Question about Sharp 32U-S60 32" TV
TV all the sudden won't power on. Where is the fuse located?
    Top Expert:
  • Sharp Master
  • 14,553 Answers
Follow the power cord inside the set as it goes almost directly and non stop to the AC line fuse.
Posted on Dec 06, 2012
All 4 windows won't work and rear door latch won't open! So, I have two problems: Firstly my rear hatch won't open as of yesterday (Keyless entry pushed & it doesn't even make a noise...
Look at your maintenance manual. To find where your fuse box is located(may be under the hood or under the steering wheel). When you find the fuse box look on the back of the panel flap and you'll find a fuse map. Locate the fuse that corresponds with your problem. It could be the same fuse but not likely. If fuse is blown then replace it with a spare. Most manufacturers will put spare fuses in the box or you could pull a fuse from some where else just to try and see if the problem is still there( make sure it's the same size and understand that it could blow this fuse as well then you will need 2 fuses). Most of the time fuses don't just blow. For some reason it pulled to much load. Probably a dead short in the wiring. I hope this helps.
Jan 22, 2013 | 2005 Toyota 4Runner SR5 V8
The TV won't turn on. It is plugged in, but won't turn on at all. Is it fused?
It has a fuse and if the power light comes on and blinks a specific code that would be a error code.
This set weighs close to two hundred pounds, follow the power cord inside the set as it goes almost directly to the fuse which should be a 6.3 amp fuse----careful if its bad, it is a slow blow and special, a Radio Shack or Generic one the same amperage and type will blow for no reason, if its bad don't keep feeding it fuses.
Dec 08, 2012 | Sony FD Trinitron WEGA KV-36FS120 36" TV
My MW511 won't start
Check the input power is coming or not. Check fuse inside control board & wiring too. If everything ok then it's problem of control board
Oct 14, 2017 | Washing Machines
Power windows are all down & won't go up, could it be the fuse?if so, where is the fuse located? what does the fuse look like?
if you got a 2001 & up likely the fuse box is in the hood.look on the driver side there should be a little gray box filled with neon yellow & green fuses. the look like memory cards for a cell phone
Dec 27, 2011 | Dodge Grand Caravan Cars & Trucks
2005 sedona won't start all of a sudden. Doesn't make a sound except for a tiny whirring sound like the feul injectors. Replaced starter...still won't start. checked all fuses...they are good....
you could just have dead cell in the battery which isn't getting enough amps to the starter,, have the battery LOAD checked,, that will tell you if the battery is actually good, just because it registers 12 volts isn't necessarily an indication that the required amps are present.
Sep 27, 2011 | 2005 Kia Sedona
I have a 46" Flat Screen TV. Model Number
First thing you do is to check the outlet if there is a power output the check the power cord and plug.If there 's a power in the power cord,Check the fuse of your television.The fuse is located at the power supply.You can see the power supply when you open the back cover of your television at the upper right side.Replace the fuse if busted with the same value of fuse.That's the step you can do first..Thanks..
Aug 25, 2011 | Televison & Video
It won't turn on.
Plss check if there is a power at the AC cord.Then if ther's a power try to check the fuse.It is located at the power supply of the television.Try to remove the back cover and look the power supply.Check the fuse if busted.Replace the fuse with the same amphere if busted,then power on your TV.Pls reply if did not work.Thank you!!
Aug 20, 2011 | Televison & Video
I have a 1 year old Sanyo Vizon HDTV and was watching a show when it suddenly just shut off and would not go back on again. No storms or any other power surges and it is hooked up to a real surge...
Hello
If there is no power indicator LED lights up when the set is sitched ON, the power regulator section inside your TV is faulty. There is a fuse [glass cartridge type]; on the power regulator board. If this fuse blows OFF the set won't switvh ON of the front power light won't light up. Check this fuse first. You can locate it at its power switching regulator board inside, where the AC power goes straight to it after a filternig circuit. If the fuse is blown out, replace ti with same rating. It ratings will be marked either on its edge rims of on its body by colour code lines. Replace the the fuse; if it has blown out, and switch ON the TV. if the replaced fuse also gets failed, do not put any fuse after, the power supply section has some short with it. It is best to replace the power supply board as a card absis; rather than making "surgery" to it. Some components in it will be very difficult to get too. You can buy a new power board from /Vizio Authorised Service Center at your town. OK.
Jul 14, 2011 | Televison & Video
Power won't come on
No power signal lights appear?If no power lights try to check the fuse inside your TV.remove the back cover to see the fuse location.It is located besides the power supply.check it if busted,then replace the same value of fuse.Unplug first before removing the cover to avoid electric shock.thanks!!
Jul 07, 2011 | iLO LCT32HA36 Television
I have a 1 1/2 year old Panasonic TC-P42U1 plasma tv. While watching a show, it suddenly shut off and won't come back on. What do you think caused this and how can i fix it? Thanks.
Try unplugging it completely for 30 seconds to 1 minute. Plug it back in. If it still won't come on, it's likely taken a power surge and popped a fuse or power supply, which means a trip to the service center.
Jun 18, 2011 | Panasonic TC-P42U1 42 in. Plasma HDTV
Sharp 32U-S60 32" TV Logo
123 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
