download the driver accordingly.
Let me know how you go!
Posted on Jan 29, 2009
Lexar JumpDrive S70 - USB Flash Drive - 8 GB disconnect
this could a problem with an unstable driver you might have to unistall the driver restart your computer then reinstall the driver
if you motherboard came with a disk the drivers could be on it
otherwise you might need to download them
or a bad dusty or loose usb lead connection
click start control panel administrative tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
you will need to update/reinstall drivers
right click to reinstall drivers
if you can see your usb drive but its not working
ports (com&lpt) right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems to a computer and its parts
you will need to download one try one of these
http://download.cnet.com/usb2-0-driver-zip/3000-18493_4-163914.html
http://download.cnet.com/usb-2-0-root/3000-18493_4-55793.html
http://download.cnet.com/usb-mass-storage-controller/3000-18493_4-161651.html USB Mass Storage Controller
http://download.cnet.com/via-usb-2-0/3000-2098_4-10163319.html
Install a USB 2.0 host controller driver
hope this helps
Aug 14, 2012 | Lexar JumpDrive S70 - USB flash drive - 8...
Cant find driver for SimpleTech 250gb external hd. Is it available?
Should not be necessary. It is recognized by the system automatically. Try connecting to another port, check the data cable and the connection to the unit, it may be corroded or loose.
Sep 13, 2011 | SimpleTech 250GB USB2.0 7200 RPM External...
I an not have driver usb for hdd2193 for fix problem
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question / exclamation mark? ! or a red X
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
if you dont have a motherboard disk you will need to download the drivers
Intel PCI to USB Enhanced Host Controller NEC PCI to USB Enhanced Host Controller B0 NEC PCI to USB Enhanced Host Controller B1 USB 2.0 Root Hub Generic USB Hub VIA PCI to USB Enhanced Host Controller
hope this helps you
Sep 11, 2011 | Toshiba MK4026GAX (hdd2193) 40 GB Hard...
I;\IS NOT ACCESSIBLE ACCESS IS DENIED
USB drives can be write-protected by modifying the StoreageDevicePolicies Registry key and WriteProtect Registry value.
click Start>run>regedit to open Registry Editor. and press control+F to open the find dialogue box and type "usb device" or "driverdesc" to open usb mass storage device or type "usb mass storage device" in the search windows. And right click on it and delete. This will set the policy value to 0. then insert your usb device. It will work fine.
# Remember: do not delete any unknow files in the registry as this will make some programes not work as usual.
also
If you are running a Windows XP OS then you might be able to:
- click start right click on my computer select open
- Right click the icon of your Flash Drive (It should be F:/ or something)
- Click Properties in the menu that comes up
- Click the Sharing tab
- Click permissions
- And finally, click Allow next to Full Control.
also you might
click start control panel administrive tools ,computer management ,device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers or
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts also
scroll to disk drives if you can see your drive + to expand right click you should see options to update driver,disable,uninstall scan for hardware changes. or
select properties you should see options in the general tab to troubleshoot,policies,volumes,driver and details under the driver tab you will have the options to check the driver details,update driver,rollback driver or uninstall
hope this helps
Mar 18, 2011 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I need to reinstall driver for USB mass storage device
control panel admistrive tools,computer management,device manager you should see a yellow question mark? right click to reinstall drivers
hope this helps
Sep 02, 2010 | Maxtor Personal Storage 3200 (U01E200) 200...
My WDBAAU0015HBK external harddrive don't boot when i start up my computer. It says initalising USB divices and then when it autodetect the USB mass storage devices it stops. In the BIOS i put the boot...
It sounds like the BIOS is set to auto-boot from the USB device.
Have you reset the 'boot order' in the BIOS?
Also if you are still running sp2 go to Microsoft update and install the updates. You should be running on service pack 3.
(the updates are free, and are more secure than sp2)
Jul 20, 2010 | Computers & Internet
Samsung Pleomax SAM MD-205 driver?
It took me a lot of digging to try and find a driver download. You can try the UHD25-80GB driver (this is for Windows 98, but you can try to see if it fixes the problem): http://www.samsungpleomax.com/sup_03_01.asp?page=2&fcate=Driver+download&scate=Storage+Media&tcate=HDD&scateg=Storage%20Media&tcateg=HDD. Direct link to zip file: http://www.samsungpleomax.com/sup/cs/HDD-driver-2500-80GB%20DRIVER.zip
Also, specs indicate that you need USB 2.0 or 1.1. I had problems connecting via a 4-port hub (that was supposed to support USB 2.0) so ended up connecting directly via my computer USB ("Enhanced" = 2.0) slot, which seemed to work fine.
Apr 04, 2009 | Samsung Zirex Pleomax 80GB Portable Hard...
Laptop VISTA basic will not recognize 3.5" Nexxtech enclosure as mass storage device
run diskmgmt.msc there it will show all disk drives. if it detects usb mass storage and the hd is not showing. soulds liek hd is bad or jumper set wrong
Apr 28, 2008 | NexxTech Portable Hi-Speed USB 2.0 Kit...
Vista and USB Western Digital HD
Try to use another USB port might not compatible with greater that 2.0
Nov 19, 2007 | Computers & Internet
Kingston (SDCZ2-512-A10-KT) (SDCZ2512A10KT) .512 GB Hard Drive Logo
87 people viewed this question
Top Kingston Computers & Internet Experts
Brian Sullivan
Brian Sullivan
laikexpert
laikexpert
Florin
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
