Question about Radio Communications
What can I do to increase modulation on my pc78xl
    Sergeant:
  • 193 Answers
Open radio and adjust VR 4. Might need external power/modulation meter to do so. Or watch swing on radio meter.
Posted on Dec 06, 2012
  • Josh compton Feb 06, 2013
    thanks Jeremy that worked great could you also tell me how I can peak and tune my president Zachary t.base station
  • Jeremy Nottingham
    Jeremy Nottingham Feb 06, 2013
    1. Remove C128 (.47uF).
    2. Remove TR16.
    3. Replace R132 (1k) with a 470 Ohm.
    4. Replace R50 (3.9 Ohm) with a 1 Ohm.
    5. Re-tune coils L13,L12,L11 for maximum forward power output.
    6. Jumper C61 with a 67pF capacitor.
    7. Replace TR10 (2SC2029) with a 2SC1969 then tune L16,L17 and spread L14 For even power across band.
    8. Remove D13 and replace with a jumper. (This supplies more power to final)
    MODULATION: VR6 or cut D16
    AM POWER: L13,L12,L11
    RX COILS: L1 thru L8, VR1
    Step 5 for basic output tune. And the adjust vr6. Anything more the final and driver should be replaced. I also found that adjusting the power supply voltage around 14.2Volts also squeezz out all you have there already. Any higher and it puts a strain on the regulator on the power supply.
    2. Remove TR16.
    Habit-Forming:
    New Friend:
  • 65 Answers
Theres a process to increasing the modge ...it invlolves removing 2 cap discs a transitstor and jumping a wire you can find this mod i believe on cbtricks.com
Posted on Mar 11, 2015
Where could I find a linear amp for my pc78xl
Most repair shops sell or know where but you can find them new on the internet, try Google or one of the search engines, the radio will if stock have to have the output adjusted to use the amp.
Dec 12, 2012 | Radio Communications
Schematic for pc78xL won,t turn on
there gould be a number of reasons for it not turning on but the one I am thinking of is the reverse polarity diode. If it is burnt your radio will not turn on look in the area of your where your power wires come in .You should see a single black zenner diode.Replace it and it should turn on .
Jan 21, 2012 | Uniden Bearcat Pro PC78XL 40-Channels Base...
I have a bear cat scanner i moved out of nys to nc and now i cant find any codes wat can i do
The best database for locating your local frequencies can be found at:
www.radioreference.com
Another source is:
www.cityfreq.com
Sep 02, 2009 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Not receiving on any channel
uou may a bad mic if not I would think the
autoamp is at bad.this means you will
have to thae to a shop.
Good luck
Aug 26, 2009 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Mic not Keying up
Sounds like you are not modulating well. try adjusting your amp.also, test your antenna for wire breakage and, make sure that your mic has good wires as well.
Jan 22, 2009 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Want to increase memory above 1 gig. compaq nx9010
You may have incompatible memory module. Just put in one memory module in at a time to see if it boots up, this will determine which module was not compatible.
Nov 15, 2008 | HP Compaq nx9010
Cb radio
Hi, A couple of switches and knobs you can check (if present in your rig): 1. auto noise/noise blanker switch - try off position; 2. dynamic squelch control - lower down setting; 3. RF gain - should be at max (clockwise); and 4. Delta Tune - normally should be centered. Hope this works out for you and give you an idea where to start. Good luck and pls post again how things turn up. Kind regards.
Aug 07, 2007 | Uniden Bearcat Pro PC78XL 40-Channels Base...
Radio Communications Logo
98 people viewed this question
Top Radio Communications Experts
eradiostore
eradiostore
Mike Charette
Are you a Radio Communication Expert? Answer questions, earn points and help others
