Spinner does not work
I have a Kelvinator2 toploader washingmachine but the spinner does not seem to work. The spinner just stop after a few seconds and then the water runs again into the machine.
    Scholar:
  • 89 Answers
Could be a few things here but lets start with what its not. it is agitating (pardon thespelling) so we know that its not the motor or belt or agitation gear. the next thing that we should look into is the switch inside the control knob. just like with your dryer,you should hear a click. thats the switch. if the motor isnt coming on after that then its probably that switch. you will need to take the control panel apart and disconect the wire from both sides of the switch. then turn your multimeter to the contenuity setting and simply turn the switch over and over and see if the number changes. if it doesnt then it could be the wires or maybe even a relay of some sort, but i figure first things first on this trouble shooting job.
Posted on Jan 12, 2009
How do i fix error 149 on my avantra 30, the spinner start and stop after few seconds
Check the alignment and contact surfaces. Any bearings that allow the arm to spin when cold, may tighten up when heated and cause the arm to slow down or stop.
Jan 04, 2015 | Dishwashers
Where can I buy a salad spinner? It'd be a bonus if it had a brake in it to stop the spinning.
With a brake!! enjoy :)
http://www.target.com/p/oxo-salad-spinner/-/A-628331
Jan 14, 2013 | Home
BonJour 3450-70 Fresh Spin Automatic Salad Spinner
how do you put the lid together just below the area of the top? Friend went to wash spinner and pulled on top and now I can't get it to sit flush anymore. It seems there a two plastice prongs inside top that must be released. Help please. Love this spinner but now can't use!
Nov 18, 2012 | Washing Machines
Shake side stuck up but not drowing because that white spinner stayed down i suspect the spinner need to be changed all this happend few days after brushcleaning so not lubricateing issue
Could be a number of things;Check freezer door properly installed,improper lubriction of draw valve,the dispensing mechanism is out of alignment,draw valve binding on door,the solenoid plunger is binding in coil body, draw solenoid set too high or the drive spinner has disengaged from the spinner blade assy.Check the last thing.
Jan 27, 2011 | Taylor Ice Cream Makers
Treadmill stops after 7 seconds
you have a broken spinner. Take hte motor cover off and look on the opposite side of the motor. there will be a partof the spinner wheel there. I have yet to find a way to short cirut the connectors nor a replacement wheel.
Feb 16, 2010 | RTO Image 15.0R Treadmill Walking Belt
How to use salad spinner
Just plug it and press the power on button.Make sure that you plug it in the correct power.
May 18, 2009 | Food Processors
Ryobi weed eater 30cc
Drain all the gas/oil mix out of the system. Press the red prime bulb several times until there is no fluid in the line. Pull the spark plug and clean it with a soft dry rag. Reassemble and fill tank with 2 cyl/gas mix. Prime it, then pull several times on the start cord. That should work.
Aug 05, 2008 | Electrical Supplies
Washing Machines Logo
100 people viewed this question
Top Washing Machines Experts
