Question about Honeywell Heating & Cooling
New fan/motor for A/C
Hi. Our A/C needs a new motor/fan. It won't turn on at all now. It is an old unit but when it was surviced a little while ago, the guy said that it was still in goog shape. Can someone come out and give me a quote? Thanks, Nicole
    President:
  • 373 Answers
Found a link that might help you out.Click on the following.
click here
Since i did not know the brand name, i gave you the fan list and quotations for several other brands and models.You can select the one that matches you AC and fine its price and shipping orders right next to it.Please do post comments if you find it difficult to browse through the website.would be glad to assist.
Posted on Jan 12, 2009
Condenser fan replaced one year ago, fan not turning but can hear motor
the answer to your problem is most likely the motor start capacitor. A AC motor can run in both directions. The start capacitor is used to cause the current to lag behined the voltage which determines the direction the motor will turn. Its posible the start and run capacitors are in one can. so changing one will change the other. However look for a wiring diagram. Do not asume that both capacitors are wired in properly. They may be fighting one another causeing premature failure.
Sep 18, 2012 | Carrier 38CKC036 Air Conditioner
My model 8663RP "B"-Unit Combination
It sounds like the fan blade may be loose on the motor shaft. You can purchase a new motor for this fan online.
Look here: http://www.centralvacuumstores.com/Bath-Vent-Fan/NuTone/Motor-Assembly/S97017705-Motor-Assembly-.php
http://parts.broan-nutone.com/nutone/Shop?actn=quicksearch&searchtype=all&indextype=7&keyword=8663rp&Search.x=0&Search.y=0
May 02, 2011 | Broan-NuTone N-8663RP Combination Light...
FAN DOES NOT GO ON AND CAN THE FAN MOTOR JUST BE CHANGED WITHOUT REPLACING THE COMPLETE UNIT ??
Yes and maybe.
If you open unit, usually fan motor is plugged in, and motor is removable with bolts.
The problem is finding new fan that fits same housing without spot-welding and drilling.
I did google image search for "replacement vent fan motors" and results show choices.
For example Nutone:
http://nutoneproducts.typepad.com/nutone-products/nutone-bath-fans/page/2/
If you can locate same brand vent at local box store, you can use parts from new one to repair old one without project of replacing fan housing.
20 years ago, motors went to electric repair shop and they rewound the motor.
But today, motors are landfilled or shipped overseas for recycling.
All costs are energy, and right now, cost of re-wind is more than buying new motor, or new vent.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on fan or any do-it-yourself project.
Fixya is always less expensive than a service call.
Feb 21, 2011 | Panasonic WhisperCeiling Bathroom Fan...
2 of my hampton bay ceiling fans stopped turning-one that was installed 6 years ago and one that was installed 2 months ago. I can hear the motor vibrating when it is turned on. Do I need to replace the...
mcdevito75 here, On the fan you hear, carefully turn the blades by hand just a little and see if they start up on there own. These motors are sealed units and maybe the oil is a little thick from non-use. If the baldes don:t start up, Then I would replace the fans.
Jul 26, 2010 | Hampton Bay 24002 Ceiling Fan
Blower motor on my Ruud furnace won't turn on when the a/c is on also won't turn on manually
You need to buy a new fan motor. If you could have turned the fan with your hand all you would have needed would have been a capacitor. If your filter is always dirty or the a coil is dirty will shorten the life of a fan motor. Just for things to consider in the future. Now if the unit is about 10 years old just wore out. Get a new capacitor when you get new fan they are cheap well 5 bucks any way.
Jul 07, 2009 | Ruud UBHC Air Conditioner
Old capassitor has 3 prongs new capassitor has 2 prongs
The old motor relied on a leg off of the ol cap marked FAN. No need to bother with it anymore because the new motor probably has a different cap rating therefore it needs its own wittle capacitor. Cute ain't it? That new motor will probably have a common wire to connect to that Old cap at the C mark on it though. It will have 2 brown wires to connect to that new cap for it. (insulate that cute little cap to prevent any shocktastrophies) The black wire will of couse go to wher the old one did on the contactor. Read a little ditty I affectionatly wrote for further info entitled 'old motor had 3 wires new motor has 4 WTF"
Jun 06, 2009 | Heating & Cooling
Compressor fan motor runs backwards
Most likely a bad motor or bad capacitor. I would check the capacitor first as this is probably a $20 fix. The fact that it runs in the correct direction but at a reduced speed really leans hard to the capacitor.
Good Luck and hope this resolves things for you. Let me know.
May 09, 2009 | Goodman CKL24AR24 Air Conditioner
I have a tempstar 2000 heat pump approx 5 years old. The condenser fan blades will not rotate/operate; however, I can hear the motor hummming. When the unit is off, I can rotate the fan freely. When the...
I think this is a double problem post,so I will answer the top first.
The fan capacitor may be bad or the motor it's self is seizing up and will need replaced.
Second portion of post:
  1. Brown and brown/white go to the new capacitor(If you didn't get a new one with the motor,You will need to)Should be 7.5 mfd
  2. Black To the contactor where the black was originally connected
  3. yellow to the contactor where the red was originally connected
May 06, 2009 | Heating & Cooling
Heating & Cooling Logo
47 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
