Question about Kenmore Refrigerators
Kenmore Refrigerator Model No. 795.78312.802 is not working. Even lights won't light.
Is there a reset button so we won't have to pay for an expensive service call?
peyton32034
  • 410 Answers
SOURCE: Kenmore refrigerator light does not work
there is a tab in the bottom of the light socket that can get bent so that it wont touch the base of the new bulb. unplug your refrig and use a small screw driver and bend the tab back out a little bit so that it will contact the new bulb...
Posted on Dec 12, 2007
  • 56 Answers
SOURCE: lights, ice maker and led do not work (Model 690)
I assume you took the switch out. If you did you cannot see the control board because it is backlit by the lights. If the unit is working you are fine. TO verify put a flashlight to the display and see if you can read it. You can call the factory at 800-222-7820 for more help on monday.
Posted on Feb 22, 2009
SOURCE: Kenmore Trio lights staying on melting the bulb housing
Thanks, FixYa, for posting this problem. My husband and I were about to buy one of these and were able to save ourselves a headache. We found out some updated information obtained from Sam, a lead tech at the national Kenmore service center, 888-536-6673:
There are 4 potential manufacturers of this fridge type, only 1 of which made the faulty part, which was apparently finally recalled last month. You cannot tell the manufacturer by the brand name, only by the first 3 digits of your trio fridge's MODEL number (usually listed somewhere on the fridge as well as on the printed manual you received at the time of purchase):
795 -- LG Korea -- some fridges affected, determined by SERIAL number
596 -- Amana/Whirlpool -- not affected
464 -- Maytag -- not affected
106 -- Whirlpool -- not affected
If you have a model number beginning with 795, call Sam or his colleagues, reference the service flash sf46-515, and have them look up your fridge by serial number to determine whether your fridge contains the recalled part. Good luck to all of you, and thanks again!
Posted on Apr 09, 2009
woodchuck789
  • 4066 Answers
SOURCE: Need a service/repair manual for a Kenmore refrigerator.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Is the evaporator fan in the freezer running. It blows cold air into the fridge side through a damper in the wall between the freezer and fridge. Make sure the damper is open.
Below the evaporator fan is the evaporator coils. Remove the back cover in the freezer to observe the frost pattern. Light frost everywhere(NORMAL) or a partial pattern of ice(LOW ON FREON) or nothing(LOW FREON OR COMPRESSOR PROBLEM).
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Part 4 on this diagram is your timer http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=1069608210&productCategoryId=0160000&brandId=0582&modelName=REFRIGERATOR&diagramPageId=00003&componentDescription=COMPARTMENT%20SEPARATOR%20AND%20CONTROL&documentId=00050440&backToLink=Return%20to%20subcomponent%20list
Posted on Aug 13, 2009
SOURCE: electrolux refrigerator power failure light
I'm encountering the same problem. Also, my ice and water lights are now both on. Any ideas?
Posted on Jun 02, 2011
Kenmore filter ligth reset
Usually just hold in the button for 3-5 seconds. It does depend on model # some models you push in the ref light switch 5-6 times. If you have complete model # would help
Aug 31, 2014 | Kenmore Side by Side Refrigerator
Dishwasher won't start and start button doesn't light, but other buttons respond
I think you still have warranty, it sounds you have faulty control panel, even if it's new does not mean it is good.
Mar 19, 2013 | Kenmore Dishwashers
My kenmore front load washer doesn't want to start all lights are working but nothing happens even the door won't lock
your door switch is the problem,where the door latch goes into the machine a little switch sites behind this a safety feature and if this is broke the machine will still switch on but will not work it will need replaced they are cheap.adrianxxx
Jun 02, 2012 | Kenmore 44072 Front Load Washer
Kenmore elite dishwasher mdl 665.16919001 all lighs out, won't come ont
try a simple step to reset unit unplug and then plug back in
May 26, 2012 | Kenmore Dishwashers
I have a Kenmore side by side, model#106.52572. My power went out Wednesday night and the freezer & refrigerator sounds like it's running but it won't cool and the icemaker even sounds like...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Aug 26, 2011 | Kenmore 57029 Side by Side Refrigerator
New filter installed. how to turn off "change filter" light
There is usually a reset button near the change filter light. Without the model number I cant tell you exactly where.Please comment me back so I can further assist.
Jul 30, 2011 | Refrigerators
Model #25352344300 the filter(reset) light stays on even after I change the water filter why?
Hello, Thank You for using FixYa. I will be helping you today.You have to hold the button in until the light flashes.
Thank You and please rate my answer if it was helpful..
Jun 17, 2011 | Kenmore Side by Side Refrigerator
Refrigerators Logo
136 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
Jim Goldsmith
Jim Goldsmith
Jude24
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
