Question about Toshiba CZ36T31 36" TV
Set channels for dish - Toshiba CZ36T31 36" TV
    Top Expert:
  • Toshiba Master
  • 14,553 Answers
You want to program the set for channels or a remote? Not clear what you are after here.
Posted on Dec 06, 2012
How to get full picture on my tv?
First, ensure your tv is using the highest resolution possible (Usually 1080 for flat screens) by using an HDMI cable from the receiver to the television, and that you are on the correct input. Second, ensure your tv is not sizing the video by using the 'picture size' or 'aspect' or 'ratio' key on the remote that came with your tv (Not your DISH remote). Third, tune your DISH receiver (with your DISH remote) to an HD channel (for VIP model receivers, when you tune the channel to an HD channel, an opaque white 'HD' appears insude the blue box at the top of the screen). Fourth, hit the star key on the remote, while watching the screen. On the right hand side, near the top, it will cycle as you hit repeatedly the star key, the style of screen widening. Hit the key as often as you need to make the screen appear the way you want it to. The receiver will remember your setting for all HD channels. When finished with the HD channel, tune your receiver (with your DISH remote) to a SD channel (any channel in the guide that does not have the HD icon). Repeat the fourth step.
For Hopper/Joey family receivers, hit menu, settings, screen size. Follow the instructions to resize your screen to match your preference. When finished, repeat step four above on each an HD and a SD channel.
Mar 15, 2015 | DISH Network Televison & Video
Satelite Dish
please tell the model number please.
reply.
Oct 29, 2008 | Samsung HP-R5072 50 in. Plasma HDTV
Olevia channel setup
With the remote of dish you will control the dish box. The tv control is only necesary to set the signal on channel 3 or Aux to get the signal from the dish box.
Now Your main remote will be dish remote control. Set your tv on channel 3, then turn on the dish box, and use normally.
Oct 02, 2008 | Olevia LT26HVX 26 in. LCD Television
Find the channel to run DISH
Channel 3 is normal for that. Always have it on channel 3 on the TV set. Then you can work with it. Check your stuff and see is there a switch to set for channel 3 or 4, if none present, put it on 3, then start from the menu to set it up with remote.
Oct 07, 2014 | TCL 39" LED LCD 1080p HDTV - TVs & Home...
Reset set t.v. to channel 60 for DISH system without a remote for RCA tv
Use the TV's original remote to put it back on channel 60. The
Jun 21, 2017 | RCA Televison & Video
Can not change channel to 60 or 73 for dish
Not sure what you mean----if using HDMI the Dish box should change channels. HDMI does not like being hooked up with box and or set on---disconnect set and box including power and wait and hook up and restore power.
Aug 30, 2012 | Televison & Video
Have new E370VL hooked up to Dish Network via coax. The picture jumps/blips? Connections are tight. Help.
This can happen when there is radio interference near the coaxial cables. Sometimes the interference is behind walls. The solution is to try a different combination of modulation and channel than what the DISH receiver is current set.
The DISH menu screen for this setting is Menu-6-1-5. With dual-tuner receivers, typically "TV 1 Out" is the TV that is connected in the same room as the receiver is located. "TV 2 Out" is the tuner that is fed to the remote TV via backfed coaxial signal.
All that needs to be done is to change the channel and mode going to the effected TV to something different. If your channel/mode is currently set to Air/60, try changing it to Cable/73. When you change the mode/channel in the DISH receiver, you need to set the remote TV to the same mode and channel.
Keep in mind that with some TV companies like VIZIO, they call their "Air" mode "Antenna". With VIZIO's the TV must be set on TV input and then go into the Menu to the Settings, Tuner Settings. Change mode type to match what you are trying on the DISH receiver, exit the VIZIO menu and manually enter the channel number.
Eventually with trial and error, you will find a mode/channel combination that isn't effected by your particular environmental interference.
Jan 03, 2011 | Televison & Video
No antenna tv signal
Your dish remote should be set to the code for your TV. Then you will be able to control the channel number, not just up/down, as well as volume and maybe even the input. But do try to get a real remote for your TV so you can get to its menus.
Meanwhile, use menu+menu to see the channel being output by the Dish receiver. (Must be a 622/722... based on the 60 you listed.) Try to find an unused UHF channel number that your set does have in its up/down list. Match Air/Cable setting of Dish and TV. The Dish output is analog (NTSC) although the tuner(s) only accept digital (ATSC).
-Ken
Jul 26, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
Locked Channel
try settings and the set all data to factory default or restore to factory settings, then you my start new installation. Jkahangwa
Jun 05, 2008 | JVC AV-27230 27" TV
White screen with dish network
This is an ancient message so you have probably long since found your problem.
There may be additional input settings to be made since it sounds like the set isn't seeing any input. If you are using the cable input on both the receiver and TV, you will have to set the TV to channel 3 or 4 to see the output of the Dish receiver.
There are three common ways to connect; via the familiar cable in/outputs, S-video with a separate audio cable, and possibly DVI. The TV's input may not search for and find the right input since many sets have a setting via their menu to force the set to look at a specific input.
It helps to have both the Dish manual and the set's manual side-by-side.
May 25, 2008 | Akai LCT2060 Television
Toshiba CZ36T31 36" TV Logo
15 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
