Question about SK Hand Tool Altenator / Power Steer / Air Pump Pulley Puller
2002 ford escort intemittent charging
After engine warm up battery stops charging but after disconecttting alternaor then re connecting battery will charge on off on off ?
    Scholar:
  • 89 Answers
The is just one of a few things it could be...there should be a recharge relay. helps to protect the computer board from a power surge. by all means though keep your mind open to other ideas as well
Posted on Jan 12, 2009
I TOOK MY FOR ESCORT 2002 ZX2 FOR A EMISION TEST AND IT FAILED
Disconnect the battery and press the stop pedal few times. Re-connect battery and see if the engine light is on or off.
The car may act differently for a few starts ( computer has to relearn) and you will lose all your preset stations and time on your clock if equipped.
Jul 03, 2014 | Emission System for Ford Escort ZX2
MY 2002 FORD ESCORT'S CRUISE CONTROL AND HORN SUDDENLY STOPPED WORKING. THE FUSES ALL CHECK OUT. WHAT IS THE PROBLEM?
there is two sets of fuses on this car i think. The centre console lights are on fuses inside the car under the dash, is your interior light not working either?
Nov 12, 2013 | 2002 Ford Escort
My 1998 ford escort stop running no lights
start with the battery. needs at least 11 or 12 volts to start the car. By no lights, do you mean nothing, absolutely nothing comes on? no lights on dash when you turn key to on? If so, need to check battery connections. are they both tight and clean? Is battery fully charged? Before you can diagnose the car you musthave a good battery that is fully charged. Then you can try and start it. If it still wont start or crank over you may have a main fuse out that would be under hood near battery.
Oct 07, 2011 | 1998 Ford Escort
How to install thermostat
Removal
  1. Disconnect the battery ground cable.
  2. Remove the air cleaner outlet tube.
  3. Drain the engine coolant to a point below the water thermostat
  4. Disconnect the water temperature indicator sender unit and the engine coolant temperature sensor electrical connectors
  5. Disconnect the upper radiator hose and the heater coolant hose from the water thermostat housing.
  6. Remove the water thermostat housing bolts, the water thermostat housing, and the water thermostat.
INSTALLATION
  1. NOTE: Make sure all of the gasket surfaces are free of all gasket material. Make sure the tabs on the water thermostat engage correctly into slots in the thermostat housing.
To install, reverse the removal procedure.
  1. Fill the cooling system.
  2. Start the engine and check all hoses and connections for leaks. Allow the engine to warm up so that the water thermostat opens.
  3. Stop the engine. Top off coolant recovery reservoir as required to maintain minimum cold fill level
Sep 23, 2010 | 2002 Ford Escort
Alternaor not charging. replaced alternator still
to check alternator, undo batt cable while car is running if car dies alternator is bad.
replace alternator (some are bad from factory)
cars dont need battery to run just to start.
Sep 08, 2009 | Ford Expedition Cars & Trucks
2000 Ford Escort zx2 Odometer stopped working
Replace battery for sure then check the odometer connections at both ends, panel side and tranny side for loose connections, usually a theaded screw in type.
Mar 25, 2009 | 2000 Ford Escort
Intermitent charging 2002 ford escort
check wiring loom between alternator starter and battery
Jan 12, 2009 | 2002 Ford Escort
Alternator on my 1998 Escort quits charging
try cleaning the battery terminals with a wire brush
Dec 16, 2008 | 1999 Ford Escort
SK Hand Tool  Altenator / Power Steer / Air Pump Pulley Puller Logo
54 people viewed this question
Top SK Plumbing Experts
Gil Shultz
Dan Apthorp
Jim Goldsmith
Jim Goldsmith
Are you a SK Plumbing Expert? Answer questions, earn points and help others
