Question about Samsung HLT5055S 50" TV
HLT5055WX/XAA turns on then turns off. About 2000 hrs on Philips replacement bulb
  • 1 more comment
  • Carl Matson Dec 06, 2012
    Bulb comes on then gets btighter, then gets a little brighter again. The front fan comes on, and all 3 lights on the front (red,green,green) blink/ (Lamp replacement code?)
  • SD Tech
    SD Tech Dec 06, 2012
    No an that souns normal, you getting any high pitched or fan like sound from that area of the set? The only way to really know is replace the lamp. The number of hours it has does bother me though. You might want to remove the lamp, look for the center glass post being bent and reseat it (the lamp unit).
    Thanks for the quick response. Lamp post doesn't appear bent. NO high pitched noise. Someone mentioned possible Lamp ballast replacement, I suppose Lamp replacement first and if that doesn't fix it, try ballast. Someone also said lamp mercury changes and the lamp gets too large an arc to light up?
    Top Expert:
  • Samsung Master
  • 14,553 Answers
That is near or past the normal life on the lamp---2,000 hours or 2 years is normal---I would remove and look at the lamp---if shattered you know and also look the pillar of glass inside the lamp is not bent or warped etc.
Posted on Dec 06, 2012
My Samsung hlt5055wx/xaa has 2 green lights lit up but won't come on ? We replaced the picture tube 2 weeks ago and it has been working fine until I tried to turn it on today.
Your TV doesn't have a picture tube but rather a bulb. I would eliminate other possibilities first like cable connections etc first before looking into the set. Check all inputs with DVD or Bluray and see if it malfunctions across all inputs. If so it would be time to open up the set. If you are not comfortable with electronics you will have to bring it in.Really these sets are being given away these days and a repair should be considered carefully before spending any money.
Jul 03, 2016 | Samsung Televison & Video
Why does my DLP TV turn itself off
Try replacing that lamp door switch, this has been known to cause issues in some Samsung DLPs
Contact Samsung at 1-800-627-4368 for proper part#
Oct 21, 2014 | Samsung HLP5063WX/XAA
SAMSUNG dlp tv wont come on..trys too them goes off before pic appears and flashes red and green light not light in middle..model is HLT5055WX/XAA
There are so many possibilities... If you are SURE that the lamp is good (did you take it out & look at it?) Easiest: When you turn on the tv, do you hear a 'whirring' sound coming from the back? If you do, is it a 'smooth' sound or is it rough, scratch, & noisy?. If it is smooth, or if there is no sound, next place to check is the power supply. If it is rough & noisy, it is a bad color wheel. Unless you REALLY know what you are doing, anything other than a lamp replacement should be left to a professional repair person.
Samuel Morris
Camtek Of NY Inc
Oct 12, 2014 | Samsung Hlt5055w
HLT5055WX/XAA Has intermitant sound distortion
Check the speaker/s first. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" or "Magazine" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
May 12, 2014 | Televison & Video
Samsung HLT5055WX/XAA Intermittant Sound Pops, and people sound like talking on Helium
Check the speaker/s. If found OK; check and replace the damaged component/s at its audio output section circuit board. If needy, replace this board as card basis. If you wish to get some details; check the site linked here. Pull up older posts. Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts. http://electronicshelponline.blogspot.com/
May 31, 2017 | Televison & Video
Pb01 HLT5055wx/xaa Has 9 dots on screen small pinpoints All over randomly
Sounds like panel fault. Anyway, http://electronicshelponline.blogspot.com/ check this link. There is details and screen shots to defects to flat panel TV screens. Compare the screenshots with your TVs, and make sure about the fault. Pull up older posts.
Jun 15, 2013 | Samsung Televison & Video
I have a Model HLT5055WX/XAA that will turn on, but shortly after coming on the picture goes out. Audio still works but picture goes out and the lamp turns off. I think i need to replace the lamp but am...
Sometimes you have to gamble, lamp most likely--at least look at the lamp and make sure the glass pillar in it is not at a angle etc.
Sounds like you have taken all the easy steps, hate to buy a lamp you may or may not need but since wheel is ok the lamp or ballast are most likely.
Dec 16, 2012 | Samsung DLP HL-P5663W 56" TV
Dark pic on Samsung HLR5677WX/XAA
I have a samsung hls4676sx/xaa its has hundreds of white dots some are blinking how do I fix it
Jan 09, 2008 | Samsung DLP HL-P5663W 56" TV
Samsung HLT5055S 50" TV Logo
101 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
