Question about IBM 4224 Model 101 Matrix Printer
Error 01 checked ibm 4224 impact printer.after initializing showing error 01 .How i can solve this problem.
Error 01 is End of Form, Make sure u have paper installed.
The sensor that is at the bottom left that you feed paper thru is were this error is generated. Make sure it is aligned and working.
Also clean with wet paper towel slide in and out
You can also run a Test 851. to see if the sensor is open(1) and closed(0). also check the connection on the board to see if it still connected.
I can go into level 2 support if more help is needed.
Posted on Jan 25, 2009
Display shows Check Printer E 04 01
an E4-01 is a fuser warm up error...this is usually caused by a bad thermistor but can also be caused by a bad fuser lamp or thermostat
Apr 02, 2014 | Panasonic Workio Dp 8020e
After initializing it is showing 01 error
howto solve 50.2 fuser error for cm2320
Dec 29, 2013 | Epson DFX-9000 Matrix Printer
My printer will not power on what can I do?
If you can open it : Test the power switch and the power unit and change if one dont work If you cant open it: Change your printer
Oct 18, 2012 | IBM POWER SUPPLY 4224 Printer Part 17F4711...
What is a 19 error code on the Ibm printer 4224
Attachment Card Failed Power on Tests.
1. Switch Power off (O).
2. Wait 20 seconds and switch power on(I).
3. If the printer displays (19) again then call for service.
May 14, 2012 | IBM 4224 Model 101 Matrix Printer
Code 56 error
You have a Head Error-Head Drive/Emitter Failure.
Your going to need to check your head drive belt, being that the printer is so old the belts go bad and start to crack and turn into a tar sub. Also make sure to clean your rails, over time they build up dirt and oil and need to be cleaned off.
Rory
rcarndeas@mrp.to
Oct 29, 2009 | IBM 4224 Model 101 Matrix Printer
I HAVE A 4224 PRINTER FOR SALE. WHO COULD I CONTACT?
Are you looking to upgrade? I can take yours as an exchange or if you are interested i can repair the one that you have like new.
Please let me know. I carry parts and printers in stock refurbished with a 30/day warranty.
Rory Cardenas
Midrange Repair and Parts
Alsip IL 60803
708-597-4222 X240
rcardenas@mrp.to
Jun 22, 2009 | IBM 4224 Model 101 Matrix Printer
Machine error E04-01
error e04-01 means fuser warm up temperature
problems could be
-fuser thermister dirty ir defective
-fuser lamp is disconnected or defective
-fuser thermostat is defective
Oct 17, 2008 | Panasonic Workio DP-4530 Copier
IBM 4224 Printer G111 (172.26.131.26) does not print. Possibly bad card.
What are you trying to do? Get a Manual.
I have the book I would have to scan it for ya, but what do you need the MIM or the MAP?
Is there a Error Code?
Aug 25, 2008 | IBM 4224 Model 101 Matrix Printer
I need hep for my printer
How to get a manual to show how to do this?
Jan 09, 2008 | IBM 4224 Model 101 Matrix Printer
IBM 4224 Shuts off after warm up
4224 were notorious for poor connections between the control cards and the motherboard. Opening the printer and reseating all the cards solves a multitude of problems. Try it.
Aido
Dec 11, 2007 | IBM 4224 Model 101 Matrix Printer
IBM 4224 Model 101 Matrix Printer Logo
225 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
Jim Keysor
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
