Question about Philips Desktop 9750 Desktop Digital Transcriber / Recorder
Philips Desktop memory card files troubleshoot
  • Delene Gunderson Dec 06, 2012
    Conference Recording System LFH0955 - My memory card recording plays back on my Digital Pocket Memo but will not play on my Philps Transcription 9750 Desktop.  Will not let me skip forward or skip back between files. Only stays on 1 and shows no recording.  Please help.
Password unknown
Place the micro SD card into your card reader on your computer.
Right-click your "Start" button and then "Explore".
Find the micro SD card, it will be listed as a removable drive.
Click on the micro SD card and the files will show on the right-hand side.
Find the file that says " MMCSTORE" and then select "Copy."
Right-click on your desktop and then click "Paste." This will move the MMCSTORE file to the desktop so that you can get access to edit it.
Right-click on the MMCSTORE and then click on "Open With."
Open the file with Notepad.
Read the text to find the password.
It will be in plain text.
Remove the SD card from the computer and place it into the device for which it is used as storage.
Turn on the device.
When it prompts you for the password, enter it.
http://reviewunit.com/how-to-recover-lost-password-of-microsd-memory-cards/
Sep 16, 2013 | PNY 2GB microSD Memory Card
My files got deleted. How can i restore it for a Philips USA LFH0642/27 voice tracer recorder?
Use Card Data Recovery, it can recover deleted files from Philips USA LFH0642/27 voice tracer recorder.
Sep 19, 2011 | Cameras
Hi drivers ok but no icon or soft ware to program a SAA7130 TV card
Hello the problem with your TV card is when you install in your pc you don't make a shortcut in your desktop try to go the local drive where you installed your TV card then in program files find for the folder of Philips then open it or double click the folder. Then you will see there the .exe file where shortcut of the program where used to run your software. Or right click on that icon and then click copy and minimize the folder then on your desktop right click and click paste. Hope it can help with your problem.
Jul 14, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
Im using a kodak camera. My sandisk memory card needs to be formatted, but doing that will cause me to lose all my photos, which i really want to keep. Is there any way to save theses photos. It wont even...
Hi ashlingw,
Let me help you with the problem that you have just described, please follow the below steps :-
  1. Get a memory card ready from the market which would cost very less so that you can connect the memory card to your PC.
  2. After you get a memory card reader you can insert the san disk card in it and you will be able to see the files , the image files that you have on your memory card , on your pc.
  3. After you are able to see all the files on your card , you can copy the entire content to your desktop which means that you are copying those images on your hard disk.
  4. To copy the images, press CTRL + A or go in edit menu and select select all option once you are in the image directory , then select copy and create a new directory on your desktop and paste the images by opening the directory by the CTRL + V option or the edit -- Paste option.
Al alternate way to do this is to connect your camera directly to your pc in a mass storage mode and then you will be able to see all the image files so that you can follow the copy process as described above so that you don't lose your files.
If you are assured that you have copied the files to your desktop i.e. your hard disk you can go ahead and format your memory card.
May 10, 2011 | Cameras
Find driver easy tv captuer saa7130hl
http://download.cnet.com/Philips-SAA713X-Hybrid-Capture-Device/3000-2110_4-156884.html
if this does not help try www.driverdetective.org free to scan your computer if it finds your driver you will have to pay to download
I scaned file it looks clean but you should save it to your desktop and scan it also. G.L.
Malwarebytes' Anti-Malware 1.50.1.1100
www.malwarebytes.org
Database
version: 6326
Windows 6.1.7601 Service Pack 1
Internet Explorer 9.0.8112.16421
4/24/2011 2:14:55 PM
mbam-log-2011-04-24 (14-14-55).txt
Scan type: Quick scan
Objects scanned: 1
Time elapsed: 1 second(s)
Memory Processes Infected: 0
Memory Modules Infected: 0
Registry Keys Infected: 0
Registry Values Infected: 0
Registry Data Items Infected: 0
Folders Infected: 0
Files Infected: 0
(No malicious items detected)
Nortons insite scan
Scan Statistics:
Scan Time: 1 seconds
Scan Targets: C:\Desktop\Temp download\Drv_ATSC110_Philips_V1.3.3.2.zip
Counts:
Total items scanned: 78
- Files & Directories: 78
- Registry Entries: 0
- Processes & Start-up Items: 0
- Network & Browser Items: 0
- Other: 0
- Trusted Files: 1
- Skipped Files: 0
Total security risks detected: 0
Total items resolved: 0
Total items that require attention: 0
Resolved Threats:
No risks have been resolved
Unresolved Threats:
No unresolved risks
Apr 24, 2011 | Philips SAA7130 TV Tuner/FM Radio/Video...
I am trying to download pics into a photo album...it is saying insufficent memory card...i have done about 60 pics from same caed and now it wont do anymore...i have 389 pics on the card and asked for them...
Possible malwares or corrupt files on the card that is not allowing it to be downloaded, please check this card with another PC to confirm, if so use a search mode and detect all the files to be saved , then format off the memory card.
Also make sure that the photo album does not contain any corrupt files that is rejecting the card.
Nov 03, 2010 | Philips 6.5-Inch Digital Photo Frame...
I have videos on my 8310 blackberry and i want to tranfer them to my desktop to play them.
Hi, Video files will be stored on memory card in blackberry, so please take the memory card and connect the memory card to computer. you will see a saperate drive in My Computer. Now you can transfer the video files to computer.
OR you can try another method. Please install latest version of Desktop Manager in your computer, connect blackberry using USB data cable, Then you can transafer the data, files, videos etc. If you dont have Desktop Manager software cd to install, you can donwlaod the software from blackberry.com. I hope this information will be helpful.
Nov 17, 2009 | AT&T BlackBerry Curve 8310 Cell Phone -...
I need to back up my contacts from phone memory to card in a blackberry storm
Would you like to try this........
  • Unlock device of device keyboard.
  • Connect it via USB cable to your desktop computer.
  • A new removable drive will appear in "My computer" drives list.
  • Run Blackberry Desktop Manager on your desktop computer
  • Open "Backup and Restore" icon
  • Click on "Backup" button and specify target folder on this removable drive. For example if this removable drive has assigned letter E then the target folder for backup will be: E:\BlackBerry\documents
    That will make a full backup into *.ipd file located at your memory card.
  • To make backup of some particular data - click on "Advanced" button and specify information to be saved. And after that transfer created ipd file to your memory card.
Jul 07, 2009 | RIM BlackBerry Storm 9530 Smartphone
Philips flat screen tv reboots
Try sticking in a blank but empty USB memory stick into the USB port.... have the real remote (philips not a universal) ready... Go into the TV Menu..Select Software Update, then select Update Assistant.... then right click over to start now... It will write an HTML file to the memory card.. wait for it to say done,(been awhile since iv done it), plug it into your PC/Mac and open the file on the USB stick.... if you need an update it will check for it... download the update and the instructions to your desktop (might be compressed, if so open it and copy the files according to the readme.... stop the stick (eject) in Windows or the mac equivalent... pull it out of the pc.. turn OFF the tv and insert...
This can very likely stop the reboot loop.. Iv seen mentions of some tv firmware revisions having this problem.
Feb 22, 2009 | Philips Televison & Video
Philips Desktop 9750 Desktop Digital Transcriber / Recorder Logo
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
