Question about Sony STR-DE985 Receiver
Str-de985 humming noise only when using FM tuner. Everything else works fine with no humming noise
  • Anonymous Mar 13, 2014
    First FM, then am as well. This was preceded by a very odd noise. Everything else works just fine. Thank you.
    Sergeant:
  • 256 Answers
Have you got a FM Antena hook up to it for the FM ,Sations, If not that could be causeing it to hum.
Posted on Dec 06, 2012
5 Suggested Answers
  • 52 Answers
SOURCE: I HAVE A SONY RECIEVER STR-DH700, I get no sound
make sure the FM antenna is connected and in a good place then check to see if the A-B speaker selector is selected properly.check to see that the sound field is set properly, My 800 allows for several different options and if your speaker wires are reversed or not in the correct position front left at front left etc it will not send the signal to those speakers. try using the TEST TONE feature if you have one it will send a signal to each speaker in sequence (LF< C< RF<in order) it will go all the way around to see if they are connected properly, that way you can tell if they are connected at all or in the wrong spot on the back interface. I dont know if that is what you meant by AUTO CAL, but that is a seperate feature when you use the connected mic to determine range, height and distance to the position in the room you are most likely to be seated for optimal sound.
Posted on Nov 29, 2009
dunnbiker
  • 8546 Answers
SOURCE: Subwoofer hum from STR-DH800
That points pretty much to a bad shield on the cable. Have you tried another one? Another thing to try is to rotate the AC power cord on the sub (if it has one). Sorry, too lazy to look it up.
Posted on Dec 29, 2009
freetek
  • 5568 Answers
SOURCE: My Sony STR-DE685 Receiver out of the blue now has
In receivers, there are different power supplies or power supply outputs for the receiver and amplifier sections so you can have separate failures with one area not affecting the other. From your description, I think the (probably lower voltage) section for the receiver has either lost a cheap filter capacitor or a regulator IC. Neither of these are expensive parts but I can't know what labor costs in your area might be. An honest tech shouldn't ask more than ~$100 US for that kind of repair.
Posted on Apr 16, 2011
dunnbiker
  • 8546 Answers
SOURCE: i purchased a used sony
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Sony-STR-DE985-Receivers-manual/id/387dj984/t/2/
Posted on Jun 12, 2011
Amplifier - TA-AX380; CD Player - CDP-C40; AM/FM Tuner - ST-JX380; FM Stereo/FM-AM Receiver - STR-AV570X, and Stereo Cassette Deck - TC-W380.....all Sony. Very old system, do not have the manuals, they...
Since you have 2 receivers, you can either use the Sony STR-AV570X or the TA-AX380. You will need 3 Stereo RCA Cables to connect your CD Player, Tuner, and Tape Player. The speakers connect to the receiver you choose using the speaker input terminals.
Here is the diagram (click on picture to enlarge):
Jun 22, 2011 | Audio Players & Recorders
Philips SAA7130 TV Tuner/FM Radio/Video PCI remote stopped working
PLEASE THE SEND THE TV TUNER CARD DRIVERS I AM LOST THE TV TUNER CD
May 04, 2009 | Philips SAA7130 TV Tuner/FM Radio/Video...
I have a hum or buzz on AM and FM bands only.
I had the same problem, but it is not the tuner module! An exchange of capacitor C899(100μF/35V) on the standby board has resolved the problem. Under a dollar from an electrical store and you are all sorted. 10 minute fix for those with a soldering iron.
Feb 18, 2009 | Sony STR-DE685 Receiver
Sony STR-AV770 AM/FM Tuning
If your going to buy an antenna you could do some research at cccrane.com. They might be able to help you with the other problem too.
May 15, 2008 | Audio Players & Recorders
WIN VISTA Ultimate does support Philips SAA7130 TV Tuner/FM Radio/Video...
I couldn't get to work in Vista. So I tried in linux and My SAA7130 is working great in Ubuntu linux. bye vista.
Dec 26, 2007 | Philips TV Tuner Video Capture PCI Card -...
Manually tuning the reciever
you should be able to tune in manually.
press tune
press fm or am
press d. tuning
enter the frequency of the station 4 or 5 digits ie 9370 or 10450
another thing to look into would be getting a yagi fm antenna, they are directional and although you may have to rotate it for best results, they work great.
Nov 20, 2007 | Sony STR-DE985 Receiver
Sony STR-DE985 Receiver Logo
270 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
